Nice to see someone putting all those ISA cards to good use. How about for the next project a nice Sound Blaster interface? =)
could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." |
Hi There,
I've been reading the forum for a while but just joined in as a registered user. I did put together several projects showing how to put together a basic circuit with different Microchip MCUs and ethernet controllers. I also modified one of the original versions of the Microchip TCP/IP stack to make it more easy to customize and configure. If you want to take a look pay a visit to: http://www.ljcv.net/projects/ And I'll be around to share what a learned and answer questions if I can. Best Regards |
Thanks for the link jmodio, I'm working on a PIC / Ethernet kit and your link is excellent for that.
If you need any help feel free to contact me. BTW, I always loved the 3D drawings in your site Regards |
Thanks, I'm sure I'll take you up on the offer.
I want my version to have 6 relays and 4 opto inputs & RS485 (not 232) HVAC & Home Automation is the plan. |
This design is simple, cheap and very low-power. It`s good for a one-time application but lacks some versatility. An implementation of an external EEPROM would greatly enhance this design. Just see it as a jumpstart for all the applications you will design and publish here |
@ezuk: both. I find working with legacy devices more practical since they are supposed to be: cheap, standardized, fully developed, and i expect to see alot of projects using these devices which allows me to gather as much information as i want. Im also in it for the experience, since like what ive said before im a newbie with microchips and electronics. I also think that learning to code the TCP/IP stack would bring me closer to make my own embedded devices with networking capability.
@gradtje: yes, infact, we are planning to interface an external memory device, albeit not an EEPROM, but an MMC card (larger memory but somewhat slower) connected via SPI protocols. This is why we prefer to use the 18f45j10. |
Andrew Smallridge from Brush Electronics put together a nice set of SD/MMC drivers and file system routines for PIC, www.brushelectronics.com/, take a look that may save you some coding time. My .02 |
@jampodio: you .02 is worth a million bucks! thanks for the link. Currently i have no idea how much ram we do actually need, but i think your right about how few 1024 bytes is. Thanks for the heads up!
hello again guys, my project development has been put to a crawl. I've been analyzing the drivers from open-source codes but have no real luck into successfully making one (in c preferably). I believe that i must dig deeper if i were to fully understand how the NIC would work. Im trying to dig up datasheets for the chipsets of these NIC's but no luck as to where i can find one.
I have two 3c509b NIC's here with me, but unfortunately, it seems both devices use different chipsets. One was using LUCENT 40-0316-000 while the other one: Parallel 40-0411-001. I think i may have a better chance in understanding how these things actually work if i obtain the datasheets of these. Really need help here, and thanks for the feedback in advanced guys! |
@eblc: I tried checking the datasheet of the RTL8019AS, it seems this NIC also had some technical data about its own chipset which i would need. I think the solution to my problems is found with the datasheet of the chipsets of the NICs im using.
L.Chung |
i need help about circuit for brushless dc motor driver or controller
i need 3 phase brushless dc motor controller
| Best PIC for Project? | PJ Adams | Micro Controllers | 21 | 11th May 2007 04:53 PM |
| PIC Project advice - doubling frequency | coze | Micro Controllers | 8 | 26th February 2007 07:05 PM |
| latest project in embedded systems | cooldude440 | Electronic Projects Design/Ideas/Reviews | 3 | 20th February 2006 09:02 PM |
| Newcomers, please read! (PIC regarded) Upd. 0xD | Jay.slovak | Micro Controllers | 0 | 17th April 2005 01:04 PM |
| Embedded sys project idea | planetajay | Electronic Projects Design/Ideas/Reviews | 1 | 12th February 2004 08:56 PM |
