Hey guys.. I'm using a PIC16F877A to control a Pololu serial motor controller. I'm coding in ASM and sometimes it just refuses to work.. Sometimes the motor controllers LEDs do not light(and nothing happens) and sometimes is works perfectly.. I can usually get it working by unplugging the motor controller and plugging it back in several times(with the pic still running) or by resetting the pic but its very annoying and sometimes is still doesnt work after that. I'm also using an EasyPic4 to program the PIC and I leave the PIC in the Dev board and hook the motor controller up to the same supply and such using the headers on the board.. (Hacky / wires running everywhere) I really do not know much about serial communication at all.. I read about how to setup the baud generator and use the serial line on the PIC all from the datasheet and I used the motor controllers datasheet to get the protocol the controller expects but thats about all I know so far.. My code is quite hacked up but here it is.. Code: ;***********************************************;
; First PIC program ;
; Implented a Motor Controller ;
;Testing and Simulation
LIST P=PIC16F877A ;tell assembler what chip we are using
include "P16F877A.inc" ;include the defaults for the chip
__config 0x3D18 ;sets the configuration settings
;(oscillator type etc.)
;****** Variables **************************************************************
TEMPW EQU H'20' ;This is the start of the General Registers.
Motor0 EQU H'21' ; Motor0 speed
Motor1 EQU H'22' ; Motor1 speed
CurMtr0 EQU H'23' ; Current Motor0 speed
CurMtr1 EQU H'24' ; Current Motor1 speed
count1 EQU H'25' ; Delay Variables.
counta EQU H'26'
countb EQU H'27'
reverse EQU H'28' ;Reverse flag
org 0x0000 ;org sets the origin, 0x0000
goto main ;this is where the program starts running
org 0x0004 ;org sets the origin, 0x0004
goto IntH ;this is where interrupts are vectored
main
bsf STATUS, RP0 ;set RP0
bcf STATUS, RP1 ;clear RP1 This selects Bank 1
movlw b'00000000' ;Set all ports to output
movwf TRISE
movwf TRISD
movwf TRISC
movwf TRISB
movwf TRISA
bsf TRISB, 0 ; Using RB0/INT as interrupt here.
bcf OPTION_REG, T0CS ; Use interal CS for T0
bsf OPTION_REG, INTEDG ; Interrupt Edge trigger.
bsf INTCON, GIE ;Global Interrupt Enable (set)
bsf INTCON, INTE ;External Interrupt Enabel (set)
bcf INTCON, INTF ;External Intterupt flag
movlw d'20'
movwf SPBRG ;Set the baud rate.
bcf TXSTA, TX9 ;8bit transmission
bsf TXSTA, TXEN ;Transmit Enable bit
bcf TXSTA, SYNC ;Asynchro mode idk?
bcf TXSTA, BRGH ;low speed baud rate
bcf STATUS, RP0 ;clear RP0
bcf STATUS, RP1 ;clear RP1 This will select bank 0
bsf RCSTA, SPEN ;Serial Port Enable. Do I need this? sure..
bcf RCSTA, RX9 ;8bit receive
bcf RCSTA, CREN ;Continous Receive disable
movlw 0x00 ;Set the current speed for M0
movwf CurMtr0 ;Set the current speed for M1
movwf CurMtr1
movlw 0x30 ;Set the default speed for M0
movwf Motor0 ;Set the default speed for M1
movwf Motor1
movlw 0x00 ;Set the reverse flag (defualt: forward)
movwf reverse
movlw 0x00
movwf PORTA
movwf PORTB
movwf PORTC
movwf PORTD
movwf PORTE
call Delay ; Let motor controller initialize
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
movlw b'00000001' ;Set A0 on
movwf PORTA
Loop
; movlw 0xff
; movwf PORTA
movlw b'01111111' ;Set the default speed for M0
movwf Motor1
call Forward ; Update the motor speeds if needed
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
;; movlw 0x00
;; movwf PORTA
movlw b'00000000' ;Set the default speed for M0
movwf Motor1
call Forward
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
goto Loop ;go back and do it again
Forward
movlw 0x00 ;Go forward
movwf reverse
call UpdateMotors ; Update the motor speeds if needed
return
;Reverse
; movlw 0x01 ; Reverse
; movwf reverse
; call UpdateMotors ; Update the motor speeds if needed
; return
UpdateMotors ;Check to see if we want the speed changed. If so, Change it.
updm0
movfw CurMtr0 ; Current motor speed in W
xorwf Motor0, 0 ; Xor Current motor speed with wanted motor speed
btfsc STATUS, Z ;Test if the last operation resulted in 0
goto updm1 ;Skip to motor1 check if we dont need to update M0
call SerStart
movlw b'0000001'
subwf reverse,0
movwf TXREG
call SerChk
movfw Motor0
movwf TXREG
movwf CurMtr0
updm1
movfw CurMtr1 ; Current motor speed in W
xorwf Motor1, 0 ; Xor Current motor speed with wanted motor speed
return ;Return if we dont need to update M1
call SerStart
movlw b'0000011'
subwf reverse,0
movwf TXREG
call SerChk
movfw Motor1
movwf TXREG
movwf CurMtr1
return
SerStart
call SerChk
movlw 0x80
movwf TXREG
call SerChk
movlw 0x00
movwf TXREG
call SerChk
return
SerChk
btfss PIR1, TXIF ;Test if the data has been sent to buffer
goto $-1 ;Does this work?
