I have not really used a VT100 terminal for my serial comunications. I normally just do a VB program that controls the Serial Port and shows me what is happening.
I am going to suppose then that a VT100 terminal emulator sends everything you type serially when a enter is pressed.
PICBASIC PRO doesn't have the ability to handle strings. So to type "get A" is not the best idea....... a good idea is to create your own protocol..... can you send ESC (ASCII 27d)? You could make ESC + 1 be the "GET" comand so that whatever comes after ESC + 1 is the letter to get. (By the way the letter "A" is ASCII 65d or 41 hex, was that what you meant?)
So the program in the PIC would be something along the lines
SERIAL-IN Pin, baudrate, WAIT for ESC, VAR1, VAR2
IF VAR1=1 the GET ASCII value for VAR2
in PICBASIC would be along the terms of:
COMMAND var byte
Letter va Byte
Loop:
Serin Pin#,BaudRate, [27], COMMAND,Letter 'Waits for ESC (ASCII 27)
Select Case COMMAND
Case "1"
Serout Pin#, BaudRate, [Letter, "=", #Letter, "d" 10, 13]
Case else
Serout Pin#, BaudRate, ["Unknown Command", 10, 13]
end select
goto Loop
So if you were to send serially a ESC + 1 + A (ASCII 27d, 49d, 65d) you will receive serially...
A= 65d
Since A is ASCII 65 decimal
i hope it gives you some ideas
Ivancho
