Old 26th July 2007, 07:50 AM   (permalink)
Default Keypad Routine
Mr Goodwin, I was checking your keypad routine in your tutorials. Could you explain the following subroutine.
call Scan_Keys
movlw 0x10 ;check for no key pressed
subwf key, w
btfss STATUS, Z
goto Key_Found
call Delay20
goto Keys
People perish because of lack of knowledge
emufambirwi is offline   Reply With Quote
Old 26th July 2007, 05:40 PM   (permalink)
Pretty self explanitory really?, the first line scans the keypad, and the next two check if any pressed key was found. If one was, then it jumps to Key_Found to process the key, otherwise it loops back round.
Old 27th July 2007, 06:36 AM   (permalink)
goto Keys
Why in particular movlw 0x10 and not movlw 0x00 because I thought that this would ensure we test all the keys
Old 27th July 2007, 06:42 AM   (permalink)
Because the routine 'walks' a bit along the rows (or columns), and it only gets to that point if no key was pressed.
Old 27th July 2007, 08:16 AM   (permalink)
Keys    call       Scan_Keys
              subwf   key, w
              btfss    STATUS, Z
              goto     Key_Found
              call   	Delay20
              goto   	Keys
I understand that we are comparing the contents of 'key' with binary '00010000'.
Does this then mean that for 'no key pressed', in 'key' there should be 0x10 or 00010000
Old 27th July 2007, 08:45 AM   (permalink)
Keys    call       Scan_Keys
              subwf   key, w
              btfss    STATUS, Z
              goto     Key_Found
              call   	Delay20
              goto   	Keys
Yes, that's right - any other result means there's a key pressed.
Old 27th July 2007, 12:53 PM   (permalink)
Would you explain what happens in terms of voltage levels when I press say key '1' and scan that row? In my case, which I suppose is similar to yours, the columns are tied to Vcc through resistors, and I scan the rows. Initially, the rows are all high
Keypad Code gregmcc Micro Controllers 5 11th May 2006 08:01 AM
keypad encoder Mel_noypi Datasheet/Parts Requests 5 22nd February 2006 02:01 PM
16f628 keypad interface scarab Micro Controllers 2 21st April 2004 05:15 AM
PicBasic Keypad program Sora Micro Controllers 0 20th April 2004 07:01 PM
pic keypad nevada Electronic Projects Design/Ideas/Reviews 2 25th November 2003 03:45 PM