return
Delay
movlw d'250' ;delay 250 ms (4 MHz clock)
movwf count1
d1 movlw 0xC7
movwf counta
movlw 0x01
movwf countb
Delay_0
decfsz counta, f
goto $+2
decfsz countb, f
goto Delay_0
decfsz count1 ,f
goto d1
return
;----Our Interrupt Handler will go here.----;
IntH
movwf TEMPW
nop
nop
nop
nop
bcf INTCON, INTF ;Lets set thing back..
movfw TEMPW ;Restore w
RETFIE
end
What config' fuse settings are you using? There's really no easy way for us to tell from your __config 0x3D18 statement.
OSC is HS Everything else is disabled (watch dog, power up, brown out, etc.) | |
| | #4 | |
Check the least sig bits of the config word. HS or LP? Are you using a 20MHz xtal? | ||
The config word is entirely wrong, for HS (and nothing else) it should be 0x290A for a 16F877A.
| | #6 |
Rather than using the lazy shorthand way of writing the Config word, as 0x290A, I would use the method recommended my microchip, in their templates. It makes it easier for members to identify errors in the Config. Example: __CONFIG _CP_OFF & _DEBUG_OFF & _WDT_OFF & _BODEN_OFF & _PWRTE_ON & _HS_OSC & _WRT_OFF & _LVP_OFF & _CPD_OFF | |
| | #7 |
The config word is the remanence of using a template. I manually change the OCS to HS before I assemble. I will switch over to the template config word definitions(?). I'm using an 8mhz xtal and I'm pretty sure I've set the correct baud rate for this. Is there any config bits I specifically need for serial comm? Thanks for the help guys.. Any other tips? | |
| | #8 | |
Whats the expected baud rate of the USART? You are setting BRGH=0 and SPBRG as decimal 20, with a 8MHz xtal? Looking at page 114 of the datasheet I cannot find a correlation between the 4MHz xtal table and 8MHz that gives s SPBRG of d20? EDIT: If I am doing the sums correctly, for an assumed baud rate of 9600, SPBRG should be d12 ??? Last edited by ericgibbs; 28th June 2007 at 09:00 AM. | ||
| | #9 |
Using the formula given on page 115 in the datasheet "(Asynchronous) Baud Rate = FOSC/(64 (X + 1))" 8/(64(20+1)) = 5952 8/(64(12+1)) = 9615 So yeah. Your right :-p I'm not sure how I messed that up.. I used the formula last time but oh well.. I've tried several different baud rates.. and the result was no better but I will try this and see how things go and report back.. Thanks eric | |
| | #10 |
I cant even get it to work at all now.. SPBRG = 12d and the PIC is working.. I can see the led light up when the delay for the motor controller is initialized.. If I hook LEDs up to the serial lines.. C7 flashes slowly (Recieve line for serial) and C6(TX line) stays constant.. If I place a multimeter to the serial line that goes to the motor controller I can see a constant 5.5v with slight drops to 5v that seems to be timed when the bytes are sent to the controller.. I'm not sure if that helps you guys at all.. thats all I know.. and the controller isnt working at all now.. | |
| | #11 | |
Whats baud rate and other settings is the controller expecting? eg: 9600 baud, no parity, 8 data bits, 1stop bit etc............ Do you have a web link to pololu controller? Eric | ||
| | #12 |
| http://www.pololu.com/products/polol...c05a_guide.pdf Page 6 is the serial format the motor controller expects.. | |
| | #13 | |
On page #3 of the spec sheet, which type of connection are you using between the 877A and the controller for the serial connection.?? Is it pin #4 of the group of 9 or the 3 pins at the top of the pcb? Page #6, say any baud rate within the range specified will be autodetected. 8 bit data, no parity, 1 stop bit. | ||
| | #14 |
I'm using the serial input(pin 4).
| | #15 | |
Thats the option without a MAX232 line driver you are using. I will re-run your program tomorrow in the PIC sim and try to program a PIC and hang my laptop on the RS232 line. I'll have to use a 16F877, dont have an 'A' version. Will change the config to suit. If you crack the problem. let me know and I get on with something else. Eric | ||
| comm, controllers, motor, serial |
| Need help badly on Inchworm and MPLAB | thushy | Micro Controllers | 14 | 11th March 2007 07:05 PM |
| VB serial comm... toooooo slow | Ascari | Micro Controllers | 11 | 27th October 2006 02:28 PM |
| GPS NMEA-0183 serial comm | Oznog | Micro Controllers | 9 | 11th August 2006 08:33 PM |
| sync serial comm. | shanr | Electronic Projects Design/Ideas/Reviews | 4 | 24th September 2004 04:30 PM |
| I NEED CODE FOR 8051 SERIAl comm..PLSSS HELP | kumar_3k | 8051/8951 | 2 | 3rd January 2004 03:30 AM |
