Old 8th September 2003, 10:03 AM   (permalink)
Default PIC program Error message. Can someone help?
Hello everyone,
I am trying to program a 16F84 and I am having some difficulties.
What I want to do is change the state of outputs portA and port B at the same time but I get errors when I assemble.
Can someone take a look and please help me out?
Thank you so much.
Sincerely,
Joey Hernandez.
Here is the program:
; CONFIGURATION FUSE
__CONFIG 0x3FFB
STATUS equ 0x03
RP0 equ 0x05
PORTA equ 0x05
PORTB equ 0x06
TRISA equ 0x85
TRISB equ 0x86
DelayA equ 0x0C
DelayB equ 0x0D
DelayC equ 0x0E
; START
org 0h ; startup address = 0000
movlw b'00000000'
movwf PORTA ; all PORTA pins = 1
movlw b'11111111'
movwf PORTB ; all PORTB pins = 0
bsf STATUS,RP0 ; set RP0 for RAM page 1
movlw b'00000000' ; all PortA = outputs
movwf TRISA
movlw b'11111111' ; all PortB = outputs
movwf TRISB
bcf STATUS,RP0 ; set RP0 for RAM page 0
MainLoop movlw b'00000001'
movwf PORTA
call Delay500
movlw b'11111110'
movwf PORTB
call Delay500
movlw b'00000010'
movwf PORTA
call Delay500
movlw b'10111101'
movwf PORTB
call Delay500
goto MainLoop ; do this loop forever
end
; SUBROUTINE: waste time for 500mS
Delay500 clrf DelayA ; clear DelayA to 0
clrf DelayB ; clear DelayB to 0
movlw 3h ; set DelayC to 3
movwf DelayC
Wait1 decfsz DelayA ; subtract 1 from DelayA
goto Wait1 ; if not 0, goto Wait1
decfsz DelayB ; subtract 1 from DelayB
decfsz DelayC ; subtract 1 from DelayC
return ; finished the delay
end
THESE ARE THE ERROR MESSAGES:
Message[302] C:\3081\GFD.TXT 34 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\3081\GFD.TXT 36 : Register in operand not in bank 0. Ensure that bank bits are correct.
Error[113] C:\3081\GFD.TXT 41 : Symbol not previously defined (Delay500)
Error[113] C:\3081\GFD.TXT 45 : Symbol not previously defined (Delay500)
Error[113] C:\3081\GFD.TXT 49 : Symbol not previously defined (Delay500)
Error[113] C:\3081\GFD.TXT 53 : Symbol not previously defined (Delay500)
BABYBASS210 is offline
Old 8th September 2003, 10:08 AM   (permalink)
Default Correction on the spacing of the program.
Even though the program looks wrong because of the spacings, the spacings where correct the got repositioned when I copied and pasted it to the Electro Tech message body.
Joey Hernandez
Old 8th September 2003, 04:22 PM   (permalink)
Be careful where you place the END statement. All statements are ignored after that.
motion is offline
