Old 21st September 2007, 04:28 PM   (permalink)
Default Checking a Stepper without a Driver
Is there any possible way of just checking out if a stepper motor works or not without using a driver/controller? I dun want the motor to rotate.. it could just budge a little to indicate that its working fine...
baberjaved is offline
Old 21st September 2007, 04:52 PM   (permalink)
A battery (I use a PJ996 6V one), and two wires - you can also work out which wire is which.
Old 21st September 2007, 09:49 PM   (permalink)
yeah Thanks... it budged! =D
Old 21st September 2007, 10:17 PM   (permalink)
Now go round the rest of them, and find out what sequence you need to make it rotate.
Old 24th September 2007, 02:45 PM   (permalink)
I just finished making the L298/L297 Circuit for a Bipolar 2-Phase stepper motor... But before hooking it up with my microcontroller circuit i want to check n make sure the circuit is working fine... How do i check it and what should be the voltages on the output of the L298 and what should be the voltages on the Clock,Enable,CW/CCW and Reset pins of the L297...
I connected the chips to 5V and the Vdd of L298 to 30V and I am getting around 6V on the above mentioned pins of the L297 (It would be safe to connect it to a uC?) and on two outputs of L298 I am getting 0V and 17V on the other two...
Why 17V? Should it be this way...?
Secondly i wanted to know which wires of the stepper motor would go into the four outputs? Does the order matter... as when i change the configuration the voltages on the output change....
Old 25th September 2007, 08:33 PM   (permalink)
Here's the circuit.. Is something wrong or missing?
What should be the output on the four outputs of the L298?
Old 24th November 2007, 01:52 PM   (permalink)
Post
hey, please go through these links and directly apply 6V battery to the motor to check whether its working or not......
http://www.silabs.com/public/documen...s/en/an155.pdf
Also, u may find out which wire is which, please check out the link below:
http://www.doc.ic.ac.uk/~ih/doc/stepper/others/
best regards,
- Muhammad Zubair Bhamani
muzubair is offline
UCN5804B stepper motor driver into proteus sallama Electronic Projects Design/Ideas/Reviews 2 27th June 2007 03:01 AM
I need a stepper motor driver! tj107us General Electronics Chat 8 9th February 2006 11:43 PM
Need Help Driving Stepper Motor using MC3479p Driver Freak-A-Nature Electronic Projects Design/Ideas/Reviews 1 10th December 2004 02:44 AM
Stepper Motor Driver zhizhi16 Electronic Projects Design/Ideas/Reviews 1 29th April 2004 09:35 PM
Reversible stepper motor driver mattg2k4 Robotics Chat 10 11th November 2003 06:06 PM
