| I'm trying to modify the source for TINY BOOTLOADER to operate with the internal OSC + PLL on my 18F2620. I've changed the necessary fuses, and added what I think are the correct instructions, but it has a few weird problems. problem 1) the bootloader operates at 28800 bps, not 57600 bps as instructed, which indicates the cpu is running slower than calculated... is it running at 16mhz instead of 32mhz, since 57600/2 = 28800? problem 2) the bootloader self-destructs when it programs the pic, as if it is overwriting part of itself. after uploading my main program (which skips several bytes for the bootloader's block), I'm not able to connect to the bootloader again, after resetting the pic. Here's what I've managed to cobble together from the original code example, the parts I've changed are in red: Code: radix DEC
LIST P=18F2620 ; change also: Configure->SelectDevice from Mplab
xtal EQU 32000000 ; you may want to change: _XT_OSC_1H _HS_OSC_1H _HSPLL_OSC_1H
baud EQU 57600 ; the desired baud rate, originally 115200
; The above 3 lines can be changed and buid a bootloader for the desired frequency (and PIC type)
; Tiny Bootloader 18F series Size=100words
; claudiu.chiculita@ugal.ro
; http://www.etc.ugal.ro/cchiculita/software/picbootloader.htm
#include "icdpictypes.inc" ;takes care of: #include "p18fxxx.inc", max_flash, IdTypePIC
#include "spbrgselect.inc" ; RoundResult and baud_rate
#define first_address max_flash-204 ;102 words originally 100
CONFIG OSC = INTIO67
CONFIG FCMEN = OFF
CONFIG IESO = OFF
CONFIG PWRT = ON
CONFIG BOREN = ON
CONFIG BORV = 2 ; 4.2v
CONFIG WDT = OFF
CONFIG WDTPS = 1
CONFIG MCLRE = ON
CONFIG PBADEN = OFF
CONFIG CCP2MX = PORTC
CONFIG STVREN = ON
CONFIG LVP = OFF
CONFIG XINST = OFF
CONFIG DEBUG = OFF
CONFIG CP0 = OFF
CONFIG CP1 = OFF
CONFIG CP2 = OFF
CONFIG CP3 = OFF
CONFIG CPB = OFF
CONFIG CPD = OFF
CONFIG WRT0 = OFF
CONFIG WRT1 = OFF
CONFIG WRT2 = OFF
CONFIG WRT3 = OFF
CONFIG WRTB = OFF
CONFIG WRTC = OFF
CONFIG WRTD = OFF
CONFIG EBTR0 = OFF
CONFIG EBTR1 = OFF
CONFIG EBTR2 = OFF
CONFIG EBTR3 = OFF
CONFIG EBTRB = OFF
;----------------------------- PROGRAM ---------------------------------
cblock 0
crc
i
cnt1
cnt2
cnt3
counter_hi
counter_lo
flag
endc
cblock 10
buffer:64
endc
SendL macro car
movlw car
movwf TXREG
endm
;0000000000000000000000000 RESET 00000000000000000000000000
ORG 0x0000
GOTO IntrareBootloader
;view with TabSize=4
;&&&&&&&&&&&&&&&&&&&&&&& START &&&&&&&&&&&&&&&&&&&&&&
;---------------------- Bootloader ----------------------
;PC_flash: C1h U H L x ... <64 bytes> ... crc
;PC_eeprom: C1h 40h EEADR EEDATA 0 crc
;PC_cfg C1h U OR 80h H L 1 byte crc
;PIC_response: type `K`
ORG first_address ;space to deposit first 4 instr. of user prog.
nop
nop
nop
nop
org first_address+8
IntrareBootloader
movlw b'01110000' ;set intrc to 8mhz
movwf OSCCON
;init serial port
movlw b'00100100'
movwf TXSTA
movlw spbrg_value
movwf SPBRG
movlw b'10010000'
movwf RCSTA
bsf OSCTUNE,6,0 ;enable 4x PLL
;wait for computer
rcall Receive
sublw 0xC1 ;Expect C1h
bnz way_to_exit
SendL IdTypePIC ;send PIC type
MainLoop
SendL 'K' ; "-Everything OK, ready and waiting."
