| Hi all Can JDM programmer program the chip PIC16F877 i/sp cause i try to program this chips many times and the message is verify failed adress 0000 please help me uergent thanks | |
| Yes it does. You want urgent help but have provided next to no details. Please post all the output from the programmer. Did you build the JDM? Are you using a USB to RS232 converter? Have you programmed any other PIC with this programmer?
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | |
| Thanks for fast replay -Yes i have a jdm for 2 years -no i don't have a usb to rs232 converter i use rs232 -i have programmed too many PIC 16f84,16f628,16f877,16f877A-20 many times i hope fast replay again thanks again | |
| Maybe your PIC does not work! Have you tried another pic16f877? which software are you using? | |
| I test two PIC which is did't work at all i use ICprog105d please help | |
| Stupid question, but did you select the F877 programming option and set the proper oscillation settings?
__________________ Buy it, use it, break it, fix it, trash it, change it, mail upgrade it, charge it, point it, zoom it, press it, snap it, work it, quick erase it, write it, cut it, paste it, save it, load it, check it, quick rewrite it, plug it, play it, burn it, rip it, drag and drop it, zip unzip it. | |
| yes my frind i am programming a 8051 for over than 10 years,but PIC maybe only a 3 years ,as i tell you befor my jdm programmer work very well with PIC16f877 and f877A with no problem,but with this dame PIC16f877 i/sp not working my q is... is the jdm programmer program PIC16f877 i/sp with no chang from PIC16f877 or 16F877A or by anther word there is a defirence betwwe them thanks too much | |
| ULTRA clean 9VDC Power Supply Project | Peter_wadley | Electronic Projects | 47 | 19th November 2008 01:54 PM |
| interfacing PIC to 4511 and ICs | mikedf | Micro Controllers | 2 | 1st March 2007 07:04 AM |
| i need clarity on a pic 16f877 | ZIGGY_DAN | Micro Controllers | 3 | 27th January 2007 12:30 PM |
| PIC 16f877 with RTC | ahmad-al3omar | Micro Controllers | 9 | 26th January 2007 11:40 PM |
| Newcomers, please read! (PIC regarded) Upd. 0xD | Jay.slovak | Micro Controllers | 0 | 17th April 2005 02:05 PM |
