Old 25th August 2007, 12:08 AM   #1
Default reprog-16f84a - failed
I followed Bill's "hello world" instructions and was able to program the 16F84A the first time. Found out that I used the wrong file "duh" Tried to program again with the correct file and got this:
Connecting to MPLAB ICD 2
ICD0019: Communications: Failed to open port: (Windows::GetLastError() = 0x2, 'The system cannot find the file specified.
ICD0021: Unable to connect with MPLAB ICD 2
MPLAB ICD 2 Ready
ICDWarn0034: Please ensure that your system's serial FIFO buffers are disabled.
ICDWarn0054: MPLAB IDE has lost communications with the MPLAB ICD 2. Would you like to attempt to reconnect?
MPLAB ICD 2 Ready
...Connected
Setting Vdd source to MPLAB ICD 2
...Reading ICD Product ID
Running ICD Self Test
...Passed
MPLAB ICD 2 Ready
...Connected
...Passed
MPLAB ICD 2 Ready
Programming Target...
...Erasing Part
ICD0152: Failed to read all of requested bytes (0x0 of 0x8)
ICD0275: Programming failed.
MPLAB ICD 2 Ready
Now what do I do? TIA
lemonyx is offline
Old 25th August 2007, 02:11 AM   #2
Hmm, it all looks about right. Do you have a second 16F84A to try? What is the VPP voltage (programmer / settings / power)
Also might help to install Fireflys C2 33uf & C3 0.1uf if they're not already installed.
Are you using a USB to RS232 adapter?
Bill
Smart Kits build Smart People
Old 25th August 2007, 02:57 AM   #3
Are you sure the problem is not on the PC end?
Maybe he has two copies of MPLAB running (do not know if that is possible) or has some how messed up the serial port. Perhaps a reboot will fix it.
BCHS/3v0's Tutorials
3v0 is online now
Old 25th August 2007, 03:15 AM   #4
Bill
1. the target Vdd: 4.96, Vpp:12.62, 2Vpp: 12.30
2. just have c3 installed, don't have a 33uf in the part's box, but do have a 47uf, will that work??
3. using serial, com 1 and fifo is off.
4. 2nd chip reprogrammed got this:
MPLAB ICD 2 Ready
...Connected
ICD0082: Failed MPLAB ICD 2 operation
MPLAB ICD 2 Ready
...Connected
...Passed
MPLAB ICD 2 Ready
Verifying...
...Verify Succeeded
...Programming succeeded
24-Aug-2007, 19:06:45
MPLAB ICD 2 Ready
it did not "build" but it "programed" fine, I think??
I installed the power led and that does help to let me know that there is power on the Firefly. Just waiting for the word back if the 47uf will work or not. The next closes is 10uf.
TIA
3v0
that is what happens before step 4 ICD0019: Communications: Failed to open port: on the hello world instructions. after you set the comm then you "connect" and then step 5.
lemonyx is offline
Old 25th August 2007, 04:10 AM   #5
47uf is fine, it's a power filter cap. It was chosen to be small as possible. Any value over 6.3v is fine.
Also you should reboot after you disabled the COM buffer for the first time. Also only COM1 or COM2 are supported by MPLAB.
PS how did you fit that 3M socket! The 1.2mm pins are too large that's why I recommend the Aries version (0.8mm pins)
Bill
Old 25th August 2007, 04:16 AM   #6
On the socket, it was a "snug" fit, but just pushed it on.
On that 1st PIC, will I be able to reprogram it again or is it history?
Is there another way to erase the chip and start over?
thanks, Bill
lemonyx is offline
Old 25th August 2007, 04:32 AM   #7
You can erase/reprogram the 16F84A at least 1000 times.
Newer PICs are sometimes 100,000 or more.
Bill
failed, reprog16f84a
Pic 16f84a Rotating Led Display Circuit Gayan Soyza Micro Controllers 8 30th September 2009 07:13 PM
How can I save data into RAM (16F84A) Charlie123 Micro Controllers 2 27th April 2007 03:03 PM
interupt problem with a 16f84a gibbon_82 Micro Controllers 2 1st April 2004 11:58 AM
Trouble loading .hex onto 16f84a any thoughts? andthisiswhatremains Micro Controllers 0 10th October 2003 03:23 PM
Newbie with "Verify Failed at address 0000h" error Beefer3 Micro Controllers 14 15th September 2003 09:22 AM
