| New Member | please i need a source code in assembley langauge for a calculator that displayed at screen (lcd) which does the four function (*,/,+,-) using 8051 for two digit thanks pleaaaaaaaaaaaase |
| Experienced Member | Hi, i can help you with that code but in diferent way. i have a code for calculator but in picbasic(for pic micocontrollers).if you want ask me again. |
| Experienced Member | Whilst we enjoy helping people; in order to help you we need to know how far you've progressed. Please post what you've already done, including any ideas you've had. If you need help that your lecturer should have provided, please tell us (and your lecturer) what you found was lacking. It is not right if you manage to attain a high grade from the help we have provided if your lecturer is negligent; it will make them appear to be better than they really are and put you at an unfair advantage to your classmates. It also would help us to know more about your education, geographical location and experience with the English language. |
| Experienced Member | Have you tried doing your school assignment by yourself first? Mike |
| Experienced Member | I've seen plenty of these examples in other threads on the forum, just do a quick search for "assembly calculator"
__________________ Spency. PIC Micro's - Your mind is the limit PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net |
| New Member | my code: please help Code: RS EQU P3.4 RW EQU P3.5 EN EQU P3.6 DATA EQU P1 DB4 EQU P3.4 DB5 EQU P3.5 DB6 EQU P3.6 DB7 EQU P3.7 EN EQU P3.3 RS EQU P3.2 mov r7,#3 lcall operand cjne r7,#2,error mov r0,a lcall operator cjne r7,#1,error mov r1,a lcall operand cjne r7,#0,error mov r2,a lcall equal LCALL INIT_LCD MOV A, #'0' error: jmp $ operand: LCALL WRITE_TEXT lCALL INIT_LCD MOV P2, #11110000B JNB P2.0, ROW1 JNB P2.1, ROW2 JNB P2.2, ROW3 JNB P2.3, ROW4 ;JMP LOOP ROW1: MOV P2, #00001111B JNB P2.4, SHOW7 JNB P2.5, SHOW8 JNB P2.6, SHOW9 ;JNB P2.7, SHOW_ADD JMP $ ROW2: MOV P2, #00001111B JNB P2.4, SHOW4 JNB P2.5, SHOW5 JNB P2.6, SHOW6 ;JNB P2.7,SHOW_sub JMP $ ROW3: MOV P2, #00001111B JNB P2.4, SHOW1 JNB P2.5, SHOW2 JNB P2.6, SHOW3 ;JNB P2.7, SHOW_MUL JMP $ ROW4: MOV P2, #00001111B JNB P2.4, SHOW_ON JNB P2.5, SHOW0 ;JNB P2.6, SHOW_equal ;JNB P2.7, SHOW_div JMP $ SHOW0: MOV A, #'0' lCALL WRITE_TEXT lCALL DELAY dec r7 SHOW1: MOV A, #'1' lCALL WRITE_TEXT lCALL DELAY dec r7 ;JMP LOOP SHOW2: MOV A, #'2' lCALL WRITE_TEXT lCALL DELAY ;JMP LOOP SHOW3: MOV A, #'3' lCALL WRITE_TEXT ;CALL DELAY dec r7 ;JMP LOOP SHOW4: MOV A, #'4' lCALL WRITE_TEXT lCALL DELAY dec r7 ;JMP LOOP SHOW5: MOV A, #'5' lCALL WRITE_TEXT lCALL DELAY dec r7 ;JMP LOOP SHOW6: MOV A, #'6' lCALL WRITE_TEXT lCALL DELAY dec r7 ;JMP LOOP SHOW7: MOV A, #'7' lCALL WRITE_TEXT lCALL DELAY dec r7 ;JMP LOOP ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; SHOW8: MOV A, #'8' lCALL WRITE_TEXT lCALL DELAY dec r7 ;JMP LOOP SHOW9: MOV A, #'9' lCALL WRITE_TEXT