mainl
clrf crc
rcall Receive ;Upper
movwf TBLPTRU
movwf flag ;(for EEPROM and CFG cases)
rcall Receive ;Hi
movwf TBLPTRH
movwf EEADR ;(for EEPROM case)
rcall Receive ;Lo
movwf TBLPTRL
movwf EEDATA ;(for EEPROM case)
rcall Receive ;count
movwf i
incf i
lfsr FSR0, (buffer-1)
rcvoct ;read 64+1 bytes
movwf TABLAT ;prepare for cfg; => store byte before crc
rcall Receive
movwf PREINC0
decfsz i
bra rcvoct
tstfsz crc ;check crc
bra ziieroare
btfss flag,6 ;is EEPROM data?
bra noeeprom
movlw b'00000100' ;Setup eeprom
rcall Write
bra waitwre
noeeprom
btfss flag,7 ;is CFG data?
bra noconfig
tblwt* ;write TABLAT(byte before crc) to TBLPTR***
movlw b'11000100' ;Setup cfg
rcall Write
bra waitwre
noconfig
;write
eraseloop
movlw b'10010100' ; Setup erase
rcall Write
TBLRD*- ; point to adr-1
writebigloop
movlw 8 ; 8groups
movwf counter_hi
lfsr FSR0,buffer
writesloop
movlw 8 ; 8bytes = 4instr
movwf counter_lo
writebyte
movf POSTINC0,w ; put 1 byte
movwf TABLAT
tblwt+*
decfsz counter_lo
bra writebyte
movlw b'10000100' ; Setup writes
rcall Write
decfsz counter_hi
bra writesloop
waitwre
;btfsc EECON1,WR ;for eeprom writes (wait to finish write)
;bra waitwre ;no need: round trip time with PC bigger than 4ms
bcf EECON1,WREN ;disable writes
bra MainLoop
ziieroare ;CRC failed
SendL 'N'
bra mainl
;******** procedures ******************
Write
movwf EECON1
movlw 0x55
movwf EECON2
movlw 0xAA
movwf EECON2
bsf EECON1,WR ;WRITE
nop
;nop
return
Receive
movlw xtal/2000000+1 ; for 20MHz => 11 => 1second delay
movwf cnt1
rpt2
clrf cnt2
rpt3
clrf cnt3
rptc
btfss PIR1,RCIF ;test RX
bra notrcv
movf RCREG,w ;return read data in W
addwf crc,f ;compute crc
return
notrcv
decfsz cnt3
bra rptc
decfsz cnt2
bra rpt3
decfsz cnt1
bra rpt2
;timeout:
way_to_exit
bcf RCSTA, SPEN ; deactivate UART
bra first_address
; After reset
; Do not expect the memory to be zero,
; Do not expect registers to be initialised like in catalog.
