| Hello everyone. I'm just wondering if I can use a type K thernocoupler direct with any PIC. Thanks | |
| Almost certainly not, you need to amplify the output a LOT to make it large enough. | |
| sinc k-type has a range of (-200 °C to +1200 °C) as per: http://www.picotech.com/applications/thermocouple.htm l you may use PT-100 if its range is suitable ( -200°C to +850°C ) see : http://www.maxim-ic.com/appnotes.cfm/an_pk/3450.
__________________ Its what your friend in Your mind, what you in your friends mind | |
| If you want quick and dirty, a simple opamp to amplify the signal will work enough to give a PIC's ADC something to work with. But you better be a damn good programmer and signal analyst to make any degee of precision from it.
| Thank you for your fast reply. I read somewhere (I don't recall...) that there's a pic that can handle type k thermocouple. I searched on "www.microchip.com" but nothing there about this subject. Anyone knows about it? | |
| The MAX6675 is probably the easiest/most accurate way of using a K type with a microcontroller. http://www.maxim-ic.com/quick_view2.cfm/qv_pk/3149 | |
__________________ Regards, Sarma. Last edited by mvs sarma; 7th July 2008 at 11:22 AM. | ||
__________________ Its what your friend in Your mind, what you in your friends mind | ||
| It is downloaded from www.microchip.com directly
| There are ADCs like the LTC2418 that handle thermocouples fine. A normal op-amp won't work well no matter how good a programmer you are! The problem is offset, thermocouple inputs are so small that common opamp offsets might make hundred of degrees F of error. Second thing here- is this thermocouple grounded? It's ok to do that, not only we can bolt both wires to a grounded cylinder head, in fact a thermocouple can even measure a temp on a grounded hot plate by bonding one wire at one point and the other wire at a different point! But this means one voltage is slightly above ground, the other slightly below, so we need to be able to measure slightly below ground AND we need to be differential.
| K type | chandu13 | Micro Controllers | 11 | 30th March 2007 03:27 AM |
| help on inductor design for buck type dc-to-dc converter | markking | General Electronics Chat | 15 | 15th December 2004 04:37 AM |
| various type of capacitor | yuenkit | Electronic Projects Design/Ideas/Reviews | 1 | 1st December 2004 05:16 PM |
| Electric motor as a generator, DC type? | Johnson777717 | General Electronics Chat | 5 | 23rd June 2004 10:13 PM |
| Cap Type for 555 timer | Screech | General Electronics Chat | 4 | 13th January 2004 12:32 AM |
