Old 30th April 2007, 10:55 AM   (permalink)
Default help needed for 7 segment display
I'm looking to code a 16f84 PIC chip that makes a seven segment display output H E L P. I've looked all over the internet with no luck. I was wondering if anyone knew any code that would help?
many thanks
mainman is offline
Old 30th April 2007, 11:22 AM   (permalink)
You just need to switch four different patterns to the display, you're unlikely to find EXACTLY what you want, because it's such a strange request - but it's trivial to do.
Old 1st May 2007, 04:00 AM   (permalink)
I think this can be useful to you :
http://www.mikroe.com/en/books/picbook/7_08chapter.htm
mabauti is offline
Old 1st May 2007, 11:21 AM   (permalink)
If you use the good example that 'mabauti' has posted, you will have to extend the Bcdto7Seg table and pointers, to cover 'HELP'
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 1st May 2007, 05:30 PM   (permalink)
Here is the body of the code I wrote for you.The initialize part and the delay you can do.In this example PORTA connecting to common cathodes & segment pins connects to PORTB.
Note that With this simple method you can only show letters.
;NOTES***********************************************************
;COMMON CATHODE SEGMENTS DISPLAY "HELP"
;COMMON CATHODES SHOULD CONNECT TO PORTA ACORDING TO THIS TABLE
;SEGMENTS STARTING FROM LEFT TO RIGHT
;SEG4	SEG3	SEG2	SEG1
;H	E	L	P
;RA0	RA1	RA2	RA3
;SEGMENT PINS SHOULD CONNECT TO PORTB ACORDING TO THIS TABLE
;SAME PINS LINKS TO OTHER SEGMENT PINS
;SEGMENT A-RB0
;SEGMENT B-RB1
;SEGMENT C-RB2
;SEGMENT D-RB3
;SEGMENT E-RB4
;SEGMENT F-RB5
;SEGMENT G-RB6
;DELAY SHOULD BE ABOUT 10MS
HELLO	 MOVLW B'00001'		;TURN ON RA0 & OFF OTHERS
	 MOVWF PORTA
	 MOVLW B'1110011'	;DISPLAY LETTER P
	 MOVWF PORTB
	 CALL  DELAY
	 MOVLW B'00010'		;TURN ON RA1 & OFF OTHERS
	 MOVWF PORTA
	 MOVLW B'0111000'	;DISPLAY LETTER L
	 MOVWF PORTB
	 CALL  DELAY
	 MOVLW B'00100'		;TURN ON RA2 & OFF OTHERS
	 MOVWF PORTA
	 MOVLW B'1111001'	;DISPLAY LETTER E
	 MOVWF PORTB
	 CALL  DELAY
	 MOVLW B'01000'		;TURN ON RA3 & OFF OTHERS
	 MOVWF PORTA
	 MOVLW B'1110110'	;DISPLAY LETTER H
	 MOVWF PORTB
	 CALL  DELAY
	 GOTO  HELLO
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is online now
Old 1st May 2007, 09:34 PM   (permalink)
Gayan has provided a simple, elegant, intuitive example which should be more than enough to get the OP started.
Mike, K8LH is offline
Old 2nd May 2007, 01:57 PM   (permalink)
Device 16F877
Xtal = 4
Dim Number As Byte
Initialization:
	TRISB = %00000000               ' Make PORTB all outputs
	Number = 0                      '
Main:
	 Number = 0
	 Repeat                                    ' Create a loop
		 Inc Number                        ' Increment the Number register
		 GoSub Encode_Segment_Display      ' Convert to segment data and display it
		 DelaymS 500                       ' Small delay to slow down counting
	 Until Number = 4                         ' Loop until number = 4, then reset
	 Goto Main                                 ' Loop forever
Encode_Segment_Display:
	SELECT Number
	    CASE 1
	   		 PORTB = %01110110
	    CASE 2
			 PORTB = %01111001
	    CASE 3
	   		 PORTB = %00111000
	    CASE 4
	   		 PORTB = %01110011
	ENDSELECT
	Return
Click here to watch this program/circuit in action
Hope that helps (The circuit shows a "1" - its just a saved piccy on my site, watch the video to see "H E L P" displayed on the segment)
Spency.
PIC Micro's - Your mind is the limit
PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net
gramo is offline
Problem with LCD code? spondootre Micro Controllers 15 29th April 2008 09:15 AM
Design 5 digits LED 7 segment display...(pH meter)! ayien Electronic Projects Design/Ideas/Reviews 1 12th January 2007 08:43 AM
microchip application A590 /display is ok now prosound90 Micro Controllers 20 18th November 2006 09:44 PM
Trouble with seven segment display. Jeggyman General Electronics Chat 8 6th June 2004 12:18 AM
Convert Leds to 7 Segment Display Almazick General Electronics Chat 21 19th August 2003 07:52 PM