lCALL DELAY dec r7 ;JMP LOOP ret ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; SHOW_ON: MOV A, #'ON' lCALL WRITE_TEXT lCALL DELAY ;JMP LOOP operator: LCALL WRITE_TEXT lCALL INIT_LCD MOV P2, #11110000B JNB P2.0, ROW11 JNB P2.1, ROW22 JNB P2.2, ROW33 JNB P2.3, ROW44 ;JMP LOOP ROW11: MOV P2, #00001111B ;JNB P2.4, SHOW7 ;JNB P2.5, SHOW8 ;JNB P2.6, SHOW9 JNB P2.7, SHOW_ADD JMP $ ROW22: MOV P2, #00001111B ;JNB P2.4, SHOW4 ;JNB P2.5, SHOW5 ;JNB P2.6, SHOW6 JNB P2.7,SHOW_sub JMP $ ROW33: MOV P2, #00001111B ;JNB P2.4, SHOW1 ;JNB P2.5, SHOW2 ;JNB P2.6, SHOW3 JNB P2.7, SHOW_MUL JMP $ ROW44: MOV P2, #00001111B ;JNB P2.4, SHOW_ON ;JNB P2.5, SHOW0 JNB P2.6, SHOW_equal JNB P2.7, SHOW_div JMP $ SHOW_ADD: MOV A, #'+' lCALL WRITE_TEXT lCALL DELAY dec r7 ;JMP LOOP SHOW_sub: MOV A, #'-' lCALL WRITE_TEXT lCALL DELAY dec r7 ;JMP LOOP SHOW_mul: MOV A, #'*' lCALL WRITE_TEXT lCALL DELAY dec r7 ;JMP LOOP SHOW_div: MOV A, #'/' lCALL WRITE_TEXT lCALL DELAY dec r7 ;JMP LOOP ret equal: LCALL WRITE_TEXT lCALL INIT_LCD MOV P2, #11110000B JNB P2.2, ROW444 ROW444: JNB P2.6, SHOW_equal SHOW_EQUAL: MOV A, #'=' lCALL WRITE_TEXT lCALL DELAY dec r7 ;JMP LOOP ret INIT_LCD: CLR RS CLR RW CLR EN MOV DATA, #38H SETB EN CLR EN lCALL WAIT_LCD CLR RS CLR RW MOV DATA, #0EH SETB EN CLR EN lCALL WAIT_LCD CLR RS CLR RW MOV DATA, #06H SETB EN CLR EN lCALL WAIT_LCD RET WAIT_LCD: MOV R1, #50 LOOP2: MOV R2, #50 LOOP1: DJNZ R2, LOOP1 DJNZ R1, LOOP2 RET WRITE_TEXT: SETB RS CLR RW CLR EN MOV DATA, A SETB EN NOP NOP CLR EN lCALL WAIT_LCD RET DELAY: MOV R1, #50 LOOP4: MOV R2, #50 LOOP3: MOV R3, #300 LOOP5: DJNZ R3, LOOP5 DJNZ R2, LOOP3 DJNZ R1, LOOP4 RET ;mov r0,p3 ;mov r1,p3 ;mov r2,p3 ;mov r3,p3 cjne r1,#'+',sub mov a,r0 add a,r1 jmp equ equ: cjne r3,#'=',error2 lcall WRITE_TEXT ;JMP LOOP error2:nop sub: cjne r1,#'-',mul mov a,r0 subb a,r2 mul: cjne r1,#'*',div mov a,r0 mov b,r2 mul ab div: cjne r1,#'/',error1 mov b,r2 mov a,r0 div ab error1: jmp $ Last edited by sara_6252; 29th May 2007 at 02:45 PM. |
| New Member | please hellllllllllllllllllllllp |
| Experienced Member | you need to have your keyboard cleaned, it seems some of your llllllllllllletters are sticking!
__________________ If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 |
| Experienced Member | Quote:
And sara, you would have much more chances to acheive your project by communicating your problem with us in detail, explaining where is the problem in the code, instead of begging for help. | |
| Calculator!!! | Gaurav Varshney | Micro Controllers | 1 | 6th May 2007 06:15 AM |
| Calculator battery pack. | on1aag | Electronic Projects Design/Ideas/Reviews | 3 | 18th April 2007 12:07 AM |
| help with Calculator LCD | aryyy | Micro Controllers | 4 | 17th July 2006 10:24 AM |
| Talking Calculator using 16F877A | Imprezzive | Micro Controllers | 1 | 5th May 2004 10:48 PM |
| CMOS 7555 Calculator ? | DaleHall | General Electronics Chat | 11 | 15th February 2004 12:51 AM |
