Old 20th August 2007, 01:30 PM   (permalink)
Default PIC 8-bit-boundary macro?
Has anyone come up with a macro that could test a table to see if it straddles a 256-byte boundary and then insert the 'short' or 'long' code as necessary?
        addwf   PCL,W           ;
tbl
        movwf   Temp            ; save index
        movlw   high (tbl)      ;
        movwf   PCLATH          ;
        movf    Temp,W          ;
        addlw   low (tbl)       ;
        skpnc                   ;
        incf    PCLATH,F        ;
        movwf   PCL             ;
tbl
Mike, K8LH is offline
Old 20th August 2007, 02:10 PM   (permalink)
This is what I use to use a long time ago before the readable flash chips. It's not exactly what you want but may give you an idea. Turning it into a macro would be a lot easier if there was a length command. I wrote a little macro in excel (VBA) that produced a .asm file from a list of strings. As MPLAB always includes from disk, I could treat the xls file as just another source file.
JumpMessage	addwf	PCL,F
StartMessage
Mess_E.0	equ	$-StartMessage
		goto	Message00
Mess_E.1	equ	$-StartMessage
		goto	Message01
Mess_E.2	equ	$-StartMessage
		goto	Message02
Mess_E.3	equ	$-StartMessage
		goto	Message03
Mess_E.4	equ	$-StartMessage
		goto	Message04
Mess_E.5	equ	$-StartMessage
		goto	Message05
Mess_E.6	equ	$-StartMessage
		goto	Message06
Mess_E.7	equ	$-StartMessage
		goto	Message07
Mess_E.8	equ	$-StartMessage
		goto	Message08
		if	high($+1) != high($+4+15)
		org	(high($)+1) * 256 -3
		endif
Message00	movlw	high($+5)
		movwf	PCLATH
		movfw	MessageCount
		addwf	PCL,F
		dt	"Critical Error",0
		if	high($+1) != high($+4+14)
		endif
Message01	movlw	high($+5)
		movwf	PCLATH
		movfw	MessageCount
		addwf	PCL,F
		dt	"Error Number_",0
Pommie is online now
Old 20th August 2007, 02:17 PM   (permalink)
Example, not coded by me, author unknown.
 title  "ArbTable - Tables Longer than 256 Entries."
;  This Program demonstrates how a table that is longer than
;   than 256 entries (and therefore, jumps over the 256 "addwf PCL"
;   Page boarder).
  LIST p=16f877,f=inhX32
  #include <p16f877.inc>
  __CONFIG _CP_OFF & _WDT_OFF & _RC_OSC
;  Registers
 CBLOCK 0x20
TableOff:2
Temp
 ENDC
;  PAGE
;  Mainline of ArbTable
  org 0
loop:
  movlw 9			;  Get the 10th Message
  call   GetMSG
	MOVF 0X20,W
	MOVWF PCLATH
	MOVF 0X22,W
	NOP
  nop
  goto   loop
GetMSG			;  Figure Out where the Specified
				;   Message is
  movwf  Temp			;  Save the Message Count
  clrf   TableOff		;  Reset the Table Values
  clrf   TableOff + 1
GM_Loop
  movf   Temp, f		;  If Temp == 0, then Stop Search
  btfsc  STATUS, Z
   goto  GM_End
  call   MSGTable		;  get the Value in the Table
  iorlw  0			;  Are we at the End of a Message?
  btfsc  STATUS, Z
   decf  Temp, f		;   Yes - Decrement Temp
  incf   TableOff, f		;  Point to the Next Table Element
  btfsc  STATUS, Z
   incf  TableOff + 1, f
  goto   GM_Loop
GM_End			;  Tbllo/TblHI Now Point to the
				;   First Character in the Specified
  return		;   Message
MSGTable			;  Place all the Messages Here
  movlw  TableStart	;   Setup PCLATH for the Table
  addwf  TableOff + 1, w
  movwf  PCLATH
  movlw  TableStart & 0x0FF	;  Figure out the Offset
  addwf  TableOff, w
  btfsc  STATUS, C		;  If Necessary, Increment PCLATH
   incf  PCLATH, f		;  to get the Correct 256 Address Page
  movwf  PCL			;  Update the PC
TableStart			;  Table Data
Msg0
  dt	 "This is the First Message #1", 0
Msg1
  dt	 "This is the Second Message", 0
Msg2
  dt	 "This is the Third Message", 0
Msg3
  dt	 "This is the Forth Message", 0
Msg4
  dt	 "This is the Fifth Message", 0
Msg5
  dt	 "This is the Sixth Message", 0
Msg6
  dt	 "This is the Seventh Message", 0
Msg7
  dt	 "This is the Eigth Message", 0
Msg8
  dt	 "This is the Nineth Message", 0
Msg9
  dt	 "This is the Tenth Message", 0
  end
ericgibbs is online now
Old 20th August 2007, 03:52 PM   (permalink)
Thank you for the examples Gentlemen. Always a help to look at a problem from others perspective and you've given me plenty of ideas to start coding and simulating.
Have a great day. Mike
Timer0 Prescale lord loh. Micro Controllers 10 8th October 2008 05:13 PM
Sync Problem Marc_Urito Micro Controllers 3 29th April 2007 03:21 PM
Validating Code Without PIC burg Micro Controllers 4 22nd April 2007 04:14 PM
Where to disable the GIE bit on a PIC interrupt? blueroomelectronics Micro Controllers 2 7th February 2007 03:27 AM
Newcomers, please read! (PIC regarded) Upd. 0xD Jay.slovak Micro Controllers 0 17th April 2005 01:04 PM
