Old 24th September 2007, 12:21 PM   (permalink)
Default Problem with multiple ADC using pic16f877
Hello everyone, I have encountered the problem of using dual/multiple ADC inputs into PIC. I am using 2 ADC channels and outputting the result onto a LCD. The output that I receive is always that for the PORT with the higher pin (eg. If I am using pin RA1 & RA0, only the conversion of RA1 is received in my LCD display) There seems to be an overwrite of the RA1 over RA0. This problem persist when I am using different input pins.
The below mentioned is the code for ADC reading and initialisation. :
Thank you for your help.
void ADC_init() // for init of ADC
ADCON1=0x82;
TRISA=0xff;
int read_ADC_channel(unsigned int channel_number) // for reading
int value;
switch(channel_number)
case 0:
ADCON0 = 0b01000011;
case 1:
ADCON0 = 0b01001011;
default:;
DelayMs(1);
ADGO=1; //start AD conversion
while(ADGO) //wait for conversion to finish
value=(ADRESH<<8)+ADRESL; //read the values in the registers
return(value);
andyto is offline
Old 24th September 2007, 12:24 PM   (permalink)
You might try reading my tutorial about the ADC, it explains a number of potential problems - in particular that of the source impedance that's feeding the ADC - in your case you're not allowing much time for the sample and hold to charge/discharge, so you better have a really low source impedance?.
Old 24th September 2007, 12:35 PM   (permalink)
Try this:
case 0:
break;
case 1:
break;
Does it work?
eng1 is offline
Old 24th September 2007, 12:43 PM   (permalink)
Hi, thank you for all your prompt reply,
I did actually included a break in between:
DelayMs(1);
This will delay for 1 ms which I think should be more than sufficient for anything, I even try up to 10 sec and it's still the same.
As for impedance, I have measured it and its aound 1kohm, so not that high too.
andyto is offline
Old 24th September 2007, 01:02 PM   (permalink)
DelayMs(1);
Where exactly? can you post the code?
You have to place a break after each case.
eng1 is offline
Old 24th September 2007, 01:04 PM   (permalink)
DelayMs(1);
Please post your circuit diagram, and explain how you 'measured' the source impedance.
Old 24th September 2007, 01:11 PM   (permalink)
Thank you, I didn't notice that I miss that out. Thanks a million, eng1!
andyto is offline
Old 24th September 2007, 01:12 PM   (permalink)
I use a mulitmeter one end to my LDR and the other end to gnd, not sure if it is the correct way of doing it.
andyto is offline
Old 24th September 2007, 01:19 PM   (permalink)
It's not - so you're feeding an LDR directly to the ADC input? - this is MUCH too high a source impedance. Do you have the same on each analogue input?.
And why are you trying to read it every millisecond?.
Old 24th September 2007, 01:38 PM   (permalink)
I have it on 2 inputs. Will they sort of cross interferw with each other?
andyto is offline
Old 24th September 2007, 01:52 PM   (permalink)
What do you mean?, post a drawing of how it's connected.
Old 24th September 2007, 01:54 PM   (permalink)
Are you biasing the LDR somehow? One usually connects the LDR in series with another resistor and senses the voltage in the middle. An op amp buffer should be used to change the impedance for the ADC. See attached schematic.
File Type: png ldr.png (1,000 Bytes, 10 views)
eng1 is offline
Old 24th September 2007, 02:22 PM   (permalink)
The type of LDR I have is a 3 pin type (1 to gnd, 1 to Vcc and the other is the Vout) acts like a potentiometer.
Eng1's break statement has helped me solve one wierd problem which is why the value duplicates, my mistake in programming. However, another problem surfaced.
Now, input 1 RA0 works perfectly fine. But I am getting no reading from RA1, which has the same input circuit as RA0, even if I unplug and plug it into the RA0 circuit the reading is still 0.
Below is my full code. Your help is greatly appreicated.
#include <pic1687x.h>
#include "delay.c"
#include "lcd.c"
#include <stdio.h>
int value;
case 0:
break;
case 1:
break;
default:;
DelayMs(1);
ADGO=1;//start AD conversion
while(ADGO)//wait for conversion to finish
return(value);
void main()
char myStr[]="12345";
int myInt;
ADCON1=0x82;
TRISA=0xff;
TRISC =0b11000000;
TRISD = 0;
lcd_init();
while(1){
myInt = read_ADC_channel(0);
sprintf(myStr,"%4u",myInt);
lcd_goto(0);
lcd_puts(myStr,0);
myInt = read_ADC_channel(1);
lcd_goto(0x40);
lcd_puts(myStr,0);
andyto is offline
Old 24th September 2007, 02:33 PM   (permalink)
Somehow I got it solved, simply by using RA2 instead of RA1. I am not sure why is this happening. Anyone has similar experience before?
andyto is offline
Old 24th September 2007, 11:37 PM   (permalink)
I remember on the 876A that if you were using multiple porta pins for analog or digital I/O that some combinations of analog and/or digital I/O on certain pins was not possible. Basically they gave you 5 bits in a register to set what all 8 pins were (A or D). 5 not enough Might check the data sheet. Found that one out the hard way.
speakerguy79 is online now
16F877 Timer0 Interrupt Affecting ADC sebana Micro Controllers 13 12th September 2007 10:43 AM
PIC16F877 general purpose RAM problem mysteyboyk Micro Controllers 13 10th July 2007 04:37 PM
multiple touch switch problem sstimuluss Electronic Projects Design/Ideas/Reviews 3 15th January 2007 03:03 AM
pic16f877 ram problem osmandemirci General Electronics Chat 1 28th November 2006 04:11 PM
PIC16F877 ADC Problem All values the same Theodoros Micro Controllers 10 2nd June 2005 07:33 AM