END
__________________ If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 | |
| Could it be that you need to select the internal oscillator block? Code: movlw b'01110010' ;set intrc to 8mhz
movwf OSCCON Mike. Last edited by Pommie; 12th July 2007 at 03:38 PM. | |
| what if you change Code: movlw spbrg_value movwf SPBRG Code: movlw .34 movwf SPBRG Not sure if i would trust the internal OSC for a Bootloader so far... sure you may need to tweak/calibrate it a little bit first. and how about... Code: #define first_address max_flash-206
__________________ Steve Last edited by mister_e; 12th July 2007 at 08:48 PM. | |
| mmm, try that one Code: movlw b'01110000' ;set intrc to 8mhz movwf OSCCON bsf OSCTUNE,6,0 ;enable 4x PLL btfss OSCCON,2 ;wait 'til internal osc is stable GOTO $-2 Code: #define first_address max_flash-210
__________________ Steve | |
| I tried all of your suggestions, in various combinations, as well as putting PLLEN after the code that checks for the osc to be stable. was not able to achieve any usable baud rates beyond 28800. so I decided to fall back on the regular 8mhz intrc and 38400 baud, which gives a baud error of 0.16% I still have the problem of the bootloader self destructing. once I flash my main code to the chip, via the bootloader, I am unable to contact the loader again. i suspect the cause is from modifying the starting address? Code: #define first_address max_flash-208 Code: movlw b'01110010' ;set intrc to 8mhz movwf OSCCON btfss OSCCON,2 ;wait 'til internal osc is stable GOTO $-2
| not at this moment, but i tested with the mod i suggested and i can connect to the PIC,it recognize the device... but it always tell me... Quote:
Weird... And this, with those few PIC model i tried, with or without crystal. So, for now, i will bet your device programmer don't set/program correctly the configuration fuses... but yeah... it's just a bet. As always, i doubt the reliability of the internal OSC for a bootloader. Did you tried with a crystal? If i can find time and have some success with, i'll forward the info here.
__________________ Steve Last edited by mister_e; 14th July 2007 at 01:37 AM. | ||
| ok, I learned the pc-side flash application will only 'protect' the first 100 words of the bootblock, so the extra words added to the code were resulting in part (first few words?) of the program getting overwritten. that is why the 'loader would self destruct. I haven't had opportunity to do a side by side comparison, but I found this modified source for a 18F4680, which when I changed the config fuses and processor type, compiled for my 18f2620. best thing is, it's the original 100 word size, so it does not self destruct. thanks Steve and everyone else for your help! Code: radix DEC
xtal EQU 8000000 ; you may want to change: _XT_OSC_1H _HS_OSC_1H _HSPLL_OSC_1H
baud EQU 38400 ; standard TinyBld baud rates: 115200 or 19200
; The above 3 lines can be changed and build a bootloader for the desired frequency (and PIC type)
; Modified by Nam Nguyen-Quang for testing different PIC18Fs with tinybldWin.exe v1.8
; namqn@yahoo.com
; Copy these include files to your project directory (i.e. they are in the same
; directory with your .asm source file), if necessary
#include "icdpictypes.inc" ; Takes care of: #include "p18fxxx.inc", max_flash, IdTypePIC
#define first_address max_flash-200 ;100 words
