As Instrumentation Tech, we had a lot of repeated problems. One of them is lossing the panel meters and not getting replacement simillar in size and specifications, so that i thought if possible to make a panel meter using my new world of PIC using Assemblly and PIC16F876 with the following Specs:
4 - wire meter ( not loop supplied )
4 - 20 mA input ( or 1 to 5 V using 250
hm: Resistor )
0 - 10 output figures using two units of 7-Sigments LED ( Common Cathode ) with reselution of 0.1
if it is possible and got a room from the outputs we may need two alarming set points for LO and HI signalling.
All replys are very wellcommed starting from YES or NO and not ending with Web Links and Schematics. If it is possible i'll set this my next goal to achive.
