Old 25th July 2007, 02:12 PM   (permalink)
Experienced Member
savnik is on a distinguished road
Default Lcd
I swap the :
LcdE equ 0 ; enable Lcd
LcdRw equ 3 ; read Lcd
with this
LcdE equ 3 ; read Lcd
LcdRw equ 0 ; enable Lcd
but the below code isn't work
Before swap the code work
;*	PORTB:	0 LCD Display E
;*		1
;*		2 LCD Display RS
;*		3 LCD Display R/W
;*		4-7 LCD Display D4 .. D7
PORTC	equ	PORTB		; LCD-Control-Port
PORTD	equ	PORTB		; LCD-Daten-Port
LcdRs	equ	2		; Data Lcd (not control)
; The program begins with the initialization
Init	bsf     STATUS, RP0	; Bank 1
	movlw	B'00000000'	; PortB all outputs
	movwf	TRISB
	bcf     STATUS, RP0	; Bank 0
	call	InitLCD		; Display initialization
;around loops * 1 ms
;10MHz -> 2,5MHz -> 2500T
WAIT
top      movlw   .249           ; timing adjustment variable (1ms)  10MHz 249*10=2490T
         movwf   loops2
top2     nop                    ; sit and wait (Schleifenlδnge 10T)
         nop
         nop
         nop
         nop
         nop
	 nop
         decfsz  loops2, F      ; internal loops complete?
         goto    top2           ; no, go again
         decfsz  loops, F       ; more outer loops complete?
         goto    top            ; no, go again
         retlw   0              ; yes, return from subWAIT
; LCD-Routinen
; initialization the LCD-Displays
InitLCD
	movlw	D'255'		; 250 ms Break after switching on
	movwf	loops
	call	WAIT
	movlw	B'00110000'	; 1
	movwf	PORTB
	bsf	PORTB, LcdE
	nop
	bcf	PORTB, LcdE
	movlw	D'50'		; 50 ms Pause
	movwf	loops
	call	WAIT
	movlw	B'00110000'	; 2
	call	Control8Bit
	movlw	B'00110000'	; 3
	call 	Control8Bit
	movlw	B'00100000'	; 4
	call 	Control8Bit
	movlw	B'00000001'	; lφschen and cusor home
	call	OutLcdControl
	movlw	B'00101000'	; 5 function set, 4-bit  2-lined,  5x7
	call	OutLcdControl
	movlw	B'00001000'	; 6 display off
	call	OutLcdControl
	movlw	B'00000110'	; 7 entry mode, increment, disable display-shift
	call	OutLcdControl
	movlw	B'00000011'	; 8 cursor home, cursor home
	call	OutLcdControl
	movlw	B'00001100'	; 9 display on, cursor off, cursor flash off
	call	OutLcdControl
	return
; a control byte 8-bit upper-carry
Control8Bit
	movwf	PORTB
	bsf	PORTB, LcdE
	nop
	bcf	PORTB, LcdE
	movlw	D'10'
	movwf	loops
	call 	WAIT
	return
; for it wait, there? the display for the data acceptance is ready
LcdBusy
        bsf     STATUS, RP0	; make Port B4..7 input
	movlw	B'11110000'
	iorwf   TRISB, f
        bcf     STATUS, RP0
BusyLoop
	bcf	PORTC, LcdRs
	bsf	PORTC, LcdRw	; Lesen
	bsf	PORTC, LcdE
	nop
	movf	PORTD, w
	movwf	LcdStatus
	bcf	PORTC, LcdE
	nop
	bsf	PORTC, LcdE	; Enable
	nop
	bcf	PORTC, LcdE
	btfsc	LcdStatus, 7	; test bit 7
	goto	BusyLoop
	bcf	PORTC, LcdRw
        bsf     STATUS, RP0	; make Port B4..7 output
	movlw	B'00001111'
	andwf   TRISB, f
        bcf     STATUS, RP0
	return
; a byte with tax data from LCD data to the display upper-carry
OutLcdControl
	movwf	LcdDaten
	call	LcdBusy
	movf	LcdDaten, w
	andlw	H'F0'
	movwf	PORTD		; Hi-teil data write
	bsf	PORTC, LcdE
	nop
	bcf	PORTC, LcdE	; Disable LcdBus
	swapf	LcdDaten, w
	andlw	H'F0'
	movwf	PORTD		; Lo-teil data write
	bsf	PORTC, LcdE
	nop
	return
; a data byte of LCD upper-carry data to the display
OutLcdDaten
	movwf	LcdDaten
	call	LcdBusy
	movf	LcdDaten, w
	andlw	H'F0'
	bsf	PORTC, LcdRs	; Daten
	bsf	PORTC, LcdE	; Enable LcdBus
	nop
	swapf	LcdDaten, w
	andlw	H'F0'
	bsf	PORTC, LcdE
	nop
	bcf	PORTC, LcdRs	;
	return
savnik is offline   Reply With Quote
Old 25th July 2007, 02:39 PM   (permalink)
Experienced Member
Pommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to behold
Some of the code is writing to portb, some to portc and some portd. How have you got your LCD connected?
Pommie is offline   Reply With Quote
Old 25th July 2007, 02:47 PM   (permalink)
Experienced Member
like this and works
but i want to swap the E with RW or to ground the RW
Old 25th July 2007, 03:22 PM   (permalink)
Experienced Member
I see, you have equated portc and portd as portb - how confusing.
I can't see why it shouldn't work. Maybe you should go through the code and replace all port accesses with portb - you might then be able to spot the error.
If you want to ground RW then you need to replace the busy test with a delay.
Old 25th July 2007, 03:24 PM   (permalink)
Experienced Member
yes i want to ground the RW . How delay is need;
Old 25th July 2007, 03:25 PM   (permalink)
Super Moderator
Why do you want to ground it?.
Old 25th July 2007, 03:27 PM   (permalink)
Experienced Member
Because only write to lcd , not read.
Old 25th July 2007, 03:36 PM   (permalink)
Experienced Member
ericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to behold
You are testing the BUSY bit with a READ!
Eric
ericgibbs is online now   Reply With Quote
Old 25th July 2007, 03:56 PM   (permalink)
Super Moderator
Leave it as it is, it makes for the fastest possible updating speed of the LCD, otherwise you have to introduce fixed delays, which waste time. The read is to check the busy flag, so it never waits longer than it needs to.
Old 25th July 2007, 03:59 PM   (permalink)
Experienced Member
Ok i leave it as it , but i want o to swap the E with RW
problem with LCD meera83 Micro Controllers 9 17th July 2007 02:20 PM
Help understanding the Unicorn Kyle-s4h Micro Controllers 2 5th June 2007 06:08 PM
PIC16+Parallel lcd - by twitchy Nigel Goodwin Micro Controllers 16 18th May 2007 10:44 AM
8 bits LCD Problem joe_1 Micro Controllers 3 27th April 2007 01:38 AM
89c4051 4-bit controlled LCD sporadic screwup Pax Writer Micro Controllers 7 26th April 2007 05:58 AM