CONFIG FCMEN = OFF
CONFIG IESO = OFF
CONFIG PWRT = ON
CONFIG BOREN = ON
CONFIG BORV = 1 ; 4.2v
CONFIG WDT = OFF
CONFIG WDTPS = 1
CONFIG MCLRE = ON
CONFIG PBADEN = OFF
CONFIG STVREN = ON
CONFIG LVP = OFF
CONFIG XINST = OFF
CONFIG DEBUG = OFF
CONFIG CP0 = OFF
CONFIG CP1 = OFF
CONFIG CP2 = OFF
CONFIG CP3 = OFF
CONFIG CPB = OFF
CONFIG CPD = OFF
CONFIG WRT0 = OFF
CONFIG WRT1 = OFF
CONFIG WRT2 = OFF
CONFIG WRT3 = OFF
CONFIG WRTB = OFF
CONFIG WRTC = OFF
CONFIG WRTD = OFF
CONFIG EBTR0 = OFF
CONFIG EBTR1 = OFF
CONFIG EBTR2 = OFF
CONFIG EBTR3 = OFF
CONFIG EBTRB = OFF
cblock 0
crc
i
cnt1
cnt2
cnt3
counter_hi
counter_lo
flag
endc
cblock 10
buffer:64
dummy4crc
endc
SendL macro car
movlw car
movwf TXREG
endm
ORG 0x0000
nop
nop
nop
nop
org first_address+8
IntrareBootloader
;init IntOSC, added by Nam Nguyen-Quang
movlw 0x70
movwf OSCCON
; the above 2 lines should be commented out for designs not using the internal oscilator
; or for the chips without the internal oscilator
;init serial port
movlw b'00100100'
movwf TXSTA
movlw spbrg_value
movwf SPBRG
movlw b'10010000'
movwf RCSTA
;wait for computer
rcall Receive
bnz way_to_exit
MainLoop
mainl
clrf crc
movwf TBLPTRU
rcall Receive ;Hi
movwf TBLPTRH
rcall Receive ;Lo
movwf TBLPTRL
movwf i
incf i
rcall Receive
movwf PREINC0
decfsz i
bra rcvoct
bra ziieroare
bra noeeprom
rcall Write
bra waitwre
noeeprom
bra noconfig
rcall Write
bra waitwre
noconfig
;write
eraseloop
rcall Write
writebigloop
movlw 8 ; 8groups
movwf counter_hi
lfsr FSR0,buffer
writesloop
movwf counter_lo
writebyte
movwf TABLAT
tblwt+*
decfsz counter_lo
bra writebyte
rcall Write
decfsz counter_hi
bra writesloop
waitwre
bra MainLoop
SendL 'N'
bra mainl
Write
movwf EECON1
movlw 0x55
movwf EECON2
movlw 0xAA
movwf EECON2
nop
;nop
return
Receive
; for 18F2xxx chips, this should be xtal/1000000+1
movwf cnt1
rpt2
clrf cnt2
rpt3
clrf cnt3
rptc
bra notrcv
return
notrcv
decfsz cnt3
bra rptc
decfsz cnt2
bra rpt3
decfsz cnt1
bra rpt2
;timeout:
way_to_exit
bra first_address
; After reset
END
| as a follow up, I think I was using the wrong value for spbrg ... despite a higher cpu clock given by the PLL, Fosc remains at 8mhz, and the baud rate generator pulls its clock directly from Fosc, not from the cpu clock. So SPBRG = 7 would have been the value for 57600 baud, but with a baud error of nearly 9%, it would generate a lot of errors. 38400 on the other hand has a baud error of 0.16%.
| Kind of why i created the PicMultiCalc. It find the right value for you in few clicks and show you the error percentage AND find the best match for you... yeah lazy boy tool In our situation, if it was possible to bypass the utility bootloader code protection, the internal EUSART BRG16 would have been really handy. 115200 baud @32MHz and 0.64 err% 57600 baud @32MHz and 0.08err% ... really not bad
__________________ Steve Last edited by mister_e; 15th July 2007 at 12:15 AM. | |
| your values are correct, assuming we had Fosc of 32mHz... but the pic supports a max of 20mHz for Fosc, via external crystal/clock. running in INTRC + PLL Fosc is only 8mhz, regardless of the cpu clock (4x PLL). I use an excel spreadsheet I nocked up to calculate baud rates, based on the three formula offered in the datasheet. how does the 16bit baud generator help in this situation? I understand it can be used to generate very slow baud rates with a high Fosc?
