| Got my new Inchworm+ and assembled it. Works great! Now if I could only get MPLAB for Linux, I'd be set. Hate windoze, but what can ya do? I have one question though: Should I have to unplug the programming cable from the target to allow the target to run my program (always had to unplug the K150). I thought that, since the Inchworm+ was a debugger too, I would be able to leave it plugged in between programmings. But the target doesn't run until I unplug. Last edited by futz; 29th September 2007 at 05:42 PM. | |
Short but not too detailed info: (very quick and dirty) The Inchworm can operate as a programmer or a debugger. There is a box on the main menu that allows you to select if you want to compile your program for RELEASE or DEBUG. For use with programmer select RELEASE For use with debugger select DEBUG Build asm/compile the program You need to select ICD2 under either DEBUG or PROGRAM tab In the programmer mode: Connect Program Under programmer tab/menu select "Release from Reset" to get your program to run with ICSP cable attached. HTH | ||
| Ah! Got it! Thanks 3v0! | |
| I'm told it works under WINE, but have not tested it. | |
And now I have a question for you: Where can I buy some of the other kits you sell? Is DipMicro going to be carrying the others? Do you sell direct? | ||
| Capacitor Charge/Discharge question | ThermalRunaway | General Electronics Chat | 25 | 12th August 2008 05:48 PM |
| Basic Transmission question | CamNuge | General Electronics Chat | 2 | 8th March 2006 11:08 PM |
| High speed data logging question | cubdh23 | Micro Controllers | 3 | 19th August 2004 12:54 PM |
| Data Logging question with high speed!!!! | cubdh23 | General Electronics Chat | 4 | 16th August 2004 07:33 PM |
| PBX question | waqar | Electronic Projects Design/Ideas/Reviews | 0 | 30th March 2003 07:21 PM |
