+ Reply to Thread
Results 1 to 4 of 4
Thread: PIC 16f876 data eeprom write
  1. #1
    SuperBud Newbie
    Join Date
    Sep 2003
    Posts
    2
    Default PIC 16f876 data eeprom write
    I have a problem with data eeprom write routine. I use the routine in PIC's datasheet but pic doesn't esc of sleep mode.
    Can you help me?
    Thank you
    SuperBud
  2. #2
    motion Newbie
    Join Date
    Jul 2003
    Location
    Quezon City.PH
    Posts
    560
    You might get responses if people could understand what you mean. Could you please explain your question a little bit clearer please.
  3. #3
    SuperBud Newbie
    Join Date
    Sep 2003
    Posts
    2
    This is the routine :
    ; the value to write is in variable sup
    ; the address si in register w
    Scrivi_Dato
    BSF STATUS, RP1
    BCF STATUS, RP0 ; Bank 2
    movwf EEADR ; EEADR<=w
    Banksel sup
    Movf sup,0 ;w<=sup
    BSF STATUS, RP1
    movwf EEDATA ;EEDATA<=w
    BSF STATUS,RP0 ; Banco 3
    BCF EECON1,EEPGD ;Punta alla Data Memory
    BSF EECON1,WREN ;Abilito la scrittura
    BCF INTCON,GIE ;Disabilita interrupt
    movlw 55h
    movwf EECON2
    movlw 0AAh
    movwf EECON2
    BSF EECON1,WR ;Abilito scrittura
    BSF INTCON,GIE ;Abilita interrupt
    SLEEP
    BCF EECON1,WREN ;Disabilito scrittura
    Return
    the program remains blocked on instruction SLEEP.
    Excuse me for my bad English i hope that you can understand my problem and help me.
    Thank you
    Bye
  4. #4
    motion Newbie
    Join Date
    Jul 2003
    Location
    Quezon City.PH
    Posts
    560
    In addition to the global interrupt enable GIE, I think you need to enable EEIE bit in PIR2 to get an interrupt to come out of SLEEP. You also have to have an interrupt service routine at location 4 to clear the EEIF bit.
    I don't use this routine myself. Since writing to the eeprom takes a long time, I simply return from this eeprom write routine and clear the WREN bit elsewhere. Anyway, a simpler routine instead of using SLEEP and interrupts is as follows:
    WAIT:
        BTFSC    EECON1,WR
        GOTO     WAIT
        BCF      EECON1,WREN
    "Having to do with Motion Control"
+ Reply to Thread
Tags for this Thread
