Old 28th September 2007, 05:20 PM   #1
Default mplab sim says running.....
Hi, I'm starting like most people doing a blinky program. I am running some code through the mplab sim to see if my program runs properly and to get a feel for the commands. When the program gets to my delay loop it seems to hit a snag. The sim says running.... and doesn't ever make any progress. Here is my code I imagine I am using the wrong registers for my count1 and count 2, or I have overlooked something else. Thanks for taking a look at my code.
list p=16f628a
#include <p16f628a.inc>
__config _CP_OFF & _WDT_OFF & _PWRTE_ON &
_BODEN_OFF &_INTRC_OSC_NOCLKOUT & _MCLRE_ON &
_LVP_OFF
ERRORLEVEL -302
;*****Set up the Constants****
STATUS equ 03h ;Address of the STATUS register
TRISA equ 85h ;Address of the tristate register for port A
PORTA equ 05h ;Address of Port A
COUNT1 equ 9Ah ;First counter for our delay loops
COUNT2 equ 9Bh ;Second counter for our delay loops
;****Set up the port****
bsf STATUS,5 ;Switch to Bank 1
movlw 00h ;Set the Port A pins
movwf TRISA ;to output.
movlw 85h ;set value of counter
movwf 9Ah ;move to counter folder
movlw 85h ;set value of counter2
movwf 9Bh ;move value to counter folder
bcf STATUS,5 ;Switch back to Bank 0
;****Turn the LED on****
Start
movlw 02h ;Turn the LED on by first putting it
movwf PORTA ;into the w register and then on the port
call Delay
movlw 00h ;Turn the LED off by first putting it
call Delay
goto Start ;go back to Start and turn LED on again
Delay
Loop1
decfsz COUNT1,1 ;This second loop keeps the LED
goto Loop1 ;turned off long enough for us to
decfsz COUNT2,1 ;see it turned off
goto Loop1
return
;****End of the program****
end
jeremy
jeremygaughan is offline
Old 28th September 2007, 05:24 PM   #2
You've used the include file so you don't have to redefine the I/O
Try using
bsf STATUS,RP0 ;bank1
I've got to run for lunch, but will look at your code when I get back.
Also try looking at the Hello World poster on my site (download section)
Bill
Smart Kits build Smart People
Old 28th September 2007, 05:25 PM   #3
hi jeremy,
Dont forget the 'sloooow' execution speed of the program when running in the simulator.
Your delays will seem like forever!.
Use a Variable and some conditional statements in the program delays.
That is when running in sim mode, it skips [dosn't compile] the delays.
When you post your code 'select it' and add the CODE quotes from the menu bar, the source code will keep its format.
EDIT: another quick look,, you are using register addresses that are in Bank1 [for the counters] also these are defined registers, its not the ideal way.
Use General Registers 0x20 up, see Figure 4.2 on the datasheet.
ericgibbs is offline
Old 28th September 2007, 06:01 PM   #4
wow that was a rush. I didn't think I would be that happy to see the program finally work. I used the suggestions that guys submitted and it works perfectly. I'm almost ready to program this chip. Thanks again and here is the code revised.
	list p=16f628a
		__config  	_CP_OFF & _WDT_OFF & _PWRTE_ON & _BODEN_OFF &_INTRC_OSC_NOCLKOUT & _MCLRE_ON & _LVP_OFF
		ERRORLEVEL -302
COUNT1         equ       20h     ;First counter for our delay loops
COUNT2         equ       21h     ;Second counter for our delay loops
    bsf           STATUS,RP0      ;Switch to Bank 1
    bcf           STATUS,RP0      ;Switch back to Bank 0
    movlw	07h		     ;turn off comparators
    movwf	CMCON
Start
    call          Delay
    call          Delay
Delay
    movwf      20h	            ;move to counter folder
    movlw      03h	            ;set value of counter2
    movwf      21h	            ;move value to counter folder
Loop1
    goto        Loop1
    return
    end
jeremy
Old 28th September 2007, 11:42 PM   #5
Nicely done.
