Hey all
ive become quite proficient with PICs, the one im using currently is the PIC16F877A...very common i know and im using TIMER1 really well... Its been quite user friendly However i need another timer, and if i can help it, id like to use another timer and not use multiples of timer 1. I need timer 2 OR timer 0 to count up to 0.1ms (20MHz clock) so loading the PRESCALER to 1:4 will allow this. But Timer0 doesnt indictae how to TURN ON or TURN OFF the timer, i need to be able to control it like TIMER1. Timer 2 has this functionality but gets me a bif baffled. The use of the PR2 register, if i load this with 125, then with the values stated, i should get an interrupt at 0.1ms, but i dont I cant see where ive gone wrong? heres the timer code Code:
BSF T1CON, T1CKPS1 ;THESE 2 LINES
BSF T1CON, T1CKPS0 ;SET PRESCALER TO 8
BCF T1CON, T1OSCEN
BCF T1CON, TMR1CS
BCF T1CON, TMR1ON ;STOPS TIMER
CLRF T2CON
BSF T2CON, T2CKPS0 ;POSTSCALER TO 4
MOVLW h'FE' ;reset timer1 values 0.5MS
MOVWF TMR1H
MOVLW h'C7' ;reset timer1 values 0.5MS
MOVWF TMR1L
BSF INTCON, PEIE
BCF PIR1, TMR1IF
BCF PIR1, TMR2IF
BSF STATUS, 5 ;Change to BANK 1
BSF PIE1, TMR1IE
BSF PIE1, RCIE
BSF OPTION_REG, INTEDG
BCF STATUS, 5 ;Change to BANK 0
BSF INTCON, INTE ;Enable EXTERNAL INTERRUPT
BSF INTCON, GIE ;GLOBAL INTERRUPT ENABLE
BSF T2CON, TMR2ON ;STARTS TIMER
BSF PORTC, 1
Timer2 is FAR easier, and much more useful than timer0 (which is really a bit naff!), but timer2 counts up until the value equals PR2, then starts counting from the beginning again. Check my seven segment LED tutorial at http://www.winpicprog.co.uk/pic_tutorial10.htm which uses a timer2 interrupt to multiplex the displays.
I've done up quick examples of all three timers, and converting it back to assembly from PIC Basic would not be too hard;
http://users.tpg.com.au/gramo/Site/timers.htm The best timer calculator I have found is here; http://www.best-microcontroller-proj...c-timer-0.html TMR2 is definitely the best low maintenance timer, as there is no additional code required once it is running. Just on TMR0, you can disable TMR0 interrupts via INTCON.5 and its just as handy for mid length type delays.
Spency. PIC Micro's - Your mind is the limit PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net |
| 89C52 Timer | ahmedragia21 | Micro Controllers | 9 | 10th February 2007 01:55 PM |
| Watchdog timer in PIC | elexhobby | Micro Controllers | 7 | 6th November 2005 02:51 AM |
| newbie needs help with presetable count down timer 7 segment | zenton | Electronic Projects Design/Ideas/Reviews | 3 | 6th September 2004 04:16 AM |
| countdown timer code | ah_Hui | Micro Controllers | 0 | 26th April 2004 05:30 PM |
| Double Timer, With LED | Rakarin | Electronic Projects Design/Ideas/Reviews | 5 | 27th May 2003 07:14 PM |
