Old 18th March 2007, 12:07 AM   (permalink)
Default help>>>long delay
hi every body
can any one help me and give me code for delay more than 15 or 30 minutes in assembly language
i'm using pic16f84a
and oscilator 4Mz
and thanks
solidsnike is offline
Old 18th March 2007, 12:50 AM   (permalink)
shoow, thats 1uS per command
That makes 1000000 cycles per second
Multply that by 60 to delay a minute = 6000000
Now I could throw alot of numbers around, or, just use http://www.mnsi.net/~boucher/picloops.html
and it will do it for me. Heres the routine for a 1 minute delay. Call this X times to delay X minutes.
;PIC Time Delay = 60.0000010 s with Osc = 4.000000 MHz
	movlw	D'2'
	movwf	CounterD
	movlw	D'51'
	movwf	CounterC
	movlw	D'146'
	movwf	CounterB
	movlw	D'18'
	movwf	CounterA
loop	decfsz	CounterA,1
	goto	loop
	decfsz	CounterB,1
	goto	loop
	decfsz	CounterC,1
	goto	loop
	decfsz	CounterD,1
	goto	loop
	retlw
Spency.
PIC Micro's - Your mind is the limit
PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net
gramo is offline
Old 18th March 2007, 02:02 AM   (permalink)
I use interrupt routine to count my delay time for my counter, quite accurate and can be very long.
Superman returns..
bananasiong is offline
Old 18th March 2007, 03:55 AM   (permalink)
I agree, though this method may seem a bit advanced to a beginner.
Use timer based interrupts to derive a 1 second "heart beat" in your ISR and implement one or more count down timers in your ISR where they then become simple background tasks.
Here's a relatively simple and tight ISR count down timer example, 16 instructions in all, that can easily provide a 1 second (00:00:01) to 256 hour (255:59:59) delay;
;  unsigned char Timer [] = { 23, 00, 00 };  // hrs, mins, secs
;  if (TimerEnabled)            // if Count Down Timer enabled
;  { n = 2;                     // index seconds array element
;    while (!Timer[n]--)        // while value 00 (post dec value)
;      Timer[n--] = 59;         // set to 59 and bump array index
;    if (!(TimerEnabled = Timer[0]+Timer[1]+Timer[2]))
;    {                          // perform timed out code here
ISR_TMR
        btfss   TMRENA          ; is TMR turned on?               |B0
        goto    ISR_Next        ; no, branch, else                |B0
        movlw   TMRSEC          ;                                 |B0
        movwf   FSR             ; setup indirect access           |B0
ISR_T0  movf    INDF,W          ; is value 0?                     |B0
        bnz     ISR_T1          ; no, branch, else                |B0
        movlw   h'59'           ;                                 |B0
        movwf   INDF            ; reset to '59'                   |B0
        decf    FSR,f           ; decrement array index           |B0
        goto    ISR_T0          ; test next array element         |B0
ISR_T1  decf    INDF,F          ; post decrement array element    |B0
        movf    TMRHRS,W        ; check for time-out              |B0
        addwf   TMRMIN,W        ;                                 |B0
        addwf   TMRSEC,W        ; timed out (00:00:00)?           |B0
        bnz     ISR_Next        ; no, branch, else                |B0
        bcf     TMRENA          ; turn off timer enabled flag     |B0
                                ; perform timed out code here     |B0
ISR_Next
Mike, K8LH is offline
Old 18th March 2007, 11:13 AM   (permalink)
thankx gramo for your help ..... and for your program ...it very good program but when i need delay for one hour ... i need call the delay 60 times that a lot to my code
thankx Mike, K8LH fo help .... but i need to explain to me what is yuor meaning by
Old 18th March 2007, 01:25 PM   (permalink)
Thanks for doing this lamer's college work for him!
Screen name: Aloone_Jonez
Hero999 is offline
Old 18th March 2007, 01:32 PM   (permalink)
It could have been a valid non-home work question lol
Spency.
gramo is offline
Old 18th March 2007, 01:37 PM   (permalink)
Homework or not it's still someone asking for it on a plate. They've probably been turned away from other forums before and thereofre have learnt to disguise requests for homework.
