| | Thread Tools | Search this Thread | Display Modes |
| Experienced Member | Quote:
Use an op-amp with a gain of 121.156, that will make an input of 41.269mA = 5V output ![]() For an ideal op-amp, the non-inverting amplifier gain (Vout / Vin) is given by ![]()
__________________ Spency. How many PC programs are developed with assembler? Then why use it with PIC's? PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net | |
| Experienced Member | Use a 1M pot for Rf and a 8.2K for R1, that should give you a good range for the gain ![]()
| Experienced Member | hi chandu, I would recommend that you avoid the use of the '-' symbol in your number values, it can be mis-read as a minus variable. How to convert this 0 – 41.269mv signal to 0 –5 v. I would suggest a modification to Gramo's 1Meg Resistor, make it two resistors, one fixed 910K and a 200K multiturn, else the pot will be near end one for a gain of 121 Regards
__________________ Eric "Good enough is Perfect" PIC tutorials: Nigel's site: http://www.winpicprog.co.uk/ Gramo's site: http://www.digital-diy.net/ Last edited by ericgibbs : 27th March 2007 at 05:06 PM. |
| Experienced Member | Ahh yea. maybe use a dual op-amp, and set the gain to 10 on one 12.187 on the other, the gains would multiply eg 41.269mV into the 1st amp(with a gain of 10) would give 410.269mV 410.269mV into the 2nd amp (with a gain of 12.187) would have an output of 5V
| Experienced Member | Your LM324 has 4 amps built into it according to the datasheet
| Experienced Member | Have you taken into account the cold junction compensation of the thermocouple? A TC only measures the difference in temperature between two points so a voltage reading will only tell you the temperature difference between both ends. In order to get an absolute temperature reading you need to know the temperature at one end at the TC. THis is so called "cold-junction compensation" or you set one end to a known temperature. Unless you are only interested in the temperature difference, you will need to use an absolute form of temperature measurement on your microcontroller to figure out the absolute temperature you are measuring. You could also use an IC like the max6675 that takes care of the amplification, cold junction compensation and look-up tables for you. |
| The type of connector | liupengjian | General Electronics Chat | 8 | 22nd December 2004 06:52 AM |
| help on inductor design for buck type dc-to-dc converter | markking | General Electronics Chat | 15 | 15th December 2004 03:37 AM |
| various type of capacitor | yuenkit | Electronic Projects Design/Ideas/Reviews | 1 | 1st December 2004 04:16 PM |
| Electric motor as a generator, DC type? | Johnson777717 | General Electronics Chat | 5 | 23rd June 2004 09:13 PM |
| Cap Type for 555 timer | Screech | General Electronics Chat | 4 | 12th January 2004 11:32 PM |
