Old 27th April 2007, 01:59 PM   #1
Default Programming HEX file with MPlab/Inchworm
I'm busy building a LCF project from an elektor magazine. I've got the asm and hex file and would like to know how to program it with mplab (using a inchworm)
If I open the asm file and compiled it with mplab there's a ton or errors, so I thought since i've also got the compiled .hex file I could just write it to the PIC.
Can I just open the hex file in mplab and program it? Or does mplab automatically compile the asm file and them program it.
gregmcc is offline
Old 27th April 2007, 02:10 PM   #2
If it's the one I'm thinking of?, the HEX file doesn't work either - it was bizzarely asembled with masses of blank bytes stored in the HEX file, and pieces of the code missing.
Old 27th April 2007, 02:12 PM   #3
Its the one by John Becker - LCFmet790.asm Correction - Its also from everyday practical eletronics and not elektor.
gregmcc is offline
Old 27th April 2007, 02:25 PM   #4
That's a different matter then, that file works fine.
The source code probably isn't written for MPASM, John Becker had never even heard of MPASM until I told him about it years back, he was using a shareware assembler instead?.
To load the HEX file, try File/Import.
Old 27th April 2007, 04:20 PM   #5
Aah - thanks. That did the trick. Didnt see that import there before
gregmcc is offline
file, hex, mplab or inchworm, programming
UNIT Committment solution using Dynamic programming arijit18 Electronic Projects 1 18th October 2007 09:28 PM
Good Programing Techniques Suraj143 Micro Controllers 5 27th April 2007 08:27 AM
Standalone Pic Programmer Using ICSP or RS232 Neiwiertz Micro Controllers 11 27th May 2006 02:23 AM
Need Help GAL/PAL Programming Steel General Electronics Chat 2 15th May 2004 12:16 AM
how would i generate HEX file for multiple assembly files? belinda_sg Micro Controllers 2 30th March 2004 08:54 AM
