Old 6th September 2007, 10:39 PM   (permalink)
Default Program issues
First of all, thanks for the previous help with this program to all who took the time. I would not bother you again with the same program, but I am stumped.
The program runs fine, outputs work. Not sure about the A/D working though. I had originally set up AN3 to get the delay value that is decremented. It was not working apparently, so I just put in a value in the code for "Delay".
The problem is that no matter what I set the value at, the delay I actually see on the LEDs is always the same, and only changes with the prescalar on Timer0. I tried changing the RAM address of "Delay" to 0x0022 from 0x0020, did not help. I am at a loss here. The program runs exactly as it should otherwise. The thing that puzzles me is that Delay is being decremented somewhere, as the program will not continue to the next LED until is is 0. Unless it never had a value to begin with and is always 0?
http://h1.ripway.com/AmbientSix/Strobe.txt
EDIT: I am not sure how to make the text file open in the post, when I just copied it the format was awful.
Ambient is offline
Old 6th September 2007, 11:37 PM   (permalink)
List p=12f683
include P12F683.INC
__CONFIG _FCMEN_ON & _IESO_OFF & _CP_OFF & _CPD_OFF & _BOD_OFF & _MCLRE_ON & _WDT_OFF & _PWRTE_OFF & _INTOSCIO &_INTRC_OSC_NOCLKOUT
errorlevel -302 ; suppress message 302 from list file
w_temp EQU 0x7E ; variable used for context saving
status_temp EQU 0x7F ; variable used for context saving
Delay EQU 0x0022
Done EQU 0x0021
red EQU b'00000001'
wht EQU b'00000010'
blue EQU b'00000100'
;*****************[code]***********************************
org 0x0000
goto INIT
NOP
NOP
NOP
org 0x0004
GOTO ISR
org 0x0005
INIT
BSF STATUS,RP0 ;selects memory Bank 1
MOVLW b'01000001'
MOVWF OSCCON ;sets oscillator to 1MHz
MOVLW b'00000000'
MOVWF OPTION_REG ;enables Timer0, 1:4 PS (1.024ms/overflow)
MOVLW b'10100000'
MOVWF INTCON ;enable GIE, Timer0 interrupt
MOVLW b'00000111'
MOVWF CMCON0 ;disables comparator
BCF STATUS,RP0 ;selects memory Bank 0
CLRF GPIO
BSF STATUS,RP0 ;Bank 1 selected
MOVLW b'00011000' ;GP0,1,2,5 as outputs, GP3,4 as inputs.
MOVWF TRISIO ;GP3,5 are for future add-ons.
MOVLW b'00010000' ;GP4 analog input enable, FOSC/2
MOVWF ANSEL
MOVLW b'10001101' ;right justify, VDD ref, AN0, ADON
MOVWF ADCON0
BCF STATUS,RP0 ;Bank 0 selected
MOVLW h'0009'
MOVWF Delay
START
CLRF TMR0
; BSF ADCON0,ADON
; BSF ADCON0,GO ;get A/D data for "Delay" variable
; BTFSC ADCON0,GO
; GOTO $-1
; MOVF ADRESL,W
; MOVWF Delay
; BCF ADCON0,ADON ;disables A/D till next use.
;==================RED=========================
RedON
BCF Done,h'0000'
MOVLW red
MOVWF GPIO ;turns red LED on.
BTFSC Done,h'0000' ;tests for decrementing complete
GOTO WhtON ;executed when complete
GOTO $-2 ;executed when not complete
;==================WHITE========================
WhtON
BCF Done,h'0000'
MOVLW wht
MOVWF GPIO ;turns white LED on.
BTFSC Done,h'0000'
GOTO BlueON
GOTO $-2
;==================BLUE=========================
BlueON
BCF Done,h'0000'
MOVLW blue
MOVWF GPIO ;turns blue LED on.
