Hi Tim,
The SX/B BASIC docs say it's a compiler not an interpretor and it really looks like a simple, capable, intuitive BASIC implementation. Let me study it a little more. I'm sure there's got to be a way to access a 64 byte display buffer quickly and efficiently (perhaps using GET and PUT or more directly using @address_of operations). Don't "jump ship" for another processor yet. You listed some very good reasons for why you're developing with the SX family. Later, Mike |
Mike,
Your right it is a compiler not an interpretor. I use those words interchangibly and I should not. Look at this code example that shows how to have a large array of 64 from an SX28 limited 16 byte array. Although I never quite figured it out how to use it in past applications. Let me know if this helps or not. I have plenty more code examples from Jon Williams (guy that wrote the PDF book - also known as JonnyMac). I zipped it along with all of the others that may be helpfull to you. Look at Big_Array.sxb and WREAD.sxb in particular. Many of the other complete programs have good subroutines in them too. Thanks. |
Tim,
I'll take a closer look at SX/B during the coming week. Meanwhile for your amusement and for those PIC users who may be considering purchasing one of those $12.90 USD 16x32 modules, here's an updated (untested) version of PIC demo software using Swordfish BASIC that features PWM brightness control and an improved performance assembly code ISR driver. Mike Code:
* Name : OEM 16x32 Display v3.BAS *
* Author : Mike McLaren, K8LH *
* Notice : Copyright (c) 2007, Micro Applications Consultants *
* : All Rights Reserved *
* Date : 07/21/07 *
* Version : 3.0 *
* Notes : v3 software features PWM brightness control and an *
* : assembly code ISR driver for improved performance *
Device = 18F2520
Clock = 16
Dim Display(16) As LongWord, ' full 32 bit row size elements
TempRow As LongWord ' temp 32 bit variable
Dim i As Byte, '
Row As Byte, ' row number, range 0..15
Counter As Byte, ' ISR counter var'
RowPos As Word, ' 16 bit row ring counter
Work0, Work1, Work2 As Word ' 16 bit ISR work registers
' scan 1 of 16 rows each 1 msec interrupt '
' 265 cycles, 53.0 usecs, 5.30% ISR processing "overhead" ' '
Interrupt TMR2_Interrupt()
ASM
SR1 equ 0 ;' SR1 pin RB0 (row SR)
SR2 equ 1 ;' SR2 pin RB1 (column 1 SR)
SR3 equ 2 ;' SR3 pin RB2 (column 2 SR)
CLK equ 3 ;' CLK pin RB3 (all SR's)
LAT equ 4 ;' LAT pin RB4 (all SR's)
bcf PIR1,1 ;' clear Timer 2 interrupt flag
rlncf Row,W ;' row number (0..15) x4
rlncf WREG,W ;'
addlw Display ;'
movwf FSR1L ;' FSR1 = Display(Row).byte0
clrf FSR1H ;'
movff POSTINC1,Work0+0
movff POSTINC1,Work0+1
movff POSTINC1,Work1+0
movff POSTINC1,Work1+1
movff RowPos+0,Work2+0
movff RowPos+1,Work2+1
bsf Counter,4 ;' counter = 16
v0 movlw b'00000010' ;' preload WREG
rlcf Work1+0,F ;' rlcf lo byte
rlcf Work1+1,F ;' rlcf hi byte
rlcf WREG,F ;' pick up b2 (2nd column SR)
rlcf Work0+2,F ;' rlcf lo byte
rlcf Work0+3,F ;' rlcf hi byte
rlcf WREG,F ;' pick up b1 (1st column SR)
rlcf Work2+4,F ;' rlcf lo byte
rlcf Work2+5,F ;' rlcf hi byte
rlcf WREG,F ;' pick up b0 (row SR)
movwf LATB ;' update port, [--010ddd]
bsf LATB,CLK ;' toggle <CLK> [--011ddd]
decfsz Counter,F ;' all 16 iterations?
