| This code program W EQU 0 F EQU 1 Z EQU 2 ZERO EQU 2 C EQU 0 CARRY EQU 0 GPWUF EQU 7 ;======================== SW0 EQU 0 ;switch names SW1 EQU 1 SW2 EQU 3 SW3 EQU 4 TFlag EQU 7 ;bit numbers for flags DBTime EQU 12 ;======================== ; endef regester ;======================== INDF EQU H'00' TMR0 EQU H'01' PCL EQU H'02' STATUS EQU H'03' FSR EQU H'04' OSCCAL EQU H'05' GPIO EQU H'06' ;======================= SleepT EQU H'07' ; inactivity counter to allow sleep Flags EQU H'08' ; storage space for messages ThisSw EQU H'09' ; current switch status ;======================= ; switch0 LastSw0 EQU H'0A' ; last value - for detecting change SwState0 EQU H'0B' ; the official (debounced) status DBTimer0 EQU H'0C' ; counter used during debouncing of the switch ; switch1 LastSw0 EQU H'0D' ; " " SwState0 EQU H'0E' ; " " DBTimer0 EQU H'0F' ; " " ; switch2 LastSw0 EQU H'10' ; " " SwState0 EQU H'11' ; " " DBTimer0 EQU H'12' ; " " ; switch3 LastSw0 EQU H'13' ; " " SwState0 EQU H'14' ; " " DBTimer0 EQU H'15' ; " " ;===================== ORG H'0200' ID0 Data H'0000' ID1 Data H'0000' ID2 Data H'0000' ID3 Data H'0003' ;===================== ; MCLRDisabled, NoCodeProtect, NoWatchDog, IntRCOsc ORG H'0FFF' CONFIG Data H'000A' ;===================== ORG H'00' MOVWF OSCCAL ; store the factory osc. calibration value Start CLRWDT ; setting up options MOVLW B'00000010' ; use int clock input, /8 prescaler OPTION ; pullups on, and wakeup on pin change BTFSS STATUS,GPWUF ; don't change outputs on a wakeup CLRF GPIO ; but output 0s on a powerup MOVLW B'00011011' ; GP0, GP1 , GP3 and GP4 are inputs TRIS GPIO ; GP2, GP5 are outputs CLRF SleepT CLRF Flags CLRF DBTimer0 CLRF DBTimer1 CLRF DBTimer2 CLRF DBTimer3 BTFSC STATUS,GPWUF ; on wakeup, don't change the switch states GOTO Main CLRF LastSw0 ; but if it's a powerup, CLRF SwState0 ; assume they're all off (open) CLRF LastSw1 CLRF SwState1 CLRF LastSw2 CLRF SwState2 CLRF LastSw3 CLRF SwState3 ;================== Main CALL DoTime ; need clock 'running'for debounce CALL Switch0 ; check switch0 position, CALL Switch1 ; then switch1, CALL Switch2 ; then switch2, CALL Switch3 ; and switch2 CLRW ; assume no switch is pressed MOVF SwState0,F ; check the state of sw0 BTFSS STATUS,Zero ; do nothing if it's not pressed IORLW B'00000100' ; else set GP2 high MOVF SwState1,F ; same for sw1 BTFSS STATUS,Zero ; do nothing if it's not pressed IORLW B'00000100' ; output on GP2 MOVF SwState2,F ; same for sw2 BTFSS STATUS,Zero ; do nothing if it's not pressed IORLW B'00100000' ; output on GP5 MOVF SwState3,F ; and sw3 BTFSS STATUS,Zero ; do nothing if it's not pressed IORLW B'00100000' ; with output on GP5 MOVWF GPIO GOTO Main ;================= ; DoTime DoTime BTFSS TMR0,7 ; high bit of timer set? GOTO dt1 ; no - we've overflowed BSF Flags,TFlag ; yes, set the flag RETLW 0 dt1 BTFSS Flags,TFlag ; have the timers been serviced? RETLW 0 ; yes INCF DBTimer0,F INCF DBTimer1,F ; no, increment all the timers INCF DBTimer2,F INCF SleepT,F BCF Flags,TFlag ; reset the service flag, and BTFSS STATUS,Zero ; see if the sleep timer has overflowed RETLW 1 ; There's been no activity for 256*2mS, it's time to sleep MOVF GPIO,W ; read the current pin status SLEEP ; and good night ;================== ; Switch0 ; GP0 Switch0 CLRF ThisSw ; assume switch is not pressed BTFSS GPIO,Sw0 ; check sw status INCF ThisSw,F ; the sw was pressed ; Compare to last state MOVF LastSw0,W XORWF ThisSw,W BTFSS STATUS,Zero ; Zero is set if there's been no change. ; No change since last scan, but are we in a debounce phase? GOTO sw01 MOVF SwState0,W XORWF ThisSw,W ; compare present state of sw to the official state BTFSC STATUS,Zero ; Zero is Clr if they differ (we're in debounce) GOTO sw02 ; Switch is changing, have we gone past the debounce time? MOVLW DBTime ; get the debounce time SUBWF DBTimer0,W ; and compare to elapsed BTFSS STATUS,Carry ; Carry is set if DBTimer >= DBTicks GOTO sw02 ; we've exceeded the debounce time - change the official state of the switch MOVWF SwState0 ; store current state in SwState GOTO sw02 ; the switch input is changing state - prepare to debounce sw01 MOVF ThisSw,W MOVWF LastSw0 ; remember this passes' state CLRF SleepT ; we've had activity - reset the sleep timer CLRF DBTimer0 ; and reset the debounce timer ; we're done for this pass... sw02 BTFSS SwState0,0 ; check the switch state, and RETLW 0 ; return with 0 if not pressed, RETLW 1 ; 1 if pressed ; ********************************************* ; Switch1 ; GP1 Switch1 CLRF ThisSw ; assume switch is not pressed BTFSS GPIO,Sw1 ; check sw status INCF ThisSw,F ; the sw was pressed ; Compare to last state MOVF LastSw1,W XORWF ThisSw,W BTFSS STATUS,Zero ; Zero is set if there's been no change GOTO sw11 ; No change since last scan, but are we in a debounce phase? MOVF SwState1,W XORWF ThisSw,W ; compare present state of sw to the official state BTFSC STATUS,Zero ; Zero is Clr if they differ (we're in debounce) GOTO sw12 ; Switch is changing, have we gone past the debounce time? MOVLW DBTime ; get the debounce time SUBWF DBTimer1,W ; and compare to elapsed BTFSS STATUS,Carry ; Carry is set if DBTimer >= DBTicks GOTO sw12 ; we've exceeded the debounce time - change the official state of the switch MOVF ThisSw,W MOVWF SwState1 ; store current state in SwState GOTO sw12 ; the switch input is changing state - prepare to debounce sw11 MOVF ThisSw,W MOVWF LastSw1 ; remember this passes' state. CLRF SleepT ; we've had activity - reset the sleep timer CLRF DBTimer1 ; and reset the debounce timer ; we're done for this pass... sw12 BTFSS SwState1,0 ; check the switch state, and RETLW 0 ; return with 0 if not pressed, RETLW 1 ; 1 if pressed ; ********************************************* ; Switch2 ; GP3 Switch2 CLRF ThisSw ; assume switch is not pressed BTFSS GPIO,Sw2 ; check sw status INCF ThisSw,F ; the sw was pressed ; Compare to last state MOVF LastSw2,W XORWF ThisSw,W BTFSS STATUS,Zero ; Zero is set if there's been no change GOTO sw21 ; No change since last scan, but are we in a debounce phase? MOVF SwState2,W XORWF ThisSw,W ; compare present state of sw to the official state BTFSC STATUS,Zero ; Zero is Clr if they differ (we're in debounce) GOTO sw22 ; Switch is changing, have we gone past the debounce time? MOVLW DBTime ; get the debounce time SUBWF DBTimer2,W ; and compare to elapsed BTFSS STATUS,Carry ; Carry is set if DBTimer >= DBTicks GOTO sw22 ; we've exceeded the debounce time - change