| Experienced Member | I agree with you as far as the range is concerned. But there are combinations of the two resistors that can't switch the transistor off. |
| Experienced Member | Quote:
What does Open Collector mean anyway? Will a BC548 do? so I would take the line from pin 5 and run it via a 10K resistor to the Base of the NPN, then connect a 10K from the Emitter to the Base, do I then take the output from the collector and run that to where the buffer out put is?
__________________ "The glass is neither half-empty, nor half full, it's just twice as big as it needs to be" - Unknown | |
| Super Moderator | Quote:
| | (permalink) | |||
If you check my PIC tutorials (Hardware Extras) there are some examples of using transistors for it, which you could use for your buffer. Quote:
| | (permalink) | ||
I hope you'll have your programmer working! Last edited by eng1; 13th September 2007 at 01:27 PM. | ||
| Experienced Member | Bugger, bugger, bugger. I lost the pad for the buffer out put when I was trying to desolder the pin ( I dont know how because i dont think it was heated excessively), but that doesnt matter..... with the lost pad i connected my programmer up to the computer, still the LED remained lit, however much dimmer this time. with the collector of my ghetto inverter connected to the 10 K resistor that came off buffer 4 the LED was brighter again, but unresponsive to the programming softwares "commands" ( I have been using the chech feature) what now?
| Experienced Member | Update, almost got it, i made a mistake with the pin, i accidently used clock pin 3, but i fixed that, now the led is dim when VPP is dissabled, and bright when its enabled (looks like i almost have it). however it still is returning errors, and isnt programming, could this be due to the VPP voltage which now sits on 1.9V when VPP is disabled... what do you think?
| Experienced Member | Nigel, I've edited my previous post. Can you give your comment please? Thank you. |
| Experienced Member | Someone electro had me tie VPP to ground via a 10K, that brought it down to 1.88 and i added a further 1K so now its sitting at 1.8V, almost there, but i dont know if thats a proper solution.
| Experienced Member | What's the voltage on the input of the "ghetto" inverter when the VPP LED is dim? You may want to add a 10K resistor from the base of the "ghetto" inverter transistor to ground if this voltage is above 0.4V
__________________ --- The days of the digital watch are numbered. --- Last edited by kchriste; 14th September 2007 at 02:19 AM. |
| New Member | Hi, sorry to ressurect such an old thread, but I'm facing pretty much the same problem as the original poster. Whenever I turn my programmer on, the Vpp raises to 11.66 volts and sits there forever. I'm using a custom built tait-style programmer, using the 74HC14 chip. I've already tried changing to 74HC05 but got no luck. Should I also try with the 74hc06 or 74hc07 chips as suggested back in this thread? Would that make a difference? Thank you, Cesar |
| Experienced Member | Why would a design use 7406 or 74LS06 when so many new IC or CMOS inverters are available? You think so too? Because there is a reason. The circuit needs the open-collector feature of these "old" IC to properly drive the transistors. If you don't know that, don't try to change these IC types. Countless builders have fallen in the same trap.
__________________ L.Chung |
| mclr pin problem for pic16f877a | neelam29 | Micro Controllers | 6 | 7th February 2007 01:04 PM |
| Sudden problem with MCLR on PIC16F628 | Futterama | Micro Controllers | 16 | 15th October 2005 02:04 PM |
| faulty digital components testing,checking | walters | General Electronics Chat | 5 | 22nd August 2005 07:10 PM |
| Question about MCLR pin with Pro40 | cubdh23 | Micro Controllers | 9 | 10th October 2004 08:57 AM |
| Need of resistor to MCLR? HURRY! | brodin | Micro Controllers | 3 | 21st February 2004 12:07 PM |
