| Notices |
| | (permalink (permalink)) |
| I searched many threads.. but i didnt got the applications of Dtmf.. I have the tutorial and interfacing circuit diagram.. but i wanted to know its various applications.. Please post your ideas and knowledge.. Regards, Simran..
__________________ Simran.. 8051 Specialist.. | |
| Thanks ... it's good if we can dial the phone numbers.. using microcontrollers... 1. can it be used for generating number of phone lines... from one line.. 2. can it be used for controlling from Long diatance like 100 kms through phone.. 3. Dual tone means.. ? and multi frequency means.. ? actually i was thinking for applications point of view and hobbyists can help most in this... Regards, Simran..
here ' tester ' means.. Actually the tutorial i'm following is: http://www.freewebs.com/maheshwankhede/dtmfdecoder.html Regards, Simran
__________________ Simran.. 8051 Specialist.. Last edited by simrantogether; 5th September 2007 at 08:23 AM. | ||
| MT 8870 is a DTMF tone decoder IC.Yes its a similar project. When it hears a valid tone pair it starts counting binary & showing by the 4 bits.By this 4 bits its giving input to the micro & detecting what inputs have come.So it can determine which output to be turn on or off. Last edited by Gayan Soyza; 5th September 2007 at 08:39 AM. | |
| that means : it counts from ' 0000 b ' till ' 1111 b' in binary form in an infinite loop ... and suppose when we pressed any key suppose '5' then it after detecting '5' gives it to microcontroller... Am i right? Regards, Simran..
| Yes when you press number 5 it will show b’0101’ from the 8870 outputs. If you connect 4 leds to the output of 8870 you will see the first & the third leds will lights up when you press five. So we are writing a program inside a microcontroller if this value b’0101’ has come to the micro then turn on the fifth relay. If you press number 1 then it will display b’0001’ so you tell micro if bit 0 has set then turn on relay one etc…… | |
| Hey Gayan.. Its wonderful... One very important thing i would like to ask from you.. Can we use DTMF 8870 for making our " keypad " because usually.. what we see is that the algorithm of general keypad is tough.. I think you might have followed the book called Mazidi and Mazidi.. that keypad algorithm is tough.. Regards, Simran..
For me DTMF is better to control device in the vicinity. | ||
| Actually the keypad i am using .. Sir, i find it a bit tough... just for detecting one key out of 16 keys.. it takes a very big program in ' c language '. but then also i'll try... Regards, Simran..
__________________ Simran.. 8051 Specialist.. Last edited by simrantogether; 6th September 2007 at 05:11 AM. | |
| Sir yes.. I'll definitely try .. Actually, i needed some help ... if possible .. please answer the following questions: 1. can DTMF be used for generating number of phone lines... from one line.. 2. can DTMF it be used for controlling of stepper motor from Long diatance like 100 kms through phone.. 3. Please tell the name of the example project that can be made on interfacing DTMF with controller.. Regards, Simran..
__________________ Simran.. 8051 Specialist.. Last edited by simrantogether; 6th September 2007 at 05:48 AM. | |
| Visual Basic for Electronics Engineering Applications | ThermalRunaway | Electronic Books | 22 | 27th August 2008 07:40 PM |
| Could anyone tell me where I might find a DTMF decoder IC? | Micah | Micro Controllers | 10 | 16th August 2007 12:26 AM |
| dtmf applications?? | msovais | Electronic Projects Design/Ideas/Reviews | 9 | 23rd February 2007 10:49 PM |
| DTMF decoder, please help!! | mindctrl | Electronic Projects Design/Ideas/Reviews | 3 | 18th July 2005 05:16 PM |
| DTMF decoder with MIC | KaJuan | Micro Controllers | 0 | 16th February 2004 07:53 AM |
