Old 8th April 2007, 07:00 PM   (permalink)
Default Reprogramming PICs with Internal OSC on & MCLR disabled (internal) Inchworm+
Finally tried programming a 16F628A with Internal OSC enabled & MCLR disabled (internal) with the new Inchworm+ (with Mike, K8LH BS250P update (Q1)). You will get a warning but all went well because of VPP before VDD seems to be possible with the mod.
Programming Target...
...Validating configuration fields
ICDWarn0033: MPLAB ICD 2 does not support programming this device if both the internal oscillator and internal MCLR are selected.  You may continue programming, but you are encouraged to cancel, reconfigure your device, and try again.
...Erasing Part
Verifying...
...Verify Succeeded
Programming Configuration Bits
.. Config Memory
Verifying configuration memory...
...Verify Succeeded
...Programming succeeded
08-Apr-2007, 13:55:21
MPLAB ICD 2 Ready
Erasing Target Device...
...Erase Succeeded
MPLAB ICD 2 Ready
Bill
Smart Kits build Smart People
Old 11th April 2007, 12:44 PM   (permalink)
Bill,
I see there's the normal inchworm, inchworm classic and inchworm+
Whats the difference bet. all the versions?
Will the above only work on the inchworm+
I've got the normal inchworm - what do I need to do to mod it to turn it into the + version?
Sorry if this has been asked before but I trolled through the forum and didnt find anything.
gregmcc is offline
Old 11th April 2007, 01:31 PM   (permalink)
Here's the thread. The BS250 PFET mod is simpler but both should work equally well. The relay can switch more current than the PFET.
http://www.electro-tech-online.com/micro-controllers/26984-inchworm-1-5-reed-relay-mod-switched-5v-target.html?highlight=inchworm+relay
Actually the Inchworm you have is the classic. The Inchworm+ has only minor changes but they operate the same.
Bill
Old 11th April 2007, 01:58 PM   (permalink)
Excellent - thanks.
gregmcc is offline
Old 11th April 2007, 02:09 PM   (permalink)
Actually the link doesn't send you to the thread. Do a search for "Inchworm relay" will find the thread (and this one too)
Bill
Old 11th April 2007, 05:10 PM   (permalink)
thanks - I did that. The link takes you to the default page, but I found the link you pointed to.
gregmcc is offline
