| Experienced Member | hello: i want to design a circuit using microcontroller for watching a disel engine parameters as (temperature,presure and its generator) . what is the better choise:PIC or AVR for working near an engine |
| Experienced Member | (portable) PC and DAQ aquisition card from NI |
| Super Moderator | Quote:
| Experienced Member | Go to the Atmel website. Theu have a whole series of AVR chips, specifically for automorive applications. I never read anything on them, as have no need at this time. I just started last December, done a few abusive things in the learning process, and yet to destroy my first MCU. AVR chips are pretty tough. Like it's stated above, you need to protect any circuit placed in the engine compartment from heat, elements, and vibration. All the components, not just the MCU have an operating temperature range. |
| Experienced Member | Quote:
For good reason, you'll find that manufacturers put as much of the electronics as they can, inside the passenger compartment. Vibration, temperature, electrical noise, and moisture are much more moderate. | |
| Moderator | Quote:
__________________ search engine for electronic partsJunebug USB PIC programmer kit. USB Bit Wacker | |
| Experienced Member | True. |
| Experienced Member | There should be sending units that are terminated under the dash (assuming this engine is in a vehicle) for all the things you are after. Can you provide more details? You can pick them up there and use either micro-controller to do the job. Search the forums, there is a fellow doing a speedometer with a PIC chip. |
| Experienced Member | For heat, get a MCU with an extended temperature range. The PIC16F628 extended temperature range device works up to 125C whereas the industrial temp range ones only are spec'd to 85C. The support components also have to be spec'd to the max temp you'll expect as it is always the weakest link that fails.
__________________ --- The days of the digital watch are numbered. --- |
| Experienced Member | If you don't have the $ or £ or € for NI material, check this one: http://www.picotech.com/auto/index.html Please consider scan rate, accuracy, resolution and so on before starting any ADC stuff. |
| New Member | I think the key is not the selection of MCU, BUT your design method. either of them work if you have a good deign.
__________________ robots,AI,microcontroller |
| electric engine capacitors??? | pike | General Electronics Chat | 6 | 7th November 2004 03:42 PM |
| OBD and Engine monitoring system | RK NAIR | Electronic Projects Design/Ideas/Reviews | 3 | 26th October 2004 05:16 AM |
| OBD and Engine monitoring system- Help | RK NAIR | Micro Controllers | 0 | 24th October 2004 04:28 PM |
| Engine Start Button Effects | indecided | Electronic Projects Design/Ideas/Reviews | 4 | 9th October 2004 03:34 PM |
| Engine RPM Counter/LED Display | minhs | Electronic Projects Design/Ideas/Reviews | 4 | 23rd October 2003 08:05 PM |
