Old 25th March 2007, 08:09 AM   (permalink)
Considered a higher level programming language such as Proton?
Result = ADIN 0
Result = Result * 5 / 1023
Select Result
	   Case >= 3.000
	   		LED_1 = 1
	   Case 1.700 To 2.999
	   		LED_1 = 0
	   Case < 1.700
	   		LED_1 = 1
EndSelect
Spency.
PIC Micro's - Your mind is the limit
PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net
gramo is offline
Old 1st April 2007, 01:08 PM   (permalink)
Can anyone go over this code, and tell me if I'm on right track. I tried the MPLAB simulator, but I am at a loss when it comes to (stimulus functions).
This code was partially copied from Pommie(thanks), and I hope it is well implemented.
All it does is read AN0 and AN1, and compare the results to < than or > than a certain value, and if out of range, LED goes on GP5. If in range LED stays off.
I hope code OK. May need some tweaking.
I know it's been a while since original post, but my family and work, are also a priority.
Here it is,
	list      p=12f675           ; list directive to define processor
	#include <p12f675.inc>        ; processor specific variable definitions
	errorlevel  -302              ; suppress message 302 from list file
	__CONFIG   _CP_OFF & _CPD_OFF & _BODEN_OFF & _MCLRE_OFF & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT
; '__CONFIG' directive is used to embed configuration word within .asm file.
; The lables following the directive are located in the respective .inc file.
; See data sheet for additional information on configuration word settings.
;***** VARIABLE DEFINITIONS
Word equ 0x30
		ORG     0x000             ; processor reset vector
		goto    main              ; go to beginning of program
		ORG     0x004             ; interrupt vector location
; isr code can go here or be located as a call subroutine elsewhere
; these first 4 instructions are not required if the internal oscillator is not used
main
		call    0x3FF             ; retrieve factory calibration value
		bsf     STATUS,RP0        ; set file register bank to 1
		movwf   OSCCAL            ; update register with factory cal value
		bcf     STATUS,RP0        ; set file register bank to 0
;**************************************  Begining of application code  *********************************
portsetup
                        ; ensure Bank "0" is previously selected
       clrf GPIO        ; clear GPIO
                        ; the default chip configuration upon start up, or reset, is analogue input on GP0, GP1, GP2 and GP4
                        ; to alter this configuration, next 2 instructions are necessary, customize per your application.
       movlw 03h        ; move literal 03h working register
       movwf ANSEL      ; move working register to file ANSEL, setting GP2 as digital input and GP1 and GP0 as analogue input.
       movlw 07h        ; move literal to working register
       movwf CMCON      ; turn comparators off as they are not used here
       bsf STATUS, RP0  ; switch to Bank "1" to set up ports
       movlw 0Bh        ; move literal to working register, 0Bh (001011b) (1 = input, 0 = output)
       movwf TRISIO     ; move working register value to TRISIO setting GP3, GP1 and GP0, as inputs, and GP2, GP4 and GP5, as digital outputs.
       bcf STATUS, RP0  ; return to Bank "0"
start
       nop              ; small delay to settle micro
       nop
       nop
       nop
       nop
       btfss GPIO,3     ; check to see if PTO is engaged.(high) if set then skip next instruction
       goto start       ; if not set, loop back to start
       call Init_ADC0
       call Read_ADC1
       nop
       nop
       nop
       call result
       nop
       nop
       call Init_ADC1
       nop
       nop
       nop
       call Read_ADC2
       nop
       nop
       nop
       call result
       goto start
Init_ADC0					;set for AN0
; Set ADCON0
    		movlw   b'10000001'
    		movwf   ADCON0     ; bit 7 is set meaning results will be right justified, and bit 0 is also set, meaning A/D module is operating. no other bit are set so Channel 00 for AN0 will be read.
; Set ADCON1
    		BANKSEL ANSEL
    		movlw   b'10100001'
    		movwf   ANSEL      ; bit 7 is set, but is unimplemented. bit 0 is set, meaning GP0(AN0) is assigned as an analogue input.
    		BANKSEL ADCON0     ; switch to bank 0.
		    return
Init_ADC1					   ; set for AN1
; Set ADCON0
    		movlw   b'10000101'
    		movwf   ADCON0     ; bit 7 is set meaning results will be right justified, and bit 0 is also set, meaning A/D module is operating. bit 2 is set, meaning Channel 01 for AN1 is ready for reading.
; Set ADCON1
    		BANKSEL ANSEL
    		movlw   b'10100101'
    		movwf   ANSEL      ; bit 7 is set, but is unimplemented. bit 0 and 2 are  set, meaning GP0(AN0) and GP2(AN1), are assigned as an analogue input.
