Hello people, i would like to ask from anyone of you kind people on how to transfer data from 877 to PC...programming software loaded in 877 is in Turbo C and compiled using HT-PICC compiler thru MPLAB...The data to transfer is in unsigned integer format...I need to know how to properly code in 877 using C to be able to transfer data to PC...PC software accepting the code is C#.. Thank you very much... | |
Try this link to point you in the right direction: http://www.winpicprog.co.uk/pic_tutorial7.htm | |
| | #3 | |
int type which is 16 bit data in micros has to be transmitted twice, high byte then low byte, receiving software has to reassemble those 8 bit data to int type because USART handles only 8 bit data
| data, pic, transfer |
| Need some help with a code provided by ATMEL | ikalogic | Micro Controllers | 1 | 23rd January 2007 03:46 PM |
| Hardcode a PIC by hand? (or 16F74 + par.port.prog = problem) | smilen | Micro Controllers | 15 | 21st November 2005 10:23 AM |
| Signalling rate & data transfer rate? | Celestie84 | General Electronics Chat | 2 | 17th June 2004 07:36 PM |
| An error in pic16f84a, why? | Zener_Diode | Micro Controllers | 6 | 11th April 2004 03:55 AM |
| Using Internal Data EEPROM on PIC16F877 | lee_man_tbu | Micro Controllers | 0 | 4th December 2003 02:47 AM |
