Old 9th April 2007, 05:58 PM   #1
Default PIC 10F200 programming -- how ?
I want to do a little project with a 10F200. The ones I have are in sot23-6 pin pack. I notice in the release notes of my picstart-plus programmer, it claims to be able to handle these devices with an adaptor (which I don't have).
So does this mean that I can use my picstart-plus with flying leads to programme my 10F200 ? If so, how might I 'connect' the sot23-6 pack to my programmer , ie which pin goes where ?
regards..
tiny2 is offline
Old 9th April 2007, 06:32 PM   #2
the pins go where they're supposed to go. consult the datasheet for a pinout. the 6 pin 10f has the same two serial programming pins as a 144 pin 18f.
you'll probably want to grab (or make) some sot to dip converters, to make interfacing with that small chip a bit easier.
edit: to save the trouble of consulting the datasheet, pgd pin 1, pgc pin 3. supply pins are vdd pin 5, vss pin 2, vpp pin 6.
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline
Old 9th April 2007, 08:30 PM   #3
Thanks for reply.
I must admit that I've never appreciated how the picstart-plus actually programmes a part, I've just kinda been glad that it does !
Having looked at the data sheet as you suggested, so can I just connect the sot23-6 pack as if it was a pdip pack, but with the pins swapped around ?
Like:-
SOT23 PDIP
pin 1 = pin 5 (ISCPDAT)
pin 2 = pin 7 (Vss)
pin 3 = pin 4 (ISCPCLK)
pin 4 = don't care
pin 5 = pin 2 (Vdd)
pin 6 = pin 8 (MCLR)
I had wondered whether the correct adaptor from microchip had more to it than that.
regards..
tiny2 is offline
Old 9th April 2007, 08:34 PM   #4
No, it just needs to connect the exact same pins as other PIC's.
Old 10th April 2007, 04:33 AM   #5
Smile
Have a look in the "Readme for PICSTART Plus.txt" file ...
Section 7
2)Align Pin 1 of the 10F2xx DIP-8 package to Pin 9 of the PicStart Plus.
If you are going to treat it like a DIP, you will want to map it starting at PIN 9 on the PS+
EDIT: I'm using MPLAB7.30 - haven't looked to see if this has changed on later versions ... I bet not but ???
RabbitResearch is offline
Old 10th April 2007, 07:07 PM   #6
Thanks all for suggestions.
I think I now understand enough to move forward -- famous last words !
"If you are going to treat it like a DIP, you will want to map it starting at PIN 9 on the PS+" -- thanks for pointing that out :-D
I'll make a little demo pcb with flying leads to connect to the zif socket, with on-board links to isolate the 10F200 programming pins from the demo-board led and switch. At least with that I should be able to prove whether its a workable solution for prototypes.
regards..
tiny2 is offline
pic, programming
UNIT Committment solution using Dynamic programming arijit18 Electronic Projects 1 18th October 2007 09:28 PM
Programming PIC using C harebosi Micro Controllers 2 27th March 2007 07:31 AM
PIC 16F627A Programming problem mas Micro Controllers 6 14th March 2007 10:52 PM
PIC programming over 10ft kybert Electronic Projects Design/Ideas/Reviews 13 26th January 2007 05:04 PM
Newcomers, please read! (PIC regarded) Upd. 0xD Jay.slovak Micro Controllers 0 17th April 2005 02:05 PM
