| hi paparts, My first reaction is that circuit will not give reliable operation with 6Volt Bty pack of ZiC batteries, especially with the diode in series with the battery. The motors must pull down the battery voltage below the safe working voltage of the PIC, also the 555 is driving an 8 You need a more heavy duty battery pack with a voltage regulator. Thats why the project works OK on a bench power supply.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 27th September 2007 at 03:56 PM. | |
| It's similar to my Mongoose robot kit. I'm using 4xAA NiMH 2300MAh batteries and 470uf caps on both the H-Bridge (I use a CD754410) and it works fine. | |
| So what can u suggest? | |
The OP says he is using Zinc Carbon batteries, which have a low specification. Paparts.. Why not try the battery type/rating that Bill uses, it should be fairly easy to substitute NiMH for Zinc batteries. Also add the bridge capacitors.
| Can I ask for the diagram? I could not find the specs of CD754410 | |
I cant find the CD754410 data ? Have you tried a NiMH battery pack??
| Have'nt yet maybe tomorrow coz its night time here. Ill give you an updtae on how I will solve it if ever. I have an idea using LM7805 a voltage regulator. My friend used a voltage regulator and it went well. | |
| 1. How far it would be proper to drive BD436/436 transistors from thr port pins of PIC16F884 without even base current limiting resistors? 2. Whether the PIC cant be tried at 4.5V which is amounts to use three cells 3. After somuch extensive circuitry and anticipated load current , perhaps it would be appropriate to use a 6V lead acid battery of 2 or 3AH capacity and try using LDO regulator for supplying the PIC.
| | (permalink) | |||
| Hi, Nigel, I was aiming these comments on the schematic posted by Paparts on 27th instant.
| google cd754410 or l293d same pinout. The l293 might be easier to find, it'll work with small dc motors up to 600ma (the cd745510 will handle 1.2a) Carbon Zinc batteries have a much different discharge curve than NiMH. Plus NiMH AA are about 1.2v per cell so four will give you 4.8v fully charged. | |
| Li-Ion cells are somewhat expensive and require an exotic charger to keep from exploding. They hate being abused and a short might anger them (see explode, fire etc...) NiMH are common and more forgiving. PS the OP seems to be having a difficult time giving up on the Carbon Zinc cells. | |
| 2 PIC16F84A using only 1 Xtal..? | AntRoFiZ | Micro Controllers | 5 | 15th May 2007 05:01 PM |
| Need help 3x4keypad to PIC16F84A microcontroller | juan12345 | Electronic Projects Design/Ideas/Reviews | 2 | 4th August 2006 01:16 PM |
| Access to configuration word of PIC16f84a | folarinv | Micro Controllers | 3 | 19th December 2005 08:43 PM |
| PIC16F84A INTERFACE WITH MSM6242BRS(PLS HELP ME) | Jay Duluguin | Micro Controllers | 9 | 18th February 2004 05:20 PM |
| How to Demux I/O of PIC16f84A? | nenayd | Micro Controllers | 3 | 22nd October 2003 10:59 PM |
