Old 30th September 2007, 08:43 AM   (permalink)
Smile PIC to LCD wiring problem ?
Yester day i bought a 20X4 LCD and this is a schematic for LCD Alarm clock( 20X4 ).
So my prob is
That PIC to LCD wiring is not clear to me.
Plz can some one help me plzzz..
pasanlaksiri is offline   Reply With Quote
Old 30th September 2007, 09:01 AM   (permalink)
Have you seen Nigel's site?
http://winpicprog.co.uk
Superman returns..
bananasiong is offline   Reply With Quote
Old 30th September 2007, 09:10 AM   (permalink)
hi Pasan,
It would be helpful if you could post the program code, so that we can identify which pin is which.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now   Reply With Quote
Old 30th September 2007, 01:04 PM   (permalink)
http://www.thouters.be/PicAlarmClock
coded in Jal downloads http://www.thouters.be/Downloads
art-666 is offline   Reply With Quote
Old 30th September 2007, 03:26 PM   (permalink)
i hope you are sure about the lcd's model is hd44780..
kerelektronik is offline   Reply With Quote
Old 30th September 2007, 05:01 PM   (permalink)
The port pin references from the posted site shows this:
-- pin assignment for the 4-bit (6 PIC I/O pins) interface:
-- PIC        HD44870
--  5 Gnd      1 Gnd
-- 14 Vcc      2 Vcc
--  5 Gnd      3 Contrast
--  6 B0      11 D4
--  7 B1      12 D5
--  8 B2      13 D6
--  9 B3      14 D7
-- 10 B4       4 RS D/I_
--  5 Gnd      5 R/W_
-- 11 B5       6 E
-- pin assignment for the 8-bit (11 PIC I/O pins) interface:
-- PIC        HD44870
--  5 Gnd      1 Gnd
-- 14 Vcc      2 Vcc
--  5 Gnd      3 Contrast
-- 17 A0       4 RS D/I_
--  5 Gnd      5 R/W_
--  1 A1       6 E
--  6 B0       7 D1
--  7 B1       8 D2
--  8 B2       9 D3
--  9 B3      10 D4
--  6 B4      11 D4
--  7 B4      12 D5
--  8 B6      13 D6   (2k2 series resistor for ISP!)
--  9 B7      14 D7   (2k2 series resistor for ISP!)
It dosn't seem to make much sense when compared to the circuit.
I'm assuming the 8 bit LCD 16F877 connect list.
Where is the RS line, it says PORTA.1 in the list, also the LCD contrast is grounded??
Eric
PIC tutorials:
Old 30th September 2007, 05:36 PM   (permalink)
es it is
Old 1st October 2007, 07:42 AM   (permalink)
Originally Posted by pasanlaksiri
es it is
hi Pasan
Have you compared the table I posted [taken from that website] with your circuit diagram?
It does not match.
Eric
PIC tutorials:
Old 1st October 2007, 07:45 AM   (permalink)
Originally Posted by ericgibbs
hi Pasan
It does not match.
Ya it doesn't match. But i can take sme idea from it.
Old 1st October 2007, 08:01 AM   (permalink)
I would consider using your compiler/assembler to produce the *.hex code from the JAL files,
then using a dis-assembler to get a 'normal' source code listing.
IIRC WinPicPro [Nigel has referred to at time?], no sure, never used a PIC dis''
This should enable you to decide which PIC pins drive which LCD pins.
Also use a 10K pot on the LCD Vo Contrast.
Eric
PIC tutorials:
Old 1st October 2007, 01:36 PM   (permalink)
I think he set that display to MAX Contra.
Thanks for the advice. I'll use Preset
Old 1st October 2007, 01:45 PM   (permalink)
Yes, use the preset - on many LCD's setting it to maximum means it doesn't work (it just gives all black squares).
Old 1st October 2007, 01:54 PM   (permalink)
Yes, I also have 16X2 LCD connected to the PC. When i ground that pin Its shows only black squares
Old 3rd October 2007, 10:05 AM   (permalink)
I have a serious problem again about Programing the PIC.
When im trying to Program ( main.hex ) the PIC its always faill to verify. My programmer is also working properly.
I set configurations as he said so.
osc hs
watchdog off
powerup on
protection off
But all ways get same error.
Then I and select XT osc. Then its verify the chip. But it doesn't work.
Y really it wont verify the chip? Is it coz of problem in the source codes
Here is the files
ASM
HEX
Thanks guys
High ADC sampling rate PIC, 18F needed? bananasiong Micro Controllers 24 28th October 2007 12:13 PM
Newbie needs help with LCD backlight dimming Mongoose General Electronics Chat 6 21st September 2007 11:23 PM
Nokia 7110 LCD + questions regarding code and behaviour of LCD. MrNobody Micro Controllers 2 19th September 2007 07:50 AM
RF tranceiver problem darvaish General Electronics Chat 2 3rd April 2005 07:44 AM
Analog output PLC CQM1H problem goekgoek General Electronics Chat 0 24th June 2003 08:07 AM
