hi i have a problem . when i setb some pins connected to a lcd or a relay nothing happen . ? i guess the problem in the output current so is there any way to get more current when i set the pins !?. i checked it wid a led and it works properly but not with the device it self . !!!!!!!
Oh btw i tried a transistor and pull up resistor . it only works wid a photo coupler ic. or 2 inverters in sequence . which will make the pcb large and not logical solution in fact :S .
Please post some schematics as it's hard to visualise what you're talking about.
You do need a transistor buffer to operate the relay but you also need a diode in reverse parallel with the relay to absorb the back EMF. ![]() http://www.uoguelph.ca/~antoon/gadge...ys/relays.html There's nothing critical anout this circuit, here's another example. ![]()
I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez Last edited by Hero999; 24th June 2007 at 09:34 AM. |
umm For example i want to connect the lcd with the micro controller. so nothing would happen if i connect it directly to the ports. but if i put the 2 inverters which leads to the same output it works :S so i guess the problem in the current coz the voltage is ok . i tested it with a led and it is right .also it works when i put 2 inverters in sequence .
That's nice but without a schematic, it's hard for us to help you.
schematic for what ?! it is at89c51 and p1 is output for the lcd and there is p2.0 to p2.2 3 control pins for enable and read and write . but when i connect them to the microcontroller pins no output . but when i put 2 inverters to give the same output as if i just get from the uc it gets output .
If u need schematic tell me what schematic u want.
When talking about the relay give the schematic with the uC and relay. Unless you are using a tiny relay with a low current coil you need a transistor. The LCD does not require much current but can be hooked up several different ways. Again the schematic. You can draw simple schematics using a paint program. Or if you want to get a leg up on making PCBs use Eagle's schematic editor. It has an export function that allows you to create an image you can post.
search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, Homepage The 15 Minute Printed Circuit Board! (+drill time) |
So far, I've only used ATTiny... but doesn't the LCD need 5v logic levels? Relay needs a driver. What's you power source? Regulated? Decoupling capacitor? Got a diode across the relay? A schematic of your circuit would have answered all these questions and more.
I usually simulate a circuit on the computer before I build, but my program doesn't do MCUs, so I do a quick sloppy sketch to keep my pins straight while wiring it up on the breadboard. I've gotten help here just off a scan of the sketch, and many times from poor digital photos. The LCD may not be intialized proper, wrong clock or delays. Contrast might not be set, backlight... You most understand that without pictures, and very few details, its tough to visualize what you have done, and to see what went wrong. |
Eng.Remon:
LCD's have more conditions compared to a Relay to be properly driven and high current on the logic lines is not one of them. 1. Do you mean the LCD backlight leds are working with the addition of 2 inverters? 2. Are you monitoring the voltage out the microcontroller pins with a voltmeter or o-scope and the LCD load unattached and attached? |
donniedj yea it deos. and i monitory the voltage on the pins of uc using voltmeter and it is around 4 to 5 volt . i ll try to attache the schema which works wid .
| Expert Stabilised Power Supply with Current Limiting | mechie | Electronic Projects | 36 | 11th March 2008 07:16 PM |
| TC4427A (H-bridge), Output current, Long term | Halo | Electronic Projects Design/Ideas/Reviews | 1 | 6th March 2007 06:58 PM |
| Adjustable Current Output | moctod | Electronic Projects Design/Ideas/Reviews | 8 | 20th February 2007 01:55 AM |
| Headphone current limit | Oznog | Electronic Projects Design/Ideas/Reviews | 2 | 8th May 2006 02:39 PM |
| Variable current output... | Night Thrasher | Electronic Projects Design/Ideas/Reviews | 2 | 19th March 2004 02:21 PM |