    		BANKSEL ADCON0
	    	return
Read_ADC1   ; read CHS0 ( channel 0)
    		bsf	ADCON0, GO_DONE		; initiate conversion
    		btfsc   ADCON0, GO_DONE
    		goto    $-1			    ; wait for ADC to finish
    		movf    ADRESH,W        ; move results from ADRESH file to W
    		movwf   Word            ; move value from W to file named Word
    		BANKSEL ADRESL          ; switch to bank 1
    		movf    ADRESL,W        ; move results from ADRESL file to W
    		movwf   Word+1          ; move value from W to file named Word and add 1
    		return
Read_ADC2   ; read CHS1 (channel 1)
    		return
result
            movlw	low(0x015B)     ; load W with value of low 0x15
	        subwf	Word,W          ; subtract value in file Word, with value in W
        	movlw	high(0x015B)    ; load W with value of 0x15
          	btfss	STATUS,C        ; check to see if bit "C", in Status is set.
         	movlw	high(0x015B)+1  ; load W with value high 0x15 and add 1
        	subwf	Word+1,W        ; subtract value in file Word, with value in W
            btfss	STATUS,C        ; carry clear if word is less than 0x15B
	        call	LEDoff
         	movlw	low(0x0266)
        	subwf	Word,W
        	movlw	high(0x0266)
         	btfss	STATUS,C
         	movlw	high(0x0266)+1
	        subwf	Word+1,W
        	btfsc	STATUS,C        ; carry set if word is greater or equal to 0x266
	        call	LEDon
	        goto start
            ; turn LED off here
LEDon
    bsf GPIO,5                      ; set bit 5 of GPIO register to 1 (high)
    return
LEDoff
    bcf GPIO,5                      ; set bit 5 of GPIO register to 0 (low)
    return
; initialize eeprom locations
		ORG	0x2100
		DE	0x00, 0x01, 0x02, 0x03
		END                       ; directive 'end of program'
Thanks to all.
hjl4 is offline
Old 1st April 2007, 01:48 PM   (permalink)
I would suggest to configure the ansel register at the beginnig only.
       movlw  b'00010011'
       movwf ANSEL
I would turn the ADC off before selecting channels and insert a short delay after turning it on again. Are you using low impedance sources?
eng1 is offline
Old 1st April 2007, 02:14 PM   (permalink)
eng1
movlw b'00010011' movwf ANSEL
Ok I'll try that, as for low impedance , yes.
hjl4 is offline
Old 1st April 2007, 02:19 PM   (permalink)
It seems that you can select a channel without turning the ADC off, but a minimum delay is reqiuired. I'm reading AN546.
eng1 is offline
Old 1st April 2007, 02:33 PM   (permalink)
Yes it is what I thought, as App notes state that after read and conversion done, GO_DONE bit is cleared. as for delay, 5micro secs should do it? Right?
P.S. thanks for the help, eng1.
hjl4 is offline
Old 1st April 2007, 02:42 PM   (permalink)
Ok so I modified my code, so ANSEL at the beginning of portsetup, is only time ANSEL is setup.
hjl4 is offline
Old 1st April 2007, 02:44 PM   (permalink)
You need to change the comparison slightly. What it is doing at the moment is checking if the voltage is less than 1.7V and if it is then turn on LED. It then returns, because of the call, and checks if it's less than 3.0V which it will be as 1.7 is less than 3.0 so it turns it off again.
Try changing the code to,
result
	        goto	LEDon ;    <-----changed
         	movlw	low(0x0266)
        	subwf	Word,W
        	movlw	high(0x0266)
         	btfss	STATUS,C
	        subwf	Word+1,W
	        goto	LEDon  ;   <------changed
	 ;       goto start	   <------removed
            ; turn LED off here
LEDoff		;		<-------moved
		goto	start ; <-------changed
LEDon
HTH
Pommie is online now
Old 1st April 2007, 02:48 PM   (permalink)
Thanks Pommie, It needed some straightening out. I will try and see if it works.
hjl4 is offline
Old 1st April 2007, 02:50 PM   (permalink)
Also, I noticed you don't allow a delay for the ADC acquisition time. I posted some code in this thread that shows how to read the ADC.
Old 1st April 2007, 03:14 PM   (permalink)
Here is code modified. Pommie, you will probably recognize a lot of your work.
Please go over this, as it compiles well for asm.