Anyway if all I wanted was a timer and I wasn't bothered about accuracy I wouldn't bother programming a PIC, I would use a simple CMOS oscillator/counter IC.
Hero999 is offline
Old 18th March 2007, 02:56 PM   (permalink)
Please remember that examples may benefit other Forum members and not just the OP. In this case I felt it was important to build on Bananasiong's comments for an interrupt based solution. I was hoping that providing a simple and elegant partial solution that demonstrates some of the power and capabilities of an ISR might encourage readers who haven't used an ISR yet to do some research.
While it seems the OP is a relative novice and doesn't seem interested in doing much research or studying code examples (on PICLIST or elsewhere) on his own, I would hope that other readers may still benefit from the example I provided.
Old 18th March 2007, 04:07 PM   (permalink)
It is very good using interrupt for counter, no matter how, it keeps counting every set interval time.
I've made a dual counter with a PIC and a few 7-segment display, previously I start with a single counter using delay routine, works fine. When come to dual counter, I was going to be crazy, because both counter have to count independently.
I was told to use interrupt early, but just couldn't figure out how to do it, until I faced the problem and found the solution, my job becomes easier a lot.
Superman returns..
Old 18th March 2007, 05:28 PM   (permalink)
Originally Posted by solidsnike
thankx gramo for your help ..... I need call the delay 60 times that a lot to my code
You have to learn how to take a raw resource and modify it for your purposes!
No, you do not call a delay sequentially to achieve your desired time. Instead, you make it parameterized.
No No:
          call minute1
          call minute1
          call minute1
          call minute1
          call minute1
          call minute1
          call minute1
          call minute1
          call minute1
          call minute1
Acceptable:
movlw .10
movwf time_minute
call delay_minute
Acceptable:
movlw .10
call delay_minute2
delay_minute:
dmstart
             do1minutedelay
             decfsz time_minute, f
             goto dm_start
return
delay_minute2:
            movwf time_minute
dmstart2
             do1minutedelay
             goto dm_start2
return
So now take whatever delay routine you like, parameterize it by intializing or importing a timer_variable parameter at the top, and use decfsz time_variable at the bottom. This way the "delaying" is automated.
This type is a blocking delay, nothing else in code takes place except for interrupts and peripherals. If you actually need to be running code during the delay, then its called a timer. Timers will be in the interrupt, better explained, checked for inside an interrupt.
donniedj is offline
Old 18th March 2007, 05:49 PM   (permalink)
Ya, you cannot call the delay for 60 times. Imagine if you want to count for one day or more O.o
decfsz a defined constant is a good choice.
Superman returns..
Old 18th March 2007, 08:06 PM   (permalink)
i have this code is generated by code generator software .. number of cycles in that code is 300000000 but when i calculated the number of cycles it dosenot much or approximates .... the different is a large can anyone tell me what is the wrong
Delay = 300 seconds
; Clock frequency = 4 MHz
; Actual delay = 300 seconds = 300000000 cycles
; Error = 0 %
   cblock
   d1
   d2
   d3
   d4
   endc
         ;299999995 cycles
   movlw   0x54
   movwf   d1
   movlw   0xA1
   movwf   d2
   movlw   0xFD
   movwf   d3
   movlw   0x02
   movwf   d4
Delay_0
   decfsz   d1, f
   goto   $+2
   decfsz   d2, f
   goto   $+2
   decfsz   d3, f
   goto   $+2
   decfsz   d4, f
   goto   Delay_0
         ;5 cycles
   goto   $+1
   goto   $+1
   nop
Old 18th March 2007, 08:08 PM   (permalink)
How did you calculate it?, I suspect you did it wrong!.
Old 18th March 2007, 08:21 PM   (permalink)
can you caculate it and give me the answer >>
Stepper motor control with PIC16F84A netbug Micro Controllers 71 30th August 2008 01:07 PM
Log Data using pic16F877A williB Micro Controllers 32 31st October 2006 10:28 AM
Random Numbers for PIC PDubya Micro Controllers 12 8th July 2006 11:01 PM
Delay routine not working gregmcc Micro Controllers 6 18th September 2005 06:23 PM
Effects stephenpic Micro Controllers 6 19th January 2004 12:57 PM
