Old 31st May 2007, 06:26 AM   #1
Default microcontroller selection
I'm selecting a microcontroller to process input data from other external circuits and store text data for 2 or 3 days at each storage run. I also need the microcontroller to be low power-consuming as I need a selected battery to supply enough power to the microcontroller to last at least 2 or 3 days. I'm basically confused about the specifications that I need to look for in a microcontroller. From my understanding, microcontrollers are selected based on CPU speed, ROM/other storage capacity, amount of I/O ports and A/D converters, power consumption, and price. Can anyone suggest any more specifications that I need to look for?
ssylee is offline
Old 31st May 2007, 09:02 AM   #2
Vdd vs. Clock frequency: if you decide the voltage, the maximum clock frequency specification must be met. For example: uC=PIC12F629, Vdd=3 V, fmax=10 MHz.
eng1 is offline
Old 31st May 2007, 09:14 AM   #3
What will be the size of the stored text files?
What limitations do you have on the battery voltage/capacity?
Are the input data rates high and do they require lots of data processing?
Do you require RS232 or other type of communication with a remote PC?
Power consumption and price will be controlled by the requirements, as above.
Let us have more detail on the questions asked, I am sure we could recommend a range of PIC devices.
Regards
ericgibbs is offline
Old 31st May 2007, 08:09 PM   #4
Make a list of what you need the microcontroller to do and then start searching. Open atmel.com and look the AVR's (8 bit micros). you can most definitely find what you need from there.
Need Help?
Press F1
If that doesn\'t help you, ask me... I might know better.
bloody-orc is offline
Old 1st June 2007, 10:11 AM   #5
Stored text files would be around 64 to 128 kb.
Battery voltage and capacity either follow the off-the-shelf ones or follow custom-made rechargeable batteries
Lots of data processing isn't really required, but input data rate could be quite high.
I either need to plug in RS232 or better yet, just plug it into usb.
ssylee is offline
Old 1st June 2007, 10:30 AM   #6
hi ssylee,
I will have a look thru the PIC specs and get back to you.
It looks like it will be a 18Fxxxx device with USB, the storage capacity of 128Kb maybe a problem, you may require extra flash storage.
A good site to browse thru is www.microchip.com
If you want to include a previous post in your reply, use the 'Quote' reply option.
Regards
Old 1st June 2007, 10:40 AM   #7
The PIC 18F2455 has USB.
For extra storage space the 24FC512 CMOS serial EEPROM.
Download the datasheets from www.microchip.com
Old 1st June 2007, 03:36 PM   #8
Take a look at the UBW.
The DIY info from the developer is at http://www.greta.dhs.org/UBW/
SparkFun has an inexpensive ready to use board.
The UBW is setup to use with a bootloader but if you can use an ICD2 if you have the right linker file.
BCHS/3v0's Tutorials
3v0 is offline
Old 4th June 2007, 12:55 AM   #9
If this is a commercial application (i.e. development hours cost money), did you consider a PDA with extension I/O card? Of course the built-in battery would not last for 2-3 days of constant full-power but standby-wakeup cycle may work.
www.dipmicro.com
dipmicro is offline
Old 8th June 2007, 05:57 PM   #10
I too am in need of direction:
I need to take the on/off output from an array of 8 photo-sensors per board/circuit and translate/transfer them into an SQL database on a remote standalone system.
* Power supply is not an issue.
* I can use PS2, Serial or Bluetooth for transport of data.
* Data reporting rate is as low as once every 1 or 2 seconds per sensor (this is very flexible).
Seems simple enough - I just don't want to trip up on a small detail.
Suggestions?
br
beachracer is offline
Old 8th June 2007, 09:27 PM   #11
Like you say, sounds simple - serial seems the obvious choice, as it's the easiest of the three to use - something as simple as a 16F628 using it's internal 4MHz oscillator is all you need. Send the 8 bits as a single byte, it's really very easy.
My tutorial 7.6 doesn't pretty well what you need, although it sends the data as 8 ASCII characters, 0's and 1's - which may suit you?.
Old 9th June 2007, 05:23 AM   #12
Thanks and awsome. I recieve my IR circuits tomorrow. I will review the tutorial and likely surface with some amateurish questions. Actually to keep the S2N ratio down I will PM you with some specifics.
Sadly, my late business partner was the microcontroller expert - I get the theory just rarely did any programming (I did do a fair bit of burning though) so I'm good with the colours just not with the brus strokes.
Thanks for the direction and help.
br
microcontroller, selection
stk500 clock source atmel microcontroller hani_a General Electronics Chat 5 2nd January 2008 06:19 AM
need advice on microcontroller selection Dialtone Micro Controllers 2 19th April 2005 06:08 PM
Connection of Siemens c167 microcontroller to peripherals. Roslan Electronic Projects Design/Ideas/Reviews 3 23rd March 2004 07:52 PM
Microcontroller selection dm927 Micro Controllers 5 20th January 2004 04:14 PM
Microcontroller selection help Mullaly Micro Controllers 3 3rd August 2003 02:08 PM
