| Hello, I am working on my graduation project which will be using RF transmitter and receiver to move data between circuits. What i want to do is use the transmitter to send the robot directions like Up,Down,Left,Right each on differant channel or in the same channel but as a binary number, eg: 1010 or 1001 as MSB is the Up and LSB is Right. My question is when i want to send a group of bits during 20ms using the transmitter/receiver pair, How do i code the microcontroller to save the bits i receive within a certain amount of time in an array so that i can later decode them using code and detect the output pins that should be set to high and the ones set to low? ex: if i send 1001 i will want to receiving end to move the robot forward and right. How can i receive the 1001 bits and interpret them to know the exact pins that should get the output. I know it is more of a job for the Encoder/Decoder but i also know that it can be done using Microcontroller. Please guide me to the corret way of doing this. Regards, Rakan | |
__________________ Superman returns.. | |
| you dont need to do those things.. encoding and decoding... there are already chips available to do this.. all you have is to simply interface.. which is very easy.. [b]Follow the link given by ' Banana Siong ' in the above post...[\b] it is a very good tutorial... Regards, Simran..
__________________ Simran.. 8051 Specialist.. Last edited by simrantogether; 24th September 2007 at 06:55 AM. | |
| Capturing serial data using PIC24 | nick2412 | Micro Controllers | 3 | 12th March 2007 10:32 PM |
| Need some help with a code provided by ATMEL | ikalogic | Micro Controllers | 1 | 23rd January 2007 03:46 PM |
| Hardcode a PIC by hand? (or 16F74 + par.port.prog = problem) | smilen | Micro Controllers | 15 | 21st November 2005 10:23 AM |
| Just Joined, Got some bugs I can't find. | Thedoctorisin136 | Micro Controllers | 0 | 1st March 2005 07:07 PM |
| An error in pic16f84a, why? | Zener_Diode | Micro Controllers | 6 | 11th April 2004 03:55 AM |