Since you've defined your variables COUNT1, COUNT2 you can call them by name.
so
 movwf 21h
can be
 movwf COUNT2
Tip1 for variables (when you have a few)
 cblock 0x20  ; start of variable space same as CBLOCK 21h
COUNT1
COUNT2
x
y
z
endc
Tip2 to reserve a block within a cblock (useful for FSR, or VAR+1, VAR+2)
 COUNT:4  ; block of four COUNT
Bill
Old 29th September 2007, 03:43 AM   #6
I've made a few modifications. I like your advice to use variables. I found that turning on a few lights is be about the same a turning on one light just repeating more of the same program. So I made a little stoplight program and a small stoplight with some leds and a capacitor / resistor for the clock. If you have anymore advice I really appreciate it. Thanks again for the guidance.
	list p=16f628a
		ERRORLEVEL -302
	cblock     20h               ;establish variables
	x,y,z
	endc
    movwf	   CMCON
Start
	movlw     01h                ;Turn the red LED on by first putting it
    call      Delay
	call      Delay
    movlw     00h                ;Turn all LEDs off by first putting it
  	movlw	  02h 				 ;Turn on green led
	movwf	  PORTA				 ;
	call      Delay
	call      Delay
	movlw	  00h				 ;turn off all leds
	movwf	  PORTA
	movlw	  04h				 ;turn on yellow led
	movwf	  PORTA
	call      Delay
	movwf	  PORTA
Delay
    movwf	  y    	             ;assign to varible y
Loop2
	movlw	  10h                ;set value of counter
    movwf     x     	         ;assign to varible x
Loop1
    decfsz    x,1                ;This second loop keeps the LED
    goto      Loop1              ;on for a moment
    decfsz    y,1
    goto      Loop2
    return
    end
jeremy
Old 29th September 2007, 09:10 AM   #7
hi jeremy,
If you use the MPLAB simulator to step thru your program, you may find 'conditional assembly' useful on many occasions
when writing programs.
Have edited your delay subr and added two lines near the top.
It will run in the simulator as it is now.
By changing the Sim1 to '0' or '1' you will see the effect, after you assemble/build, as you step thru the program.
I would suggest that you give the CBlock variables more meaningful names, x,y,z single character will be difficult to keep track
of in your head.
eg: del_cnt1, del_cntr2, asc_bfr3 etc...
	list p=16f628a
	ERRORLEVEL -302
;add these two lines of text
	Variable Sim1
Sim1 SET .1	;if '1' its running in the Simulator, else '0'
	x,y,z
	endc
;Your Source here...........
;test only
lp1: call Delay
	goto lp1
;Running a program with long delays in the Simulator can be 'slow'
;by adding a Variable say, Sim1 and setting it to either '0' or '1' and then
;testing that Variable during assembly will direct the assembler to
;generate code that gives a shortened delay for Simulation
;or the required delay for a PIC.
Delay:
	if Sim1 == 0x01		;assembler conditional assembly
	movlw 	.1		;this is for the Sim, just 1 loop
	else
	endif
Loop2:
	if Sim1 == 0x01
	else
	endif
Loop1
    	decfsz    y,1
    	goto      Loop2
    	return
    	end
Old 29th September 2007, 05:35 PM   #8
To have an understanding of how we know these tips like CBLOCK, first get familiar with Chapter 4 of the MPASM data sheet http://ww1.microchip.com/downloads/e...Doc/33014J.pdf
donniedj is offline
mplab, running, sim
reprog-16f84a - failed lemonyx Micro Controllers 6 25th August 2007 04:32 AM
Debugging 877A with MPLAB williB Micro Controllers 10 7th May 2007 04:53 PM
Need help badly on Inchworm and MPLAB thushy Micro Controllers 14 11th March 2007 07:05 PM
Some Question About Inchworm Ayne Micro Controllers 29 7th March 2007 04:08 AM
Inchworm project started williB Micro Controllers 69 5th March 2007 07:56 PM
