| Notices |
| | (permalink (permalink)) |
| hi i'm trying to interface DS1307RTC with PIC16f877. I had done interfacing of ds1307 with 89c51 and was sucessful. i have modified the same code a bit for PIC16f877 but this isn't working i'm unable to find out the problem, please help me. One thing more, in 89c51 code i had written " unsigned char ReadI2Crtc(bit ACK_Bit)" but in pic it gave error: "bit variable must be global or static" so i changed it to "unsigned char ReadI2Crtc(unsigned char ACK_Bit)" is this causing the problem. Please help me....It's really very urgent. thanks a lot. #define PORTBIT(adr, bit) ((unsigned)(&adr)*8+(bit)) static bit SDA @ PORTBIT(PORTB,7); static bit SCL @ PORTBIT(PORTB,6); ///////////////////////////////////////////////////////////////////////////////////////// /////////////////////////////////////////////////////////////////////////////////////////////// /////////////////////////////////////////////////////////////////////////////////////////////// /////////////////////////////////////////////////////////////////////////////////////////////// //------------------------------- // StartRTC I2C //------------------------------- void StartRTC(void) { SDA = 1; SCL = 1; DelayUs(5);DelayUs(5); SDA = 0; DelayUs(5);DelayUs(5); SCL = 0; DelayUs(5);DelayUs(5); } //------------------------------- // StopRTC I2C //------------------------------- void StopRTC(void) { SDA = 0; DelayUs(5);DelayUs(5); SCL = 1; DelayUs(5);DelayUs(5); SDA = 1; } //------------------------------- // Write I2C //------------------------------- void WriteI2Crtc(unsigned char Data) { for (i3=0;i3<8;i3++) { SDA = (Data & 0x80) ? 1:0; SCL=1;SCL=0; Data<<=1; } SCL = 1; DelayUs(5);DelayUs(5); SCL = 0; } //------------------------------- // Read I2C //------------------------------- unsigned char ReadI2Crtc(unsigned char ACK_Bit) { unsigned char Data=0; SDA = 1; for (i3=0;i3<8;i3++) { SCL = 1; Data<<= 1; Data = (Data | SDA); SCL = 0; DelayUs(5); } if (ACK_Bit == 1) SDA = 0; // Send ACK else SDA = 1; // Send NO ACK DelayUs(5);DelayUs(5); SCL = 1; DelayUs(5);DelayUs(5); SCL = 0; return Data; } //------------------------------- // Read 1 byte form I2C //------------------------------- unsigned char ReadRTC(unsigned int Addr) { unsigned char Data; StartRTC(); WriteI2Crtc(0xD0); //WriteI2Crtc((unsigned char)(Addr>>8)&0xFF); // ....not valid for small EEPROMs WriteI2Crtc((unsigned char)Addr&0xFF); StartRTC(); WriteI2Crtc(0xD1); Data = ReadI2Crtc(NO_ACK); StopRTC(); return(Data); } //------------------------------- // Write 1 byte to I2C //------------------------------- void WriteRTC(unsigned int Addr,unsigned char Data) { StartRTC(); WriteI2Crtc(0xD0); //WriteI2Crtc((unsigned char)(Addr>>8)&0xFF); // send address high....not valid for small EEPROMs WriteI2Crtc((unsigned char)Addr&0xFF); // send address low WriteI2Crtc(Data); StopRTC(); } void ReadAllRTC(void) { Minutes=ReadRTC(0x01); Minutes=((Minutes & 0xF0)>>4)* 10 + (Minutes & 0x0F); Hours=ReadRTC(0x02) & 0x1F; Hours=((Hours & 0xF0)>>4)* 10 + (Hours & 0x0F); AmPm=(ReadRTC(0x02) & 0x20)>>5; } /////////////////////////////////////////////////////////////////////////////////////////////// /////////////////////////////////////////////////////////////////////////////////////////////// /////////////////////////////////////////////////////////////////////////////////////////////// /////////////////////////////////////////////////////////////////////////////////////////////// main() . . . . . . ReadAllRTC(); . . . . . | |
| Written With Proton PDS The DS1307 is a great piece of kit, it provides real time date and clock values, and interfaces with the PIC micro via I2C. The values it holds for date/time are, Secs, Mins, Hours, Day, Date, Month and Year Example of interfacing with a DS1307. Note that on the DS1037 Pin 8 is connected to 5V, Pin 4 is connected to GND and Pin 3 is connected to ground if no backup battery is used! Click here too watch this circuit in action! Code: Device = 16F876
Xtal = 4
ALL_DIGITAL = True
PORTB_PULLUPS = True
' Setup the LCD
LCD_DTPIN = PORTB.4
LCD_RSPIN = PORTB.2
LCD_ENPIN = PORTB.3
LCD_INTERFACE = 4
LCD_LINES = 2
LCD_TYPE = 0
' Define I2C bus ports
SDA_Pin = PORTA.0 'DS1307 SDA pin
SCL_PIN =PORTA.1 'DS1307 SCL pin
Dim Temp1 As Byte
Dim Temp2 As Byte
Dim TempVal As Byte
Dim Secs As Byte
Dim Mins As Byte
Dim Hrs As Byte
Dim day As Byte
Dim Date As Byte
Dim Month As Byte
Dim Year As Byte
Dim Ctrl As Byte
Dim Secs_last As Byte
'Initialize LCD
Delayms 100
Cls
' Set initial DS1307 time / Date
Secs = 0 ' Set seconds
Mins = 30 ' Set minutes
Hrs = 12 ' Set hours
Day = 1 ' Set day of week value
Date = 30 ' Day of month value
Month = 11 ' Month value
Year = 6 ' Year value
Ctrl = 0 ' Set the control byte (leave as 0 in this example)
' The DS1307 works with data in BCD format, so convert BIN to BCD
TempVal=Secs
GoSub BIN_TO_BCD
Secs=TempVal
TempVal=Mins
GoSub BIN_TO_BCD
Mins=TempVal
TempVal=Hrs
GoSub BIN_TO_BCD
Hrs=TempVal
TempVal=Day
GoSub BIN_TO_BCD
Day=TempVal
TempVal=Date
GoSub BIN_TO_BCD
Date=TempVal
TempVal=Month
GoSub BIN_TO_BCD
Month=TempVal
TempVal=Year
GoSub BIN_TO_BCD
Year=TempVal
BStart
' The datasheet specifies the first byte is 1101000x where x is read(1) or write(0).