| A 16 bit SPBRG (divider chain) value can also provide finer divider chain resolution and improve the bit error rate on most of the other baud rates. | |
| what does your number generator say about Fosc = 8000000
| You can download both the Spreadsheet and the stand-alone application pictured above from the following Forum.Microchip thread and try it yourself Sir; Revised SPBRG Calc Remember to press <enter> after changing the Fosc value (a limitation of the BASIC I used). | |
| awesome, thanks
| Sorry, but it really work @32MHz when using the internal 8MHz + PLL Code: ; -----------------------------------------------------------------
; [ ---- 8 MHZ ---- ] [ ---- 32 MHz ---- ]
; Baudrate SPBRG TXSTA ERR % SPBRG TXSTA ERR %
; 2400 .207 h'24' 0.17 .207 h'20' 0.17
; 4800 .103 h'24' 0.17 .103 h'20' 0.17
; 9600 .51 h'24' 0.16 .207 h'24' 0.16
; 19200 .25 h'24' 0.16 .103 h'24' 0.16
; 38400 .12 h'24' 0.16 .51 h'24' 0.16
; 57600 .8 h'24' 3.55 .34 h'24' 0.79
; 115200 .3 h'24 8.51 .16 h'24' 2.12
SPBRG_VAL = .34
TXSTA_VAL = h'24'
; 57600 BAUDS @ 32MHz
LIST P=18F4620
include "P18F4620.inc"
CONFIG FCMEN = OFF
CONFIG IESO = OFF
CONFIG PWRT = ON
CONFIG BOREN = ON
CONFIG BORV = 2
CONFIG WDT = OFF
CONFIG WDTPS = 1
CONFIG MCLRE = ON
CONFIG PBADEN = OFF
CONFIG STVREN = ON
CONFIG LVP = OFF
CONFIG XINST = OFF
CONFIG DEBUG = OFF
; MACRO
PAUSE MACRO DELAY
movlw low(DELAY)
movwf TMR0L
MOVLW HIGH(DELAY)
MOVWF TMR0H
CALL DODELAY
ENDM
HSEROUT MACRO StringToSend
LOCAL JumpOver,String
BRA JumpOver
String
DATA StringToSend
JumpOver
movlw UPPER String
movwf TBLPTRU
movlw HIGH String
movwf TBLPTRH
movlw LOW String
movwf TBLPTRL
CALL SENDIT
ENDM
; Software constants
; Delays: to use with PAUSE macro
_50MS = .63973 ; 50 mSec
_500MS = .34286 ; 500 mSec
ORG 0
; Hardware configuration
; Internal OSC
movlw b'01110000' ; 8mhz
movwf OSCCON ;
bsf OSCTUNE,6 ; enable 4x PLL, now RUN @32MHz
; USART
movlw h'90' ; Enable USART & continuous receive
movwf RCSTA
movlw TXSTA_VAL ; Enable USART transmit & set BRGH
movwf TXSTA
movlw SPBRG_VAL ; Set Baudrate
movwf SPBRG
; Timer0
MOVLW B'00000110' ; STOP TIMER0
; CLK source = INTERNAL
; PRESCALER 1:128
MOVWF T0CON
; Program start
PAUSE _50MS ; OSC Settle time
START
; Send some data
HSEROUT "String #1\r\n\0"
HSEROUT "------- Yet another\r\n\0"
HSEROUT "----------- One more for the luck\r\n\0"
HSEROUT "***************************** done ****************\r\n\0"
PAUSE _500MS
BRA START
DODELAY
BCF INTCON,TMR0IF ; clear overflow flag
BSF T0CON,TMR0ON ; START TIMER0
BTFSS INTCON,TMR0IF ; overflow?
GOTO $-2 ; ---- NO, spin in round
BCF T0CON,TMR0ON ; YES, STOP TIMER0
RETURN
SENDIT
tblrd *+
MOVF TABLAT,W ; get character, save it to W
BTFSC STATUS,Z ; EOM (character=0) ?
RETURN ; --- YES, Bye bye
movwf TXREG ; NOPE, send it
btfss TXSTA,TRMT ; wait for data TX
goto $-2
bra SENDIT ; fetch next message character from table
END
| I have error with Pic Code & Need help | admain | Micro Controllers | 0 | 15th April 2007 07:06 AM |
| Code not working on pic 16F874A | pixelpunch | Micro Controllers | 7 | 28th February 2007 01:39 PM |
| Newcomers, please read! (PIC regarded) Upd. 0xD | Jay.slovak | Micro Controllers | 0 | 17th April 2005 02:05 PM |
| Tough assembly program for the PIC16F84 | asmpic | Micro Controllers | 34 | 3rd December 2004 07:50 PM |
| An error in pic16f84a, why? | Zener_Diode | Micro Controllers | 6 | 11th April 2004 03:55 AM |
