Notices
Old 19th March 2007, 02:47 AM   (permalink (permalink))
Default Storing Calibration Data
Hello. For my line following, instead of having static values for the line and off the line sensor readings, I was thinking of having a button for the on-line reading and off line reading, so when I press each individual button: I could get the value and store it.
This way, my robot would be better in different conditions without having to reprogram every time.
I was wondering, is it possible? Can PICs store such data? Would anyone have any snippets?
Thanks a lot,
Omar
Omar.M is online now
Old 19th March 2007, 02:55 AM   (permalink (permalink))
That is exactly what the EEPROM is for.
Reading and writing EEPROM varies from chip to chip. Which Pic are you using?
P.S. I think Nigel has a tutorial on this for the 16f628.
Pommie is online now
Old 19th March 2007, 02:56 AM   (permalink (permalink))
Also, the data sheet contains example code for reading and writing.
Old 19th March 2007, 06:03 AM   (permalink (permalink))
Here’s an example of interfacing with 4 EEPROM’s on an I2C network;
Device = 16F876
XTAL 20
ALL_DIGITAL = True
Declare SCL_PIN PORTB.0
Declare SDA_PIN PORTB.1
Dim TX As PORTB.2
Dim DATA_OUT As Byte
Dim DATA_IN(20) As Byte
Dim Address As Word ' 16-bit address required
For Address = 1 To 20
     DATA_OUT = Address
     BStart                                                             ' Send the start command on I2C
     BusOut %10100010,Address,[DATA_OUT]        ' Send the byte to the EEPROM
     BStop                                                            ' Send the stop command on I2C
     DelayMS 5                                                      ' Allow time for allocation of byte
Next Address
     BusOut %10100010,[Address]                          ' Send the address to read
     Brestart                                                          ' Send a restart command on I2C
     BusIn %10100011, [DATA_IN[Address]]            ' Grab data at the above address
Next Address
Stop
Of course you could just use one big EEPROM, but I wanted to kill 2 birds with one stone and describe I2C in my model.
http://users.tpg.com.au/gramo/Site/eeproms.htm
Spency.
PIC Micro's - Your mind is the limit
PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net
gramo is offline
Old 19th March 2007, 06:11 AM   (permalink (permalink))
Why complicate things? The OP wanted to know how to store 2 bytes. This can easily be done in the internal EEPROM of most Pic chips. Did you not realise that Pic's have internal EEPROM?
Old 19th March 2007, 06:51 AM   (permalink (permalink))
I miss read that, sorry. In that case, just use the PIC's onboard memory as suggested;
EWRITE 00, [Piece_Of_Data1]
EWRITE 01, [Piece_Of_Data2]
Variable1 = EREAD 00
Variable2 = EREAD 01
Even easier
Spency.
gramo is offline
Old 19th March 2007, 12:08 PM   (permalink (permalink))
Default Wow
That simple, huh?
Thanks so much.
I should have been more clear-- I am using a 16f684 microcontroller.
Just one more question-- which address would I write the data to?
-Omar
Old 19th March 2007, 12:17 PM   (permalink (permalink))
It's only that simple if you are using basic. If you are using assembler then copy the routines out of the data sheet - there still pretty simple. You can write to any of the locations from zero to however many bytes of EEPROM are available - 256 in the 684.
Old 19th March 2007, 12:24 PM   (permalink (permalink))
Wow, that seems easy enough, thank you
And as for basic, in fact I am using BASIC!
Great Cow Basic, to be exact.
http://gcbasic.sourceforge.net/
Thanks a lot,
Omar
Old 19th March 2007, 08:56 PM   (permalink (permalink))
Note that EEPROM has a limited write endurance. It's unlikely you would ever run into endurance problems with user-entered button presses, however for other cases where you may write them more often the write endurance can be a real issue which may limit the lifespan of the product.
Oznog is offline
Old 20th March 2007, 06:27 AM   (permalink (permalink))
This is about 1,000,000 writes, less in some cases
Spency.
gramo is offline
Old 20th March 2007, 12:32 PM   (permalink (permalink))
Default Oh
Oh. Well, I do not think I will exceed that limit-- this is merely me just experimenting with robotics; it isn't going to be in competitions or anything.
I just have a few questions. Does the data which I store in the EEPROM get erased when I power off the PIC? Or is it permanent? Is it better to get a few sensor readings and finding the average between them... or just two basic readings ?
Thanks,
Omar
Old 20th March 2007, 12:43 PM   (permalink (permalink))
The EEPROM retains the data when the power is removed. Averaging readings really depends what they are, and what you're trying to do with them.
Old 20th March 2007, 12:44 PM   (permalink (permalink))
Whatever you put in the EEPROM should stay there for at least 40 years if you believe the data sheet.
I would average a few readings and store that. End of the day you are going to compare against the average of the 2 readings. The actual readings are probably not too important.
Old 21st March 2007, 04:47 PM   (permalink (permalink))
There's normally a limit to the number of write cycles though.
Screen name: Aloone_Jonez
Hero999 is offline
Need some help with a code provided by ATMEL ikalogic Micro Controllers 1 23rd January 2007 02:45 PM
Hardcode a PIC by hand? (or 16F74 + par.port.prog = problem) smilen Micro Controllers 15 21st November 2005 09:23 AM
Oscilloscope storing data software xmat General Electronics Chat 10 14th August 2005 06:00 PM
Just Joined, Got some bugs I can't find. Thedoctorisin136 Micro Controllers 0 1st March 2005 06:07 PM
An error in pic16f84a, why? Zener_Diode Micro Controllers 6 11th April 2004 02:55 AM