the official state of the switch MOVF ThisSw,W MOVWF SwState2 ; store current state in SwState GOTO sw22 ; the switch input is changing state - prepare to debounce sw21 MOVF ThisSw,W MOVWF LastSw2 ; remember this passes' state CLRF SleepT ; we've had activity - reset the sleep timer CLRF DBTimer2 ; and reset the debounce timer ; we're done for this pass... sw22 BTFSS SwState2,0 ; check the switch state, and RETLW 0 ; return with 0 if not pressed, RETLW 1 ; 1 if pressed ; ********************************************* ; Switch3 ; GP4 Switch3 CLRF ThisSw ; assume switch is not pressed BTFSS GPIO,Sw3 ; check sw status INCF ThisSw,F ; the sw was pressed ; Compare to last state MOVF LastSw3,W XORWF ThisSw,W BTFSS STATUS,Zero ; Zero is set if there's been no change GOTO sw31 ; No change since last scan, but are we in a debounce phase? MOVF SwState3,W XORWF ThisSw,W ; compare present state of sw to the official state BTFSC STATUS,Zero ; Zero is Clr if they differ (we're in debounce) GOTO sw32 ; Switch is changing, have we gone past the debounce time? MOVLW DBTime ; get the debounce time SUBWF DBTimer3,W ; and compare to elapsed BTFSS STATUS,Carry ; Carry is set if DBTimer >= DBTicks GOTO sw32 ; we've exceeded the debounce time - change the official state of the switch MOVF ThisSw,W MOVWF SwState3 ; store current state in SwState GOTO sw32 ; the switch input is changing state - prepare to debounce sw31 MOVF ThisSw,W MOVWF LastSw3 ; remember this passes' state CLRF SleepT ; we've had activity - reset the sleep timer CLRF DBTimer3 ; and reset the debounce timer ; we're done for this pass... sw33 BTFSS SwState3,0 ; check the switch state, and RETLW 0 ; return with 0 if not pressed, RETLW 1 ; 1 if pressed END | |
| I correct mistakes were evaluated and a new program even know what mistakes Thank you | |
This looks curiously identical to: http://www.nalanda.nitc.ac.in/indust...itch/2_003.pdf Yet no reference is made to credit the original coder...hmmmm Last edited by Norlin; 4th June 2007 at 06:56 PM. | |
| Thank you Norlin I want to put the results GP2 And GP5 In other words SW1 OR SW2 = GP2 SW3 OR SW4 = GP5 Last edited by abdosat2000; 4th June 2007 at 07:12 PM. | |
| | #6 |
Hi, Shouldn't the inputs GP0, GP1, GP3 and GP4 be connected by pull up resistors?
__________________ bananasiong | |
| | #7 |
It uses the internal weak pullups. Mike. | |
| | #8 | |
I usually use pull down and make it to be active high input. Thanks
__________________ bananasiong Last edited by bananasiong; 5th June 2007 at 09:33 AM. | ||
| | #9 |
Thank you, I want to correct the mistakes and I will do compared them
| | #10 |
I am new in the programming of Pic Please help me and thank you | |
| code, writing |
| Accessing EEPROM | Clayton | Micro Controllers | 15 | 23rd March 2007 04:00 AM |
| Need some help with a code provided by ATMEL | ikalogic | Micro Controllers | 1 | 23rd January 2007 03:46 PM |
| Question on writing code for PIC | johnnyquest | Micro Controllers | 3 | 21st December 2004 01:05 PM |
| Tough assembly program for the PIC16F84 | asmpic | Micro Controllers | 34 | 3rd December 2004 07:50 PM |
| An error in pic16f84a, why? | Zener_Diode | Micro Controllers | 6 | 11th April 2004 03:55 AM |
