I'd like to try an attiny2313. Could anyone recommend a suitable DIY programmer? Thanks
please try at http://www.ikalogic.com/isp.php there is a link for isp prog software there on the site it supports ATTINY2313 perhaps you may arrange for chip size based socket or some how extend the ISP relted 5 wires and it can programm insitu. take precautions on cable length to be short and power supply properly filtered. i use this programmer, and haven't used the buffer chip even. as you know the device needs its crystal and related capacitors. this infocan be had from the datasheet of ATTINY2313. All the best
Regards, Sarma. |
One would also need a software running on the PC to control the programmer.
You can try the famous PonyProg, with the following parallel port interface. AVR ISP (STK200/300) parallel port interface
L.Chung |
AVR has a dragon board for $49. That and pull the AVRStudio, and have a really nice setup able to handle about all the Atmel people have.
It all works great. I have used the Tiny13 and Tiny2313 with no problems. For $50 (US) it is hard to justify building one. But if you google I did find and built one that did not work for the Tiny11. |
Thank you very much for your replies. I am retrieving all information I might need to start programming the 2313, so I'll probably be back with other questions
Thanx U It Also Help Me Lot
Blatent advertising deleted - Moderator!. |
http://www.instructables.com/id/Ghet...ith-AVR-micro/ Think this is the simplest/cheapest programmer I've run across. Never even thought about trying it, but have seen it mentioned on several other sites, so probably works. |
