| hello everyone ive decided to build this programmer a while a go and now its done and it dosent work ! gives me a "verify failed at address 000h !" error then when i close icprog and open it again to read the pic its blank and full of 0x3FFF so i thought to myself that the things ive done must cause it not to work so heres what ive changed * swapped the 7406 with a 7404 since i broke two pins from the 7406 IC trying to yank it out of the socket, assuming 7406 ~= 7404 anyone here knows whats the difference ? * i ignored both 1nF capacitors that is just after the data line and the clock line cause i dont have any 1nF or closer value also ive tried to plug it in directly to the parallel port but that dosent help either, and i had noticed that both VCC and VPP(MCLR) led indicators go off during programming/reading i saw some post a while ago on this forum or some other forum cant really remember, it said that RB10 pin or something like that has to be 0V in order to program a chip can some please remind me of what it was please anyone help me got to learn PIC micro | |
| | (permalink) | |||
Have you configured IC-Prog for you programmer? click "Settings" and "Hardware" and say which signals are inverted. | ||||
| Why not build the very simple JDM programmer http://www.semis.demon.co.uk/uJDM/uJDMmain.htm | |
| Let this to be a reminder for v1r05 & others who wants to build similar programmer. One cannot use other buffer/inverter parts to replace 7406 or 7407 because they are chosen for their open-collector properties. Non open collector type will simply not work. I know they are hard to get now. For the 16F628A, one has to ground pin10(RB4/PGM) to disable the low voltage programming (LVP) feature which is enabled on the chip from the factory.
__________________ L.Chung | |
| well thats good thanks Quote:
am i right ? blueroomelectronics, thats will probably be next if this fails thanks alot guys | ||
| btw during programming does the MCLR has to be at 13.Xv or and what about vcc should it be high or low ? thanks again | |
| The 7407 is a good replacement. By the way, you can use the hardware check feature and measure the volatges with a multimeter. EDIT: see the attached picture, are you using these settings? Last edited by eng1; 22nd April 2007 at 11:38 AM. | |
The requirement of 13.0V or higher is dated back from many years ago. With modern PIC parts, I have absolutely no problem using 12V to 13V for VPP. If one checks the corresponding PIC datasheet, it does give both maximum and minimum Vpp threshold voltage. Some PICs has max Vpp of only 12.5V. The original ICD2 changes its VPP voltage accordingly to suit. Will one damage those PIC using higher VPP voltage? You try and tell us.
__________________ L.Chung | ||
| ok, it works now but with winpic not icprog and i can only program a brand new F628 !A, F84A and F628A are not programmable probably they are fried during earlier tests with some other programmer 7.40$ up in smoke and no buzz thanks again guys | |
| writing to EPROM - n00b :) | bulldog5046 | Micro Controllers | 7 | 25th November 2006 09:07 AM |
| n00b ICD2 and MCLR question | DanD | Micro Controllers | 5 | 8th May 2006 03:05 AM |
| n00b with a tail light query | cantfindausername | Electronic Projects Design/Ideas/Reviews | 12 | 15th August 2005 09:19 AM |
| n00b questions (1) circuit analysis/problem solving | Super Mario | General Electronics Chat | 2 | 1st October 2003 12:46 PM |
| n00b needs advice: Infrared Emitter and Receiver | Shion Uzuki | General Electronics Chat | 2 | 3rd June 2003 07:27 AM |