BTFSC Done,h'0000'
GOTO START
GOTO $-2
;*********************ISR************************
ISR
movwf w_temp ; save off current W register contents
movf STATUS,w ; move status register into W register
movwf status_temp ; save off contents of STATUS register
BCF INTCON,T0IF
DECFSZ Delay,F
GOTO CONTEXT ;If not done decrementing, returns to current loop
MOVLW h'0001'
MOVWF Done ;done decrementing, places h'1' in "Done" register
GOTO CONTEXT
CONTEXT
movf status_temp,w ;retrieve copy of STATUS register
movwf STATUS ; restore pre-isr STATUS register contents
swapf w_temp,f
swapf w_temp,w ; restore pre-isr W register contents
retfie ; return from interrupt
END
Ambient is offline
Old 7th September 2007, 02:44 AM   (permalink)
You have initially set the delay value to be '9'. In the ISR, you have:
DECFSZ Delay,F
MOVLW h'0001'
GOTO CONTEXT
When the content of 'delay' is decreased until 0, bit 0 of Done is set, at the same time, the delay time should be restored. Otherwise, the next round the program entering the ISR, it will decrement the delay from 0, but not from 9.
DECFSZ Delay,F
MOVLW h'0001'
movlw 0x09    ;add these 2 lines
movwf Delay
GOTO CONTEXT
Besides, I suggest you to use rotate to switch the LED since you're turning on only one LED each time.
Good luck
Superman returns..
bananasiong is offline
Old 7th September 2007, 04:06 AM   (permalink)
Dumb mistake, again. It seems to work now. I will see if the A/D works for getting the value. Since the value will be changing I will just make two variables, Delay and DelayTemp, with the latter being the only decremented one.
Rotate is an great idea that I did not think about, but I may change the pattern in the future. I have to leave it as is if I decide on another pattern. There are other ways that I can reduce the code as well, but I do not need to, as the PIC has only the job of turning LED's on and off.
Thanks for your help.
Sean
Ambient is offline
Old 7th September 2007, 03:25 PM   (permalink)
A couple of comments on the ADC configuration:
MOVLW    b'00010000' ;all analog channels are disabled, try b'00011000' instead
MOVWF    ANSEL
;switch to bank 1
MOVF    ADRESL,W ;the ADRESL register is in bank 1
But I think that you want to left-justify the result and read the eight most significant bits in the ADRESH resgiter (that is in bank 0).
Hope you'll have it working.
eng1 is offline
Old 7th September 2007, 07:36 PM   (permalink)
I corrected the a/d mistake of not enabling AN3. But my reasoning of using the lower result with a right justify was that I would get bits 0-7. I only need the value to go up to a max of 256, so 8 bits is enough. Do you recommend left justify and upper address because the value will not be zero in several pot positions?
Ambient is offline
Old 7th September 2007, 07:47 PM   (permalink)
Yes, you only need 8 bit-resolution, but you want to get the eight most significant bits of the result.
If you right-justify the result and read the least significant bits, what happens if the value is...
ADRESH = xxxxxx00 ADRESL = 00110011
or
ADRESH = xxxxxx01 ADRESL = 00110011
You wouldn't get unique results.
Left-justify the result and read the ADRESH register. You'll be still using 8 bits.
eng1 is offline
Old 7th September 2007, 08:24 PM   (permalink)
I tried the left justify and using the high bits, still didn't work. The problem was I was trying to write to ADCON0 and was still in Bank 1. Now it works!
Thanks everyone. I just hope I can learn quick enough to return the favor sometime.
Sean
Ambient is offline
First Program in assembly, And Programmer Inchworm. Ayne Micro Controllers 10 9th March 2007 08:27 PM
program for writing and testing circuits luca-deltodesco General Electronics Chat 3 13th August 2006 11:17 AM
little help with my program please - simple count loop kud0s Micro Controllers 5 7th July 2005 10:40 PM
Tough assembly program for the PIC16F84 asmpic Micro Controllers 34 3rd December 2004 07:50 PM
PicBasic Keypad program Sora Micro Controllers 0 20th April 2004 08:02 PM