                                    ; Set ADCON0
    		movlw   b'10000001'
            return
                                    ; Set ADCON0
    		movlw   b'10000101'
            return
Read_ADC1
            call delay1             ; small delay for A/D aquisition time.
    		nop
    		nop
    		nop
    		return
Read_ADC2
    		nop
    		nop
    		nop
    		return
result
	        call	LEDon
         	movlw	low(0x0266)
        	subwf	Word,W
        	movlw	high(0x0266)
         	btfss	STATUS,C
	        subwf	Word+1,W
	        goto	LEDon
            ; turn LED off here
LEDoff
            goto start
LEDon
            goto start
delay1                                      ; will delay W*8 cycles including the call/return
		    addlw	0xff                    ; add -1 to W			1
	    	btfsc	STATUS,Z                ; =zero?				1/2
	    	goto	DoneDelay               ; yes, better get out of here	2
		    nop                             ; delay a bit			1
	    	goto	$+1                     ; delay a bit more		2
	    	goto	delay1                  ; go around again			2
DoneDelay	return	                        ;						2
Thanks.
hjl4 is offline
Old 1st April 2007, 03:24 PM   (permalink)
One little problem, the delay routine requires a value in W so put a movlw 5 before the call. The 5 assumes you have a low impedance source, if you get incorrect readings then change the 5 to something bigger. Apart from that it looks fine. Does it work?
Old 1st April 2007, 03:28 PM   (permalink)
I will keep you posted, and will add value to W for delay.
I should know by early afternoon if it works. Thanks for all the help.
hjl4 is offline
Old 1st April 2007, 09:56 PM   (permalink)
Properly selecting Banks in portsetup would help. But it didn't help. I'm still wondering what is wrong, and maybe 2V on AN0 or 1.5V on AN1 isn't enough.
I will try opamp LM358 or similar.
LED does not light up.
OH well, it's Sunday after all.
hjl4 is offline
Old 12th April 2007, 01:49 PM   (permalink)
It's been a week, and I think I finally got it. Here is code, and again if it looks like you can improve on it, let me know.
Word equ 0x30
main
portsetup
       bcf STATUS, RP0  ; ensure Bank "0" is previously selected
                        ; The default chip configuration upon start up, or reset of 12f675, is analogue input on GP0, GP1, GP2 and GP4
       bsf STATUS, RP0  ; switch to Bank "1" to set up analogue ports
       movwf ANSEL      ; move working register to file ANSEL, setting GP1 and GP0 as analogue input.
start
       nop
       nop
       nop
       nop
       call Init_ADC0
       call Read_ADC0
       nop
       nop
       BANKSEL GPIO     ; this is necessary only if control of pins,(such as outputs) on GPIO5 is needed after reading A/D.
       call result
       nop
       nop
       call Init_ADC1
       call Read_ADC1
       nop
       nop
       call result
       goto start
Init_ADC0
       movlw   b'10000001'
       movwf   ADCON0   ; bit 7 is set meaning results will be right justified, and bit 0 is also set, meaning A/D module is operating. no other bits are set so Channel 00 for AN0 will be set for read.
       return
Init_ADC1
    	movlw   b'10000101'
    	movwf   ADCON0  ; bit 7 is set meaning results will be right justified, and bit 0 is also set, meaning A/D module is operating. bit 2 is set, meaning Channel 01 for AN1 is set for reading.
        return
Read_ADC0
    	goto    $-1			    ; wait for ADC to finish, after which GO/DONE bit is cleared automaticaly after conversion.
    	nop
    	nop
    	nop
    	return
Read_ADC1
    	nop
    	nop
    	nop
    	return
result
	    call	LEDon
        movlw	low(0x0266)
        subwf	Word,W
        movlw	high(0x0266)
        btfss	STATUS,C
	    subwf	Word+1,W
	    goto	LEDon
LEDoff
        goto start
LEDon
        goto start
delay1
        movlw 05h               ; will delay W*8 cycles including the call/return
		nop                     ; delay a bit			1
DoneDelay
    	return
Does anybody know what the minimum readable voltage on A/D module is???
Can it read 1 volt,to a maximum of 5v??
Is it necessary to amplify above 1 v as this is too low???
Thanks to all who have helped me.
P.S. what stumped me for so long, was the fact that, to control an output pin,after reading A/D, you have to switch back to bank "0", after manipulating value in ADRESL.
Otherwise nothing happens.
Also,the datasheet is wrong .
movlw 07h
movwf CMCON
This is example given to setup analogue pins on (ANSEL) register.
It does not setup ANSEL register or modify analogue inputs, but makes sure that Comparators are turned off.
[code]
hjl4 is offline
Microcontroller interface with ADC revjam Chit-Chat 4 1st August 2008 09:21 AM
rms reading mpj111 General Electronics Chat 3 10th July 2006 01:37 PM
is reading lots of schematics the best way to learn? psasidisrcum General Electronics Chat 17 18th April 2005 09:57 PM
Specifications Applied Caltech General Electronics Chat 1 25th December 2003 06:00 PM
A/D help steady reading in low range but bounces in high usaf1 Micro Controllers 3 30th September 2003 02:14 AM
