Old 3rd October 2007, 05:56 PM   (permalink)
What error do you get? It fails to verify? What type of programmer are you using?
Also use the mangage attachments instead of some bizzare remote site, just zip them and post here.
PS I downloaded you .asm file, what did you edit it with? It's unreadable.
PPS all black squares on an LCD might mean too high a contrast, you should put the 20K pot on the design, usually one line of dark (not black) squares on a 2x16 LCD is about right. Both you'll never see anything. It varies from LCD to LCD and temperature.
Bill
Smart Kits build Smart People
Old 3rd October 2007, 06:09 PM   (permalink)
I hv never been use that b4. Thats y i fogot that. Sorry
Yes its fail to verify,
My programmer is Multi PIC Programmer 5v2.
I programm same PIC using that programmer perfectly
pasanlaksiri is offline
Old 3rd October 2007, 06:17 PM   (permalink)
Like Bill found, it will not assemble. its full of worms, where did you get it from?
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 3rd October 2007, 06:26 PM   (permalink)
http://www.thouters.be/PicAlarmClock
Hmmmm Shit I waist my time on this.
Old 3rd October 2007, 07:50 PM   (permalink)
Please hold patience
please send a detail of what pins you have connected for the 10 wire cable clearly indicating cross connections of the pin numbers of 16 pin LCD display .
let us see, afterall the site gave so many photos to make me atleast feel that genuine effort was there.
Take little more pains
Regards,
Sarma.
mvs sarma is offline
Old 3rd October 2007, 08:03 PM   (permalink)
PIC Pins / LCD Pins
RB0 - 11 (D4)
RB1 - 12 (D5)
RB2 - 13 (D6)
RB3 - 14 (D7)
RB4 - 04 (RS)
RB5 - 06 (E)
- 05 (R/W) ( Ground )
- 01 ( Ground )
- 02 ( Vcc )
- 03 ( Vo ) ( i use 20K Preset here )
Old 3rd October 2007, 08:09 PM   (permalink)
Here is the original files. There is lots of jal files in it
Old 3rd October 2007, 09:39 PM   (permalink)
PIC Pins / LCD Pins
RB0 - 11 (D4)
RB1 - 12 (D5)
RB2 - 13 (D6)
RB3 - 14 (D7)
RB4 - 04 (RS)
RB5 - 06 (E)
- 01 ( Ground )
- 02 ( Vcc )
Connect buffered RC2(PIC-17) (that is resistor R7 at pin 10 of the pcb connctor JP1.) to pin 16 of the LCD
then youmay maintain 1V DC approx on pin3 ( contrast) some where beteen 0.9 to 1.2 the display will be clear.
All the best
Regards,
Sarma.
Old 3rd October 2007, 09:44 PM   (permalink)
Hi Bill,
Try reading the .asm or .jal files with winXP "Wordpad" they open up neatly
Regards,
Sarma.
Old 4th October 2007, 01:52 AM   (permalink)
All the best
THX but my prob is I can program the chip. Its always fail to verify.
Old 4th October 2007, 07:59 AM   (permalink)
you have the HEX file and it should load
as yopu are using the MultiPIC prog,let me veify--the settings with winpic800- there is a latest ver 1.62
BTW, are you sure that the Vpp is proper at above 12.5V or as perscribed in F877 datasheet for programming?
If needed try replacing the electrolytics to 220µ F
whether your PC is suppoeting the proper voltages? i shall be back with you
don't worry
Regards,
Sarma.
Old 4th October 2007, 09:12 AM   (permalink)
Hi Pasan, please see the site below and some of the comments are extracted from there and pasted here. perhaps you have to use winpic or winpic800 for programming f877 where as f877A is programmable by ic-prog.
http://feng3.cool.ne.jp/en/pg5v2.html
PIC16F870(8),PIC16F871(8),PIC16F872,PIC16F873,PIC1 6F874(4),PIC16F876(5),PIC16F877(5)
PIC16F873A(5),PIC16F874A(5),PIC16F876A,PIC16F877A
(5) IC-Prog cannot program/verify/erase these devices with Multi PIC Programmer 5V2. Please use WinPic.
Regards,
Sarma.
Old 4th October 2007, 11:27 AM   (permalink)
Hi
Im trying to Program PIC16F877A
But I program same chip b4 properly using multi Pic 5V2
Old 4th October 2007, 11:29 AM   (permalink)
Hi Pasan,
I did very minor changes and I was able to compile the file . a set of files is zipped and attached here. now please see whether you can programme it
Regards,
Sarma.
High ADC sampling rate PIC, 18F needed? bananasiong Micro Controllers 24 28th October 2007 01:13 PM
Newbie needs help with LCD backlight dimming Mongoose General Electronics Chat 6 22nd September 2007 12:23 AM
Nokia 7110 LCD + questions regarding code and behaviour of LCD. MrNobody Micro Controllers 2 19th September 2007 08:50 AM
RF tranceiver problem darvaish General Electronics Chat 2 3rd April 2005 08:44 AM
Analog output PLC CQM1H problem goekgoek General Electronics Chat 0 24th June 2003 09:08 AM
