Old 15th September 2007, 07:24 AM   (permalink)
Default Advice on MPLAB v7.40 please
I have MPLAB v7.40 and have written many successful programmes, but I would like to know if there is an easier way to create a new project than the following:-
Select Project/New
Enter project name eg. "test"
Click on "Browse" and select a folder.
A small window "test.mcw" appears with a folder "test.mcp" and several sub folders such as "Source files".
So far so good.
But how do I start a source code file?
I've tried various methods to achieve this end, but the only one that works is as follows:-
Click on the "New file" icon in the Toolbar.
A window appears "MPLAB IDE Editor" with "Untitled" in the top left corner.
I then type in the code.
But if I press button F10 to assemble, a "Save as" window appears, so I type in the file name, eg. "test" and click on
"Save".
The following message appears:-
"Build aborted. The project contains no source files"
However, the "Untitled" tag changes to "test.asm".
Now if I right click on the "Source file" folder in the "test.mcw" window and add the "test.asm" file, I can press F10
and then the code will assemble successfully.
This seems to be a clumsy procedure, is there a simpler method?
Any advice will be appreciated.
Len
ljcox is offline
Old 15th September 2007, 07:45 AM   (permalink)
Len,
Try Projects/Add new file to project... and type filename.asm in the box.
This is in version 7.6 but I think it was the same in 7.4
Pommie is offline
Old 15th September 2007, 08:42 AM   (permalink)
I find it easier to create a new folder for my project, copy a template asm file for my microcontroller to there and rename it to suit my new project.
Then open mplab, create a new project, browse to my new folder and add my asm file to the project.
That ensures that my new asm files will have a standard header etc. at the start.
picasm is offline
Old 15th September 2007, 10:28 AM   (permalink)
Default Add, that simple!
Add file to project, as Pommie says.
Just in case, I still work in absolute mode (no flaming please!).
In my case, I have another 15 to 20 files INCLUDEd in that one.
Agustín Tomás
In theory, there is no difference between theory and practice. In practice, however, there is.
atferrari is offline
Old 15th September 2007, 12:57 PM   (permalink)
I prefer using the Project Wizard as it presets the processor type, language toolsuite, file/folder locations, etc. Then I "open" an existing template 'asm' file, do a "save as" to the new project folder, and "add file to project". The whole process takes less than a minute.
Good luck. Mike
Mike, K8LH is offline
Old 15th September 2007, 01:39 PM   (permalink)
Good luck. Mike
This is way I also start a new project, then open the source window and add a suitable header file.
I know that the templates for each PIC can be found in the MPLAB folders, but I prefer to use my own header file as it has my include files and other details.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 15th September 2007, 04:07 PM   (permalink)
From the open asm. file you can select Project-Quickbuild(your filename) and that's it, i always only use Quickbuild.
OY2L is offline
Old 16th September 2007, 10:40 AM   (permalink)
Thanks for the advice.
I decided to use the method posted by Mike and Eric, ie. use the Wizard.
I discovered that at Step 4, I can copy the template and then change its filename, which is what I expect Mike meant by "save as"
Len
ljcox is offline
Inchworm Problem mouse9911 Micro Controllers 9 19th May 2007 01:01 AM
Debugging 877A with MPLAB williB Micro Controllers 10 7th May 2007 04:53 PM
Need help badly on Inchworm and MPLAB thushy Micro Controllers 14 11th March 2007 07:05 PM
Some Question About Inchworm Ayne Micro Controllers 29 7th March 2007 04:08 AM
Inchworm project started williB Micro Controllers 69 5th March 2007 07:56 PM