bra v0 ;' no, branch, else
;' latch 48 bits of new SR data onto the driver IC outputs
bcf LATB,LAT ;' toggle <LAT> [--001ddd]
bsf LATB,LAT ;' toggle <LAT> [--011ddd]
;' advance Row variable and RowPos ring counter for the next cycle
incf Row,W ;' Row++
bcf Row,4 ;' Row = Row % 16 (sort of)
rrcf RowPos+0,W ;' rrcf lo byte into W to preserve C
rrcf RowPos+1,F ;' rrcf hi byte
rrcf RowPos+0,F ;' rrcf lo byte
End ASM
End Interrupt
' init PWM sub '
' the STB inputs on all three 16 bit serial-to-parallel drivers '
' should be connected to the RC2/CCP1 "PWM" output '
' the PWM period (and interrupts) are 1.0 msecs. adjust display '
' brightness by setting PWM duty cycle value in CCPR1L; '
' CCPR1L = 50 ' 20% duty cycle, 80% brightness '
' CCPR1L = 100 ' 40% duty cycle, 60% brightness '
' CCPR1L = 150 ' 60% duty cycle, 40% brightness '
' CCPR1L = 250 '100% duty cycle, Display is off '
Sub Init_PWM()
TMR2 = 0 ' clear TMR2 register
PIR1 = 0 ' clear interrupt flags
T2CON = %00000010 ' '00000010'
' '-0000---', postscale 1:1
' '-----0--', TMR2 off
' '------10', prescale 16:1
' for 4-us Timer 2 'ticks'
PR2 = 250 - 1 ' 250 * 4 us = 1 msec PWM period
' and interrupt rate
CCP1CON = %00001100 ' '00001100'
' '00------', unused bits
' '--00----', duty cycle lsb's
' '----1100', PWM mode
CCPR1L = 25 ' 10% duty cycle, 90% brightness
PIE1.1 = 1 ' enable Timer 2 interrupts
INTCON.6 = 1 ' enable peripheral interrupts
T2CON.2 = 1 ' turn on Timer 2
End Sub
' program '
Row = 0 ' init Row
RowPos = %1000000000000000 ' init RowBit ring counter
Counter = 0 ' init ISR counter var'
ADCON1 = %00001111 ' setup RB3..RB0 to digital mode
PORTB = %00010000 ' setup PORTB (SR <LAT> bit hi)
TRISB = %00000000 ' PORTB all outputs
Init_PWM ' init PWM & Timer 2 interrupts
Enable(TMR2_Interrupt) ' enable global interrupts
{ 1st frame }
Display(0) = %11111111111111111111111111111111
Display(1) = %01111111111111111111111111111110
Display(2) = %00111111111111111111111111111100
Display(3) = %00011111111111111111111111111000
Display(4) = %00001111111111111111111111110000
Display(5) = %00000111111111111111111111100000
Display(6) = %00000011111111111111111111000000
Display(7) = %00000001111111111111111110000000
Display(8) = %00000000111111111111111100000000
Display(9) = %00000000011111111111111000000000
Display(10)= %00000000001111111111110000000000
Display(11)= %00000000000111111111100000000000
Display(12)= %00000000000011111111000000000000
Display(13)= %00000000000001111110000000000000
Display(14)= %00000000000000111100000000000000
Display(15)= %00000000000000011000000000000000
{ additional frames }
For i = 0 To 64
TempRow = Display(15) ' save bottom row temporarily
Display(15) = Display(14) ' downward repeating scroll
Display(14) = Display(13)
Display(13) = Display(12)
Display(12) = Display(11)
Display(11) = Display(10)
Display(10) = Display(9)
Display(9) = Display(8)
Display(8) = Display(7)
Display(7) = Display(6)
Display(6) = Display(5)
Display(5) = Display(4)
Display(4) = Display(3)
Display(3) = Display(2)
Display(2) = Display(1)
Display(1) = Display(0)
Display(0) = TempRow
DelayMS(100) ' delay 100 msecs per change
Next
End
Someone wrote me off list to ask about how you might use the PWM brightness control.
To make it a little easier to deal with and perhaps understand I created a subroutine in Swordfish BASIC to adjust the brightness setting which is actually the inverse of the PWM duty cycle. Code:
' Sub Brightness(0..100) 0% black to 100% full brightness '
' 15 cycles, 3.75 usecs (16 MHz), including call and return '
Sub Brightness(pPercent As Byte) ' CCPR1L = (250-(pPercent*2.5))
Dim Temp As Byte '
Temp = pPercent * 2 '
Temp = Temp + (pPercent >> 1) '
CCPR1L = 250 - Temp ' set PWM duty cycle
End Sub '
Brightness(70) ' set brightness to 70% of full Code:
{ display fade-to-black }
i = Level ' copy current 'Level'
While i <> 0 ' fade from 'Level' to black
While Row <> 15 ' sync' to 16 row 'frame'
Wend '
Brightness(i) ' change brightness setting
While Row <> 0 ' wait for row 0
Wend '
i = Integer(i - 5) '
Wend '
Brightness(0) ' force black
Mike,
I thank you for your subroutine but I'm not quite following how it is to be applied in the Main routine. I would think brightness is controlled by the current limiting resistors so how is the Brightness control to be applied via software? Thanks again. |
Not sure where to refer you for study and you already know I'm not very good at explaining things. |
| Problem with LCD code? | spondootre | Micro Controllers | 15 | 29th April 2008 09:15 AM |
| microchip application A590 /display is ok now | prosound90 | Micro Controllers | 20 | 18th November 2006 09:44 PM |
| Display Driver for 16 * 16 matrix display | pmphilip | General Electronics Chat | 2 | 4th January 2006 07:14 PM |
| Datasheet for display driver for LM-1256(MATRIX DISPLAY) | pmphilip | Datasheet/Parts Requests | 1 | 25th January 2005 07:25 PM |
