Old 19th July 2007, 05:04 AM   #1
Default Low voltage vs high voltage programming
I've been using high voltage programming since I started using PIC. I just want to know what's the difference between these three.
1. The configuration setting.
2. One IO pin cannot be used.
3. The supply voltage of the programmer.
Is there any other difference beside what I have mentioned above?
bananasiong
bananasiong is offline
Old 19th July 2007, 05:43 AM   #2
is there any other difference beside what I have mentioned above?
As a safety feature, you cannot turn off LVP via LVP.
Also with LVP enabled, it is very easy for the PIC to get stuck in programming mode if you connect the LVP pin incorrectly in a project.
kchriste is offline
Old 19th July 2007, 06:09 AM   #3
I’m programming my PICS through serial port. I’m not giving any supply voltage from outside.
Also I never enable LVP fuse but its programming nicely.
Is it my circuit is a low voltage programmer or high voltage programmer?
Thanks.
Suraj143 is offline
Old 19th July 2007, 07:30 AM   #4
Thanks.
Serial port can supply 13 V for high voltage programming. I use parallel port programmer.
Not sure about yours, I wonder why the GND is connected to Vdd pin?
bananasiong
Old 20th July 2007, 01:00 AM   #5
Maybe it uses a positive ground?
It looks like it is neither because Vss of the PIC is not connected to anything except the zener. Unless they are using the PICs internal diodes to feed the (-) from the signal leads. Definitely something I wouldn't rely on. Does it actually work as wired?
kchriste is offline
high, low, programming, voltage
High voltage lifter things Electronic Projects Design/Ideas/Reviews 8 24th April 2007 12:07 PM
Need some help with a code provided by ATMEL ikalogic Micro Controllers 1 23rd January 2007 03:46 PM
High voltage, high speed measurement Optikon Electronic Projects Design/Ideas/Reviews 18 15th November 2005 01:51 PM
Having problems with pic16f872 cjgalway1000 Micro Controllers 0 7th April 2004 03:39 PM
PLZ HELP. high gain linear voltage amplifier mostafa0020 General Electronics Chat 0 16th August 2003 08:48 PM
