I've searched on google and these forums but havn't found a solution so I thought I'd post a thread. I'm having troubles with getting GOTO $-X working on a PIC18F. On PIC16F's, it works perfectly, but stepping through it on MPLAB's PIC SIM, it seems to not jump far enough. Am I missing something with the PIC18F's ? Thanks. |
Yes, you're missing the fact that each instruction is 2 bytes wide. Double word instructions are 4 bytes wide.
movlw h'04' ;
bra $+4 ; same as bra label1
nop ;
label1 nop ;
This method will get you into trouble with retlw type tables too. Watch out.
; enter with index (0..3) in WREG
Example_Table
rlncf WREG,W ; multiply index by 2
addwf PCL,F ;
dt 0x44 ;
dt 0x55 ;
dt 0x66 ;
dt 0x77 ;
You're gonna have so much fun on the 18F's (grin). Regards, Mike |
Thanks for your replies.
I've tried calculating the number of words used then adjusting my GOTO's, however it seems to jump too far. I've also found that by changing the GOTO from $-20 to $-18, it seems to jump 3 commands - 8 bytes worth of commands. Thanks for the heads up on the tables, I'll look into the TBLPTR method once I get this working. Here's my code, with the calculated number which jumps way too far: Code:
LCD_STRING_SLOW MACRO STRING CLRF LCD_STRING_POSITION MOVF LCD_STRING_POSITION, W; 2 - second goto should jump to here NOP; 2 CALL STRING; 4 XORLW 0x00; 2 BTFSC STATUS, Z; 2 GOTO $+20; 4 CALL LCD_DATA; 4 MOVLW 0xFF; 2 CALL DELAY; 4 INCF LCD_STRING_POSITION, F; 2 GOTO $-28; 4 MOVLW 0x00 ; - first goto should jump to here ENDM |
Do you men 20 decimal (0x14) or 0x20 (32 dec)?
If you are choose not to use base identifiers like (0x, H, . ) the assembly will use the default radix which most likely is Hex if not configured for anything else. To set the radix from withing an .asm file use RADIX DEC RADIX HEX RADIX OCT... |
Ahh, I didn't realise it was in HEX, I feel stupid now.
I havn't made jumps longer than 9 before so it never occured to me. Thank you very much. |
You could always use a couple labels (grin)...
Anyway, since you're printing strings, here's a nifty 18F' method I use for printing strings which are stored in-line with my code. It demonstrates a few things worth noting; (1) pulling a return address from the stack, (2) using TBLPTR to access individual bytes of table data, (3) how it's important to word align program counter addresses {no odd addresses, thank you}, and (4) how to modify the return address on the stack. Just replace the rcall Put232 instruction with an rcall PutLCD instruction to your "put" code... Have fun. Mike Code:
; _Print macro
_Print MACRO str ; print in-line string macro
call PutString ;
db str,0
ENDM
; usage examples
_Print "Satellite AOS:\n\r"
_Print "Satellite LOS:\n\r"
; PutString subroutine - print in-line string via Stack and TBLPTR
; string must be terminated with a 00 byte and does not need
; to be word aligned
PutString
movff TOSL,TBLPTRL ; copy return address into TBLPTR
movff TOSH,TBLPTRH ;
clrf TBLPTRU ; assume PIC with < 64-KB
PutNext
tblrd *+ ; get in-line string character
movf TABLAT,W ; last character (00)?
bz PutExit ; yes, exit, else
rcall Put232 ; print character
bra PutNext ; and do another
PutExit
btfsc TBLPTRL,0 ; odd address?
tblrd *+ ; yes, make it even (fix PC)
movf TBLPTRH,W ; setup new return address
movwf TOSH ;
movf TBLPTRL,W ;
movwf TOSL ;
return ;
The reason why I wasn't using labels was because it was for a macro, which complained that the labels were being redefined when the macro was used more than once.
There's a few things I don't understand about your code: 1) What does DB do ? I've searched on google but can't find what it does. Does it store the data in the EEPROM ? 2) What's the difference between RCALL and CALL, same goes for the difference between GOTO and BRA ? 3) Why do you have to store the return address ? Why does it not just stay as it was ? 4) Why is the DB after the CALL in the macro ? If DB is what I think it is, how does that display what hasn't yet been stored ? I have a lot to learn as far as ASM goes. Thank you for the help. Edit: I've just looked through the .lst and the DB command makes sense now, as does the reason it's after the CALL and also the reason for storing the return address. The only thing that I don't understand now is: 2) What's the difference between RCALL and CALL, same goes for the difference between GOTO and BRA ? Thanks. Last edited by yngndrw; 31st July 2007 at 02:08 AM. |
A 1-word rcall instruction is used for "short" calls where a regular 2-word call instruction can span the entire flash address space. Same thing for the 1-word bra instruction vs. the 2-word goto instruction.
Mike |
BTW, when you want to use labels in a macro you need to define them as "local"...
; _Title macro - home cursor, clear screen, print a string
_Title macro str ;
local String, Print
movlw low String ;
movwf PTRL ;
movlw high String ;
movwf PTRH ;
goto Print ;
String dt 0x1b,"[2J" ; home cursor, clear screen
dt str,0
Print call PutString ; print string
endm
Ahh, thank you very much for all of your help. I've learnt a lot.
Would it be nice of the compiler gave suggestions along with its denials.
-Duplicate label found. -May I suggest using "local x, y" since one of the duplicates were detected inside a macro. Would be nice but most likely would cost too much anyway, unless someone in the business world actualy gave a rats ... and cared. |
Like anything else you learn "the hard way"... you never forget it (grin).
| PIC18F2550 with real time counter (DS1302) | ash87 | Micro Controllers | 8 | 30th July 2007 03:21 AM |
