Old 26th September 2007, 05:15 PM   (permalink)
Default Powering Pic16F84A
I have just finished a project using PIC16F84A micro. my project runs using computer power supply of 5 volts. but when I used 4 pcs. 1.5V battery the project don't work properly. I tried this site (http://www.talkingelectronics.com/ht...A-Project.html) but it doesnt work. Can you help me how I will do it?
paparts is offline   Reply With Quote
Old 26th September 2007, 05:19 PM   (permalink)
Which type of battery are you using? standard alkaline or rechargeable and do you have a diode in battery connections>
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now   Reply With Quote
Old 26th September 2007, 06:56 PM   (permalink)
Default Re:Powering PIC 16F84A
I' using a carbon zinc battery. I followed the 6 to ~5.3v conversion given by the poptronics site. I used the 1N4002 diode.
Old 27th September 2007, 02:03 AM   (permalink)
Remove the PIC from the picture.
1. Measure the voltage of each cell.
2. Measure the voltage of the combined cells.
3. Connect diode and measure the combined voltage again with diode.
4. Attach a resistive load which will draw equal amounts of current expected from the PIC.
5. If you have a scope, monitory any ripples.
6. If resistive load pulls desired current and battery supply maintains proper voltage and ripple, then you can now scratch the new supply off the list of faults.
Swap PIC in question with another known good.
Get back to me when these are done.
donniedj is offline   Reply With Quote
Old 27th September 2007, 11:14 AM   (permalink)
Default Re:
Does the type of battery matter? whether it is an alkaline or a carbon zinc?
Old 27th September 2007, 11:17 AM   (permalink)
Only in that normal batteries are crap! - they don't last long under any sort of load, and under a heavy load may drop too low to use.
Old 27th September 2007, 11:31 AM   (permalink)
Default Re:
What if I'l get less of 5.5V with the battery ? Does current matter? How do I measure the ripples? What I have here is just a multitester.
Old 27th September 2007, 11:36 AM   (permalink)
What are you feeding from the battery?, and presumably you've got an electrolytic across it?.
Old 27th September 2007, 11:41 AM   (permalink)
Its just possible that the problems are not caused by the battery supply.
As we have no circuit to guide us, do you have any decoupling capacitors on the circuit board??
Is the battery/power supply, powering other devices in addition to the F84 PIC?
Do you have a PIC reset switch for the PIC? and/or a switch from the battery to the PIC supply???
Can you post a circuit?
Eric
PIC tutorials:
Old 27th September 2007, 11:42 AM   (permalink)
Default Re:
from this link(http://www.talkingelectronics.com/ht...A-Project.html) I used the 6 to 5V conversion.
Old 27th September 2007, 11:43 AM   (permalink)
No, we need to see the rest of the circuit!
Did you see my questions in my last post
Eric
PIC tutorials:
Old 27th September 2007, 11:56 AM   (permalink)
Default Re:
sorry i did not see what you post previously. Yes the battery is powering 2-LM741 for my line follower and 555 for my siren and the motor driver
Old 27th September 2007, 12:11 PM   (permalink)
OK,
Can you answer these questions?
It may seem we are asking lots of questions, but without your answers we cannot give the best advice.
You may know your project, but we dont.
Eric
PIC tutorials:
Old 27th September 2007, 01:56 PM   (permalink)
Default Re:
Here is my ckt. diagram
2 PIC16F84A using only 1 Xtal..? AntRoFiZ Micro Controllers 5 15th May 2007 04:01 PM
Need help 3x4keypad to PIC16F84A microcontroller juan12345 Electronic Projects Design/Ideas/Reviews 2 4th August 2006 12:16 PM
Access to configuration word of PIC16f84a folarinv Micro Controllers 3 19th December 2005 07:43 PM
PIC16F84A INTERFACE WITH MSM6242BRS(PLS HELP ME) Jay Duluguin Micro Controllers 9 18th February 2004 04:19 PM
How to Demux I/O of PIC16f84A? nenayd Micro Controllers 3 22nd October 2003 09:58 PM
