Old 29th September 2007, 08:11 AM   (permalink)
Default TX_test program in PIC C
hi all,
The code below is not working...Can anyone advice on this.I'm using PIC16f877.
#include <pic1687x.h>
#include <pic.h>
// Transmitter test program
void main() {
    TRISC = 0x00 ; //portC as output
	SPBRG = 129;	// Set the baud rate to 9.6k
	BRGH = 1;		// Set high baud rate
	SYNC = 0;		// Set asynchronous
	SPEN = 1;		// Enable serial port pins
	SREN=0;
	TX9 = 0;		// Disable 9 bit transmission
	TXIE = 0;		// Disable tx interrupts
	RCIE = 0;		// Disable rx interrupts
	TXEN  = 0;      //reset the transmitter
	TXEN = 1;		// Enable the transmitter
	while(1) {
	    TXEN  = 1;
		while(!TXIF) {	// Checks if the transmit flag is down
			continue;
		TXREG = 0b01010101;
flemmard is offline
Old 29th September 2007, 02:12 PM   (permalink)
TX and RX have to be set to input for the UART to work. You should also write to TXREG and then wait for TXIF to be set.
Pommie is offline
Old 29th September 2007, 03:20 PM   (permalink)
Hi, thanks for your reply ! Can you please send me your code if you have some sample?
flemmard is offline
Old 29th September 2007, 03:28 PM   (permalink)
I only use asm on 16F pics but I would guess it would be something like,
#include <pic.h>
void main() {
	TRISC = 0xc0 ; //portC as output
	SREN=0;
	while(1) {
		TXEN  = 1;
		TXREG = 0b01010101;
		while(!TXIF); 	// Checks if the transmit flag is down
Pommie is offline
Old 29th September 2007, 04:56 PM   (permalink)
I am compiling a Problem-Issue Verses Effort-Issue report.
I will incorportate this example as an Effort-Issue.
donniedj is offline
Old 30th September 2007, 07:32 AM   (permalink)
#include <pic.h>
void main() {
	SREN=0;
	while(1) {
		TXEN  = 1;
		TXREG = 0b01010101;
Hi , can you send me your asm code to to test my tx ?
I understand that i can add that asm code directly to my C for compilation
Thanks in advance
flemmard is offline
Old 30th September 2007, 12:21 PM   (permalink)
Thanks in advance
You can check my RS232 PIC tutorial for assembler code.
Nigel Goodwin is online now
First Program in assembly, And Programmer Inchworm. Ayne Micro Controllers 10 9th March 2007 08:27 PM
program for writing and testing circuits luca-deltodesco General Electronics Chat 3 13th August 2006 11:17 AM
little help with my program please - simple count loop kud0s Micro Controllers 5 7th July 2005 10:40 PM
PicBasic Keypad program Sora Micro Controllers 0 20th April 2004 08:02 PM
Program Verify on JMD with ic-prog monkeyxp Micro Controllers 2 2nd November 2003 12:56 PM
