| Does anyone know a technique for removing the white 'plugs' from the plastic case that microcontrollers come in? they really do my head in Cheers | |
| Use sidecutters to pull them out, place the cutters under the head and squeeze gently, then just lever back and pull the plug out. | |
| buy tweezers which come with a handle.. it is also sometimes called ' PLAS'.. i can say.. its shape matches with .. a pair of scissors.. Regards, Simran..
__________________ Simran.. 8051 Specialist.. | |
| Instead of putting the white pins back I snap a rubber band along the length of the tube so it runs over the open ends, keeping the chips/sockets in. The down side is the rubber over time will age, die, and dump the contents if you do not spot it. How long depends on what is in you air. I like the foam plugs the best. | |
| OK thanks. | |
| I use my teeth usually, really.
__________________ Superman returns.. | |
| I use a argon laser with a 75Watt output hooked up in series with a flux capacitor... Oh sorry back on track (I was daydreaming), is it really that hard? I find this funny! | |
| For a second I thought the plugs were for SMT package tubes, for these are easy and cause no agrivation. Now for DIP packages or through holes, Join the league of Teeth Users like me | |
| Yeah, I had resorted to that a few times. Its not a very pleasent to subject your teeth to though The sidecutters work nicely, but only if theyre to hand | |
| I dont see why they cant just allways use the little rubber stoppers, bunged in either end. | |
| hey.. use this.. try atleast once.. i hope you'll try it again.. ![]() just push from a back a bit.. and extract with this tool..
__________________ Simran.. 8051 Specialist.. Last edited by simrantogether; 21st September 2007 at 01:39 PM. | |
| dont go for using teeth.. believe my advice..
| dont use teeth for this purpose.. believe my advice..
| replacing plastic circuits in mobile phone | catnipsta | General Electronics Chat | 4 | 17th April 2007 06:27 PM |
| Plastic Heat Sinks? | lord loh. | General Electronics Chat | 7 | 8th May 2006 09:46 AM |
| Plastic Enclosures (Rant) | DirtyLude | General Electronics Chat | 14 | 30th November 2004 03:07 AM |
| Plastic Enclosure Help | brentonw2004 | Electronic Projects Design/Ideas/Reviews | 22 | 22nd December 2003 07:54 AM |
| Custom plastic enclosures. Need help please! | Electric Rain | General Electronics Chat | 4 | 27th November 2003 10:58 AM |
