| First - I am very, very new to PICs and don't feel confident to develop this project all on my own. Hence this request to you amazingly clever and innovative people! I work in the heavy transport industry. Reversing a 13 metre trailer up to a loading dock is more often than not done by touch! Trailers and loading deck get damaged. I want to develop a simple parking sonar device, using a pair of transducer modules (one on each side of the trailer rear to take care of non-parallel approach) and a bargraph showing the distance from each module to the loading dock. I thought of using a pair of SRF04 modules, a PIC and two bargraph displays. Once I had come up with the concept, I realised I haven't the faintest idea of how to implement the idea. Can anyone help? Thanks | |
| Details of a similar product, using different transducers and discrete logic in place of a microcontroller and audio feedback in place of a bargraph, can be seen here - including a circuit diagram. http://www.velleman.be/be/en/product/view/?id=9147 | |
| I'd recommend downloading Proton Lite, and having a read through the help file and Protons Forums, this would be a very easy program to create with PIC Basic. http://www.picbasic.org/proton_lite.php This device would also be very easy to interface with, and it offers quite a lot of features; * 0 - 255 inches range with 1 inch resolution * 42kHz Ultrasonic sensor * New LV version operates from 2.5-5.5V * Low 2mA supply current * 20Hz reading rate * RS232 Serial Output - 9600bps * Analog Output - 10mV/inch * PWM Output - 147uS/inch * Small, light weight module To read how far away the object is would be as simple as; Video: http://www.box.net/shared/q6mhhh4bu8 Code: Device = 16F877
XTAL = 4
Dim Distance as Float
DECLARE ADIN_RES 10 ' 10-bit result required
DECLARE ADIN_TAD FRC ' RC OSC chosen
DECLARE ADIN_STIME 50 ' Allow 50us sample time
LCD_DTPIN = PORTB.4
LCD_RSPIN = PORTB.2
LCD_ENPIN = PORTB.3
LCD_INTERFACE = 4
LCD_LINES = 2
LCD_TYPE = 0
ADCON1 = %10000000 ' Set analogue input, Vref is Vdd
Input PORTA.0
Input PORTA.1
DelaymS 100
Cls
Main:
Distance = ADIN 0 ' Grab the digital value of PORTA.0
Distance = Distance * 5 / 1023 ' Convert to volts
Distance = Distance / 0.010 ' Find out how many 10mV go into it
Print At 1, 1, "D1 = ", Dec1 Distance, 34, " "
Distance = ADIN 1 ' Grab the digital value of PORTA.1
Print At 2, 1, "D2 = ", Dec1 Distance, 34, " "
Goto Main
__________________ Spency. PIC Micro's - Your mind is the limit PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net | |
| PIXAXE-18 and the SRF04 | fishyghost | Robotics Chat | 10 | 20th June 2006 02:28 PM |
| LED Bargraph thermometer opinion... | William At MyBlueRoom | General Electronics Chat | 2 | 24th May 2006 11:02 PM |
| Purchasing SRF04 in Canada | micro571 | General Electronics Chat | 2 | 3rd April 2006 06:49 AM |
| srf04 ultrasonic sensors | cjgalway1000 | Robotics Chat | 2 | 5th March 2004 05:55 PM |
| Bargraph oil pressure reader using LM3914 | ekooke | Electronic Projects Design/Ideas/Reviews | 1 | 22nd December 2003 10:59 AM |