' The second byte tells the DS 1307 where to start reading, 0 is at the start.
' The Ctrl byte contains advanced features, read the datasheet for more info
Busout 11010000, 0, [Secs, Mins, Hrs, day, Date, Month, Year, Ctrl] 'Write initial values for time / Date
BStop
Delayms 20
Main:
BStart
BusIn 11010001, 0, [Secs, Mins, Hrs, day, Date, Month, Year, Ctrl]
BStop
' The DS1307 sends it data in BCD, therefore it must be changed to
' BIN so that it can be easily used (eg, print onto an LCD)
TempVal=Secs
GoSub BCD_TO_BIN
Secs=TempVal
TempVal=Mins
GoSub BCD_TO_BIN
Mins=TempVal
TempVal=Hrs
GoSub BCD_TO_BIN
Hrs=TempVal
TempVal=Date
GoSub BCD_TO_BIN
Date=TempVal
TempVal=Month
GoSub BCD_TO_BIN
Month=TempVal
TempVal=Year
GoSub BCD_TO_BIN
Year=TempVal
If Secs - Secs_last = 0 Then Goto Main 'If there is update in Secs, display time and Date
' The Dec2 modifier makes sure that each value will have 2 characters, eg 1 becomes 01
Print At 1,1,"Time: ",Dec2 Hrs, ":", Dec2 Mins,":", Dec2 Secs
Print At 2,1,"Date: ", Dec2 Date, "-", Dec2 Month, "-", Dec2 Year
Secs_last = Secs
Goto Main
BCD_TO_BIN: ' Convert the BCD values into BIN
Temp1 = $0F & TempVal ' Clear off the top four bits
Temp1 = DIG Temp1, 0
Temp2 = TempVal >> 4 ' Shift down four to read 2 BCD value
Temp2 = DIG Temp2, 0
TempVal = Temp2 * 10 + Temp1
Return
BIN_TO_BCD:
Temp1 = Dig TempVal, 0 ' GET THE DEC DIGIT FOR THE FIRST NIBBLE
Temp2 = Dig TempVal, 1 ' GET THE DEC DIGIT FOR THE FIRST NIBBLE
Temp2 = Temp2 << 4 ' MOVE NUMBER OVER TO 2ND NIBBLE
TempVal = Temp1 ^ Temp2 ' XOR THEM TOGTHER TO MAKE THE WHOLE BCD NUMBER
Return
__________________ Spency. PIC Micro's - Your mind is the limit PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net | |
| Thanks a Lot Mike for replying. I'm using hitech picc. I tried defining sda and scl as: volatile bit SDA @ PORTBIT(PORTB,7); volatile bit SCL @ PORTBIT(PORTB,6); & #define NO_ACK 0 #define ACK 1 but still nothing is happening. If i set PORTB=0x00 i get minutes = 0 and if i set PORTB=0xFF i get minutes = 165.........i'm helpless please help me out.....Thankss once again Last edited by neelam29; 1st June 2007 at 07:26 AM. | |
| Read the datasheet! - like I said above though, you really need a reasonable knowledge of assembler to use a C compiler - you can't expect to move to a PIC (or any new controller) without studying the datasheet, and having some knowledge of what you're doing. You might try loking at PIC C sites?, presumably the manufacturer of your compiler has one?, check their examples - but you will only blindly be following something you don't understand!. | |
__________________ Spency. PIC Micro's - Your mind is the limit PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net | ||
| what kinda compiler are you using that you've written your own i2c routines? I know microchip C18 has libraries with hardware and software i2c routines, and so does MikroC
__________________ If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 | |
| Connecting DS1307 to PIC16F877A | amindzo | Micro Controllers | 14 | 20th May 2007 01:11 PM |
| ICSP doesnt work - PIC16F877A, PIC16F628A | hitman47 | Micro Controllers | 1 | 21st February 2007 07:48 AM |
| What is the best C Compiler for PIC16F877A? | dimastar85 | Micro Controllers | 14 | 23rd December 2006 10:21 PM |
| PIC16f877A Project help | Alex Ng | Micro Controllers | 5 | 26th July 2006 07:47 AM |
| PIC and DS1307 | huanyong | Micro Controllers | 1 | 6th November 2003 09:25 AM |